ArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2014-07-01T11:20:37+02:00 https://brainmodular.org/forums/app.php/feed/topic/4442 2014-07-01T11:20:37+02:00 2014-07-01T11:20:37+02:00 https://brainmodular.org/forums/viewtopic.php?t=4442&p=29817#p29817 <![CDATA[Midi Filter help]]> value out of the Midi multi filter ?
Statistics: Posted by nay-seven — 01 Jul 2014, 11:20
2014-07-01T02:16:48+02:00 2014-07-01T02:16:48+02:00 https://brainmodular.org/forums/viewtopic.php?t=4442&p=29816#p29816 <![CDATA[Midi Filter help]]> (edit, found my problem)
Statistics: Posted by gurulogic — 01 Jul 2014, 02:16
2014-07-01T01:10:06+02:00 2014-07-01T01:10:06+02:00 https://brainmodular.org/forums/viewtopic.php?t=4442&p=29814#p29814 <![CDATA[Midi Filter help]]> Oh wait, I think I see what to do. I need to use the Midi Filter module to choose a specific channel to send to the Multi Filter module.
Ok thanks, I will check if this works..
Statistics: Posted by gurulogic — 01 Jul 2014, 01:10
2014-07-01T00:23:38+02:00 2014-07-01T00:23:38+02:00 https://brainmodular.org/forums/viewtopic.php?t=4442&p=29812#p29812 <![CDATA[Midi Filter help]]> use the Midi Multi Filter module for this
Statistics: Posted by nay-seven — 01 Jul 2014, 00:23
2014-07-01T00:01:01+02:00 2014-07-01T00:01:01+02:00 https://brainmodular.org/forums/viewtopic.php?t=4442&p=29811#p29811 <![CDATA[Midi Filter help]]>
I need to filter out CC# 94 only on channels 5&6, while at no point interrupting the flow of other MIDI data on these channels, so simply inserting a stop module to interrupt the MIDI flow when channel # + CC# =B is not an adequate solution, and I'm scratching my head trying to figure out how to patch the MIDI filter module to work as a notch filter.
Should be easy enough.. Right?
Statistics: Posted by gurulogic — 01 Jul 2014, 00:01
