ArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2014-05-26T23:59:43+02:00 https://brainmodular.org/forums/app.php/feed/topic/4385 2014-05-26T23:59:43+02:00 2014-05-26T23:59:43+02:00 https://brainmodular.org/forums/viewtopic.php?t=4385&p=29572#p29572 <![CDATA[Teensy/Arduino input]]> Statistics: Posted by oli_lab — 26 May 2014, 23:59
2014-05-26T21:23:18+02:00 2014-05-26T21:23:18+02:00 https://brainmodular.org/forums/viewtopic.php?t=4385&p=29569#p29569 <![CDATA[Teensy/Arduino input]]>
My goal is sending a combination of digital and analog values between teensy and Usine (mostly to Usine). In my workspace they need to be converted to floating point and go to an array bus used to distribute modulation values. (I need a dynamic remote environment that can be rerouted for each preset, and an fp array seemed more efficient and flexible than midi - but someone please correct me if I'm wrong!)
Statistics: Posted by CREDO — 26 May 2014, 21:23
2014-05-26T14:28:49+02:00 2014-05-26T14:28:49+02:00 https://brainmodular.org/forums/viewtopic.php?t=4385&p=29567#p29567 <![CDATA[Teensy/Arduino input]]> Only drawback is you can use only one instance of teensy midi on one computer
otherwise it is very stable.
Statistics: Posted by oli_lab — 26 May 2014, 14:28
2014-05-26T11:10:07+02:00 2014-05-26T11:10:07+02:00 https://brainmodular.org/forums/viewtopic.php?t=4385&p=29563#p29563 <![CDATA[Teensy/Arduino input]]> Statistics: Posted by nay-seven — 26 May 2014, 11:10
2014-05-17T19:25:35+02:00 2014-05-17T19:25:35+02:00 https://brainmodular.org/forums/viewtopic.php?t=4385&p=29501#p29501 <![CDATA[Teensy/Arduino input]]> Statistics: Posted by CREDO — 17 May 2014, 19:25
