Statistics: Posted by nay-seven — 10 Mar 2014, 14:59
]]>2014-03-10T12:25:45+01:002014-03-10T12:25:45+01:00https://brainmodular.org/forums/viewtopic.php?t=4293&p=29087#p29087I have been fiddling intensively with the surround panner, they are great indeed as one can have a 8:1 setup in a matter a minutes, but I could take advantage of some improvements : - access to the speakers position is a must if you don't use a standard speaker setting ie not in a circle or one omni in the center...(this can be adressed with the surround pack) - also is it possible to have access to the size and mass of the balls, as they are not memorized when the number of balls are changed ? this second topic would be cool as it makes the panning behaviours different from one source to another. maybe keep the sourround panner as is and make an "advance" one ? Physic modeling is great !
Statistics: Posted by oli_lab — 10 Mar 2014, 12:25
]]>2014-02-11T12:22:31+01:002014-02-11T12:22:31+01:00https://brainmodular.org/forums/viewtopic.php?t=4293&p=28973#p28973Statistics: Posted by nay-seven — 11 Feb 2014, 12:22
2014-02-11T11:57:52+01:002014-02-11T11:57:52+01:00https://brainmodular.org/forums/viewtopic.php?t=4293&p=28972#p28972Statistics: Posted by joffo78 — 11 Feb 2014, 11:57
]]>BrainModularBrainModular Users Forum2014-03-10T20:05:10+01:00https://brainmodular.org/forums/app.php/feed/topic/42932014-03-10T20:05:10+01:002014-03-10T20:05:10+01:00https://brainmodular.org/forums/viewtopic.php?t=4293&p=29089#p29089
Statistics: Posted by oli_lab — 10 Mar 2014, 20:05
]]>2014-02-11T11:57:52+01:002014-02-11T11:57:52+01:00https://brainmodular.org/forums/viewtopic.php?t=4293&p=28972#p28972Statistics: Posted by joffo78 — 11 Feb 2014, 11:57
