ArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2014-06-25T18:56:25+02:00https://brainmodular.org/forums/app.php/feed/topic/44282014-06-25T18:56:25+02:002014-06-25T18:56:25+02:00https://brainmodular.org/forums/viewtopic.php?t=4428&p=29730#p29730Also, sorry maybe not the right place for this, but I have not been able to route MIDI between racks with the Add In module or direct from one rack to another. I'm assuming this might be related?
Statistics: Posted by gurulogic — 25 Jun 2014, 18:56
]]>2014-06-25T10:25:34+02:002014-06-25T10:25:34+02:00https://brainmodular.org/forums/viewtopic.php?t=4428&p=29726#p29726Statistics: Posted by senso — 25 Jun 2014, 10:25
2014-06-25T09:32:28+02:002014-06-25T09:32:28+02:00https://brainmodular.org/forums/viewtopic.php?t=4428&p=29725#p29725your right, it should work as describe in your screen shot. in fact there is a routing issue in Usine, if a patch hasn't any audio in module, input is not calculated. I'll take a look, but the workaround is to add 'audio input module' into the patch.
]]>2014-06-24T19:51:44+02:002014-06-24T19:51:44+02:00https://brainmodular.org/forums/viewtopic.php?t=4428&p=29723#p29723Statistics: Posted by gurulogic — 24 Jun 2014, 19:51
]]>2014-06-24T19:21:39+02:002014-06-24T19:21:39+02:00https://brainmodular.org/forums/viewtopic.php?t=4428&p=29722#p29722you can use simple multiple audio out ? here an example
Statistics: Posted by nay-seven — 24 Jun 2014, 19:21
Statistics: Posted by gurulogic — 24 Jun 2014, 19:14
]]>2014-06-24T02:59:49+02:002014-06-24T02:59:49+02:00https://brainmodular.org/forums/viewtopic.php?t=4428&p=29719#p29719My objective is to have some 36 channels of audio from one rack and 32 channels in another rack all be available as inputs to a third rack. Could use busses but I assume that would be less CPU friendly. Just a two channel example would be fine, thanks!
Statistics: Posted by gurulogic — 24 Jun 2014, 02:59
]]>BrainModularBrainModular Users Forum2014-06-25T18:56:25+02:00https://brainmodular.org/forums/app.php/feed/topic/44282014-06-25T18:56:25+02:002014-06-25T18:56:25+02:00https://brainmodular.org/forums/viewtopic.php?t=4428&p=29730#p29730Also, sorry maybe not the right place for this, but I have not been able to route MIDI between racks with the Add In module or direct from one rack to another. I'm assuming this might be related?
]]>2014-06-25T09:32:28+02:002014-06-25T09:32:28+02:00https://brainmodular.org/forums/viewtopic.php?t=4428&p=29725#p29725your right, it should work as describe in your screen shot. in fact there is a routing issue in Usine, if a patch hasn't any audio in module, input is not calculated. I'll take a look, but the workaround is to add 'audio input module' into the patch.
