ArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2014-05-27T13:14:48+01:00 https://brainmodular.org/forums/app.php/feed/topic/4356 2014-05-27T13:14:48+01:00 2014-05-27T13:14:48+01:00 https://brainmodular.org/forums/viewtopic.php?t=4356&p=29580#p29580 <![CDATA[mass-spring-damper]]>
I started messing with it, or a similar idea, on the lemur app. Wanted a mass to be created on touch, at finger position, and then to reach the default radius by the next bar then start orbiting say 2 x pi Radians per bar, but rather than on a lattice, other masses are present, and are geometrically arranged around the the edge of the container, (on strings, all gravitating towards the center, or finger) and then one can increase and decrease the length of the string (radius) and hit more (or less) of the surrounding objects. Spin faster to increase tempo (and volume of impacts).
Statistics: Posted by Blaakk — 27 May 2014, 14:14
2014-05-27T11:47:39+01:00 2014-05-27T11:47:39+01:00 https://brainmodular.org/forums/viewtopic.php?t=4356&p=29579#p29579 <![CDATA[mass-spring-damper]]> It is a good idea !
I'll work on it soon
Statistics: Posted by oli_lab — 27 May 2014, 12:47
2014-05-27T01:51:05+01:00 2014-05-27T01:51:05+01:00 https://brainmodular.org/forums/viewtopic.php?t=4356&p=29575#p29575 <![CDATA[mass-spring-damper]]>
I've been thinking about centrifuges... would like to use the orbiting mass (like a hammer throw) as a trigger within the space that it occupies. I think overlaying it on certain patterns, like tesselations, fractals and maybe a spider's web, and triggering upon line crosses could maybe yield some good results.
Statistics: Posted by Blaakk — 27 May 2014, 02:51
2014-05-25T22:37:21+01:00 2014-05-25T22:37:21+01:00 https://brainmodular.org/forums/viewtopic.php?t=4356&p=29557#p29557 <![CDATA[mass-spring-damper]]>
http://www.sensomusic.com/forums/upload ... y%20XY.pat
the idea is to use a joypad to move some parameters and have them zeroed after a while...
Statistics: Posted by oli_lab — 25 May 2014, 23:37
2014-05-24T13:43:31+01:00 2014-05-24T13:43:31+01:00 https://brainmodular.org/forums/viewtopic.php?t=4356&p=29555#p29555 <![CDATA[mass-spring-damper]]>
Statistics: Posted by Blaakk — 24 May 2014, 14:43
2014-04-21T23:05:10+01:00 2014-04-21T23:05:10+01:00 https://brainmodular.org/forums/viewtopic.php?t=4356&p=29357#p29357 <![CDATA[mass-spring-damper]]> I'm using quite a lot of buttons that I give to the public...
I found out that a mass-spring model is quite interesting as each time one is pushing a button, it induce a force to the mass.
the more and the faster you push the further the mass moves.
All in one it is a very intuitive and natural way of interfering with sound parameters...
I did some experiment with Puredata (mass2D and link2D)
now I'd like to do something similar ie mass module and link module that can be linked together to form a mass spring network.
would you have any advice ?
found this that could be a starting point :
http://www.ryanmwright.com/tag/c/
Statistics: Posted by oli_lab — 22 Apr 2014, 00:05
