ArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2014-07-04T07:37:38+01:00https://brainmodular.org/forums/app.php/feed/topic/44482014-07-04T07:37:38+01:002014-07-04T07:37:38+01:00https://brainmodular.org/forums/viewtopic.php?t=4448&p=29860#p29860right click on your patch and open it with a text editor, then use the search engine (generally [CTRL+F] and look for the words container and pop
Statistics: Posted by nay-seven — 04 Jul 2014, 08:37
]]>2014-07-03T23:59:43+01:002014-07-03T23:59:43+01:00https://brainmodular.org/forums/viewtopic.php?t=4448&p=29854#p29854I have looked everywhere, but can find no module that points to a non existant popup or container. Could this perhaps be a glitch from importing part of the patch from v5?
Statistics: Posted by gurulogic — 04 Jul 2014, 00:59
]]>2014-07-03T20:13:41+01:002014-07-03T20:13:41+01:00https://brainmodular.org/forums/viewtopic.php?t=4448&p=29849#p29849Statistics: Posted by gurulogic — 03 Jul 2014, 21:13
2014-07-03T19:43:27+01:002014-07-03T19:43:27+01:00https://brainmodular.org/forums/viewtopic.php?t=4448&p=29848#p29848Statistics: Posted by woodslanding — 03 Jul 2014, 20:43
]]>2014-07-03T19:02:41+01:002014-07-03T19:02:41+01:00https://brainmodular.org/forums/viewtopic.php?t=4448&p=29847#p29847The poly suggestion is interesting, however if I cannot individually save or reload different versions of each "voice" then it does not work in my situation. Perhaps an interesting idea for a future feature?
If I have any further issue with this, I will file a report as suggested. Thanks!
Statistics: Posted by gurulogic — 03 Jul 2014, 20:02
]]>2014-07-03T09:31:27+01:002014-07-03T09:31:27+01:00https://brainmodular.org/forums/viewtopic.php?t=4448&p=29839#p29839 any chance for a polyphonic version of this patches..?
if not , can you use the report page and send us the LogUsine.log ( run a new instance of Usine, run the workspace and recreate the problem, then copy the log file) you can also join the workspace ( delete vst before if needed)
Statistics: Posted by nay-seven — 03 Jul 2014, 10:31
]]>2014-07-03T09:15:17+01:002014-07-03T09:15:17+01:00https://brainmodular.org/forums/viewtopic.php?t=4448&p=29838#p29838 With the problem patch, when I load 16 copies into a rack (only one active at any time, similar to Usine 5 grid mode) the ib becomes very sluggish and does not even respond until I deactivate/activate the patch, and then it is about a 1/2 second to refresh. All MIDI data and audio is acting normally through the patch. On the other hand, the non problem patch loaded 16 times is snappy as can be, with the exception of a bit of lag when switching visibility from one active patch to another, not a big deal for me really. Also the non problem patch is responsive when loaded 16 times into the same workspace as 16x the non responsive one so it is not a cpu issue or such.
Hoping for a nudge in the right direction to help figure this out, I am really hoping to be using this setup to get ready asap for a show coming up way too soon but this lag thing is unbearable..
Cheers!
Statistics: Posted by gurulogic — 03 Jul 2014, 10:15
]]>BrainModularBrainModular Users Forum2014-07-04T07:37:38+01:00https://brainmodular.org/forums/app.php/feed/topic/44482014-07-04T07:37:38+01:002014-07-04T07:37:38+01:00https://brainmodular.org/forums/viewtopic.php?t=4448&p=29860#p29860right click on your patch and open it with a text editor, then use the search engine (generally [CTRL+F] and look for the words container and pop
]]>2014-07-03T19:43:27+01:002014-07-03T19:43:27+01:00https://brainmodular.org/forums/viewtopic.php?t=4448&p=29848#p29848Statistics: Posted by woodslanding — 03 Jul 2014, 20:43
Cheers!
