ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2014-06-29T19:03:26+02:00 https://brainmodular.org/forums/app.php/feed/topic/4423 2014-06-29T19:03:26+02:00 2014-06-29T19:03:26+02:00 https://brainmodular.org/forums/viewtopic.php?t=4423&p=29791#p29791 <![CDATA[Bouncy ball sequencer]]> good evening and night too :D
Statistics: Posted by waolelaid — 29 Jun 2014, 19:03
2014-06-29T16:15:22+02:00 2014-06-29T16:15:22+02:00 https://brainmodular.org/forums/viewtopic.php?t=4423&p=29785#p29785 <![CDATA[Bouncy ball sequencer]]> Statistics: Posted by aMUSEd — 29 Jun 2014, 16:15
2014-06-29T15:41:04+02:00 2014-06-29T15:41:04+02:00 https://brainmodular.org/forums/viewtopic.php?t=4423&p=29783#p29783 <![CDATA[Bouncy ball sequencer]]> https://dl.dropboxusercontent.com/u/564 … lation.wkp
i only get text file what's its use ? it has a wkp extension but it's a text file what to do whith
the only way for me to understand HH is to read the questions asked in the forum
otherwise i understand nothing to HH
if somebody can explain me why there is a text file Instead of a workspace
thanx in advance
good evening :)
Statistics: Posted by waolelaid — 29 Jun 2014, 15:41
2014-06-28T22:36:31+02:00 2014-06-28T22:36:31+02:00 https://brainmodular.org/forums/viewtopic.php?t=4423&p=29771#p29771 <![CDATA[Bouncy ball sequencer]]> Statistics: Posted by aMUSEd — 28 Jun 2014, 22:36
2014-06-28T22:23:17+02:00 2014-06-28T22:23:17+02:00 https://brainmodular.org/forums/viewtopic.php?t=4423&p=29770#p29770 <![CDATA[Bouncy ball sequencer]]> and thanks for the Iris track, relaxing indeed
and if you plan to add scales to the patch, don't hesitate :)
Statistics: Posted by nay-seven — 28 Jun 2014, 22:23
2014-06-28T21:13:53+02:00 2014-06-28T21:13:53+02:00 https://brainmodular.org/forums/viewtopic.php?t=4423&p=29769#p29769 <![CDATA[Bouncy ball sequencer]]>
https://dl.dropboxusercontent.com/u/564 ... lation.wkp
and here is what it sounds like:
https://dl.dropboxusercontent.com/u/564 ... lation.mp3
it uses an Iris patch called Bell contemplation which is one of Simon Stockhausen's Iris patches, but many bell/chime sounds would do.
Thanks Nay-Seven for your help - this is the sort of thing I bought Usine for.
Statistics: Posted by aMUSEd — 28 Jun 2014, 21:13
2014-06-28T20:51:41+02:00 2014-06-28T20:51:41+02:00 https://brainmodular.org/forums/viewtopic.php?t=4423&p=29768#p29768 <![CDATA[Bouncy ball sequencer]]> Statistics: Posted by aMUSEd — 28 Jun 2014, 20:51
2014-06-28T20:31:56+02:00 2014-06-28T20:31:56+02:00 https://brainmodular.org/forums/viewtopic.php?t=4423&p=29767#p29767 <![CDATA[Bouncy ball sequencer]]> Statistics: Posted by nay-seven — 28 Jun 2014, 20:31
2014-06-28T20:25:58+02:00 2014-06-28T20:25:58+02:00 https://brainmodular.org/forums/viewtopic.php?t=4423&p=29766#p29766 <![CDATA[Bouncy ball sequencer]]>
Only problem is I see you replaced the midi transformer with the scaler - I see why, I tried it myself with both but the scales in the transformer seem to override the scales in the scaler - but the downside is you lose the ability to change length and gain of notes - if there was a way of keeping the transformer but just disabling the scales part that would be ideal - unless there is a module for just note length somewhere?
Statistics: Posted by aMUSEd — 28 Jun 2014, 20:25
2014-06-28T18:36:24+02:00 2014-06-28T18:36:24+02:00 https://brainmodular.org/forums/viewtopic.php?t=4423&p=29765#p29765 <![CDATA[Bouncy ball sequencer]]> here how i patch it:
Download
Statistics: Posted by nay-seven — 28 Jun 2014, 18:36
2014-06-28T18:06:05+02:00 2014-06-28T18:06:05+02:00 https://brainmodular.org/forums/viewtopic.php?t=4423&p=29764#p29764 <![CDATA[Bouncy ball sequencer]]> Statistics: Posted by aMUSEd — 28 Jun 2014, 18:06
2014-06-28T17:41:49+02:00 2014-06-28T17:41:49+02:00 https://brainmodular.org/forums/viewtopic.php?t=4423&p=29763#p29763 <![CDATA[Bouncy ball sequencer]]>
I will try replacing the miid transformer input with this scaler - looks like I can set arbitrary scales with it (but just not microtunings)
I've also added random generators to the length and pitch to create a more organic feel to the sound
Statistics: Posted by aMUSEd — 28 Jun 2014, 17:41
2014-06-28T15:12:37+02:00 2014-06-28T15:12:37+02:00 https://brainmodular.org/forums/viewtopic.php?t=4423&p=29762#p29762 <![CDATA[Bouncy ball sequencer]]> the real scale is coded inside the module. ( you can compare this to the name of a preset for VSTI..?)
Actually there's no way to add other scales to this module
but you can try to create your own patch , here the user andrewchi have begin one, names test scaler
btw, have you test the last patch i made ?
Statistics: Posted by nay-seven — 28 Jun 2014, 15:12
2014-06-28T14:26:35+02:00 2014-06-28T14:26:35+02:00 https://brainmodular.org/forums/viewtopic.php?t=4423&p=29761#p29761 <![CDATA[Bouncy ball sequencer]]> Statistics: Posted by aMUSEd — 28 Jun 2014, 14:26
2014-06-27T20:22:47+02:00 2014-06-27T20:22:47+02:00 https://brainmodular.org/forums/viewtopic.php?t=4423&p=29757#p29757 <![CDATA[Bouncy ball sequencer]]>
ok, i first think you want to create your own add on , but apparently you don't really want to patch right ..? ;-)
About the object number , here a try , replace the patch with this one in your rack.
Download
about tun and scl files, not possible actually, maybe later.
I know that some users are also working on some scales patchs here too
I'm just new to it and finding it daunting - I would like to be able to use microtonal scales - if you can define major and minor scales what other scales does Usine recognise?
What I mean is the names of scales seem to be just text names so I presume Usine is able to recognise these names and change the scale accordingly. So what if I typed say "Iolian' or 'pentatonic' - would it recognise these too - what are the limits to what it can use or not use?
Statistics: Posted by aMUSEd — 27 Jun 2014, 20:22
2014-06-27T19:36:51+02:00 2014-06-27T19:36:51+02:00 https://brainmodular.org/forums/viewtopic.php?t=4423&p=29755#p29755 <![CDATA[Bouncy ball sequencer]]> it is no longer recognized even in Usine 5.80b but i didn't notice those files
i had text file and another but didn't remark those files
and i didn't know Harry Partch i knew nick bartch only
i'll discover him later
thanx and good evening :D
Statistics: Posted by waolelaid — 27 Jun 2014, 19:36
2014-06-27T18:50:35+02:00 2014-06-27T18:50:35+02:00 https://brainmodular.org/forums/viewtopic.php?t=4423&p=29752#p29752 <![CDATA[Bouncy ball sequencer]]>
Download
Statistics: Posted by aMUSEd — 27 Jun 2014, 18:50
2014-06-27T14:20:33+02:00 2014-06-27T14:20:33+02:00 https://brainmodular.org/forums/viewtopic.php?t=4423&p=29750#p29750 <![CDATA[Bouncy ball sequencer]]>
tun and scl files are use for microtonal music , use by some appz and vsti
https://xenharmonic.wikispaces.com/List+of+Microtonal+Software+Plugins
Harry Partch is a composer:
http://en.wikipedia.org/wiki/Harry_Partch
Statistics: Posted by nay-seven — 27 Jun 2014, 14:20
2014-06-27T14:07:49+02:00 2014-06-27T14:07:49+02:00 https://brainmodular.org/forums/viewtopic.php?t=4423&p=29749#p29749 <![CDATA[Bouncy ball sequencer]]> some of the things first what are tun and sci files ? and what
is Partch scales i understand "scales" but i don't find Partch in the dictionnary
if you can light my lantern i could understand the end of the discuss
thanx in advance :)
Statistics: Posted by waolelaid — 27 Jun 2014, 14:07
2014-06-27T12:44:48+02:00 2014-06-27T12:44:48+02:00 https://brainmodular.org/forums/viewtopic.php?t=4423&p=29748#p29748 <![CDATA[Bouncy ball sequencer]]>
Download
Statistics: Posted by nay-seven — 27 Jun 2014, 12:44
2014-06-26T22:15:09+02:00 2014-06-26T22:15:09+02:00 https://brainmodular.org/forums/viewtopic.php?t=4423&p=29745#p29745 <![CDATA[Bouncy ball sequencer]]> Statistics: Posted by aMUSEd — 26 Jun 2014, 22:15
2014-06-26T18:38:25+02:00 2014-06-26T18:38:25+02:00 https://brainmodular.org/forums/viewtopic.php?t=4423&p=29744#p29744 <![CDATA[Bouncy ball sequencer]]> to add more shapes:
copy paste ( and link) the shape + 0to 1 + random module
change color / form of the shape if you need
Statistics: Posted by nay-seven — 26 Jun 2014, 18:38
2014-06-26T18:30:07+02:00 2014-06-26T18:30:07+02:00 https://brainmodular.org/forums/viewtopic.php?t=4423&p=29743#p29743 <![CDATA[Bouncy ball sequencer]]>
Thanks to test iococoi, and yes Amused don't display the container here
here a rack version with your plug Blue2 , i've add a length fader , because if you use sounds like pads maybe notes are too short ?
Download
Fantastic - thankyou that one works! Very nice with more ambient patches like VEC Gold Kihei - how do you add more objects?
Statistics: Posted by aMUSEd — 26 Jun 2014, 18:30
2014-06-26T12:33:32+02:00 2014-06-26T12:33:32+02:00 https://brainmodular.org/forums/viewtopic.php?t=4423&p=29741#p29741 <![CDATA[Bouncy ball sequencer]]>
download
Statistics: Posted by nay-seven — 26 Jun 2014, 12:33
2014-06-26T09:22:53+02:00 2014-06-26T09:22:53+02:00 https://brainmodular.org/forums/viewtopic.php?t=4423&p=29740#p29740 <![CDATA[Bouncy ball sequencer]]>
Download
Statistics: Posted by nay-seven — 26 Jun 2014, 09:22
thanx in advance
good evening :)
Download
Download
Download
thanx in advance :)
Download
Download
download
Download
