ArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2014-03-31T21:55:09+02:00https://brainmodular.org/forums/app.php/feed/topic/42692014-03-31T21:55:09+02:002014-03-31T21:55:09+02:00https://brainmodular.org/forums/viewtopic.php?t=4269&p=29256#p29256Statistics: Posted by seamus — 31 Mar 2014, 21:55
2014-03-29T23:48:16+02:002014-03-29T23:48:16+02:00https://brainmodular.org/forums/viewtopic.php?t=4269&p=29237#p29237I've found (today!) my solution : a script in Mobius vst that sends a midi message each time the loop restarts. In Usine, I use this midi note to trigger the cycle.
Statistics: Posted by La Tenaille — 29 Mar 2014, 22:48
]]>2014-03-29T17:28:27+02:002014-03-29T17:28:27+02:00https://brainmodular.org/forums/viewtopic.php?t=4269&p=29232#p29232Statistics: Posted by MoonSafari — 29 Mar 2014, 16:28
]]>2014-01-30T12:15:07+02:002014-01-30T12:15:07+02:00https://brainmodular.org/forums/viewtopic.php?t=4269&p=28864#p28864
Statistics: Posted by La Tenaille — 30 Jan 2014, 11:15
]]>2014-01-30T02:58:33+02:002014-01-30T02:58:33+02:00https://brainmodular.org/forums/viewtopic.php?t=4269&p=28863#p28863Statistics: Posted by ceasless — 30 Jan 2014, 01:58
]]>2014-01-28T20:48:58+02:002014-01-28T20:48:58+02:00https://brainmodular.org/forums/viewtopic.php?t=4269&p=28860#p28860Thanks tom6
Statistics: Posted by La Tenaille — 28 Jan 2014, 19:48
]]>2014-01-28T19:39:11+02:002014-01-28T19:39:11+02:00https://brainmodular.org/forums/viewtopic.php?t=4269&p=28859#p28859 did you try to disable the perfect sincro option ?
]]>2014-01-28T18:22:05+02:002014-01-28T18:22:05+02:00https://brainmodular.org/forums/viewtopic.php?t=4269&p=28858#p28858Precise tempo is usefull for live looping
Statistics: Posted by La Tenaille — 28 Jan 2014, 17:22
]]>2014-01-28T17:30:53+02:002014-01-28T17:30:53+02:00https://brainmodular.org/forums/viewtopic.php?t=4269&p=28857#p28857Statistics: Posted by ceasless — 28 Jan 2014, 16:30
]]>2014-01-28T13:45:49+02:002014-01-28T13:45:49+02:00https://brainmodular.org/forums/viewtopic.php?t=4269&p=28855#p28855If usine receives time clock tempo 120.3, it oscillates between 120 and 121. Is there a way to have a better precision ? Thanks
Statistics: Posted by La Tenaille — 28 Jan 2014, 12:45
]]>BrainModularBrainModular Users Forum2014-03-31T21:55:09+02:00https://brainmodular.org/forums/app.php/feed/topic/42692014-03-31T21:55:09+02:002014-03-31T21:55:09+02:00https://brainmodular.org/forums/viewtopic.php?t=4269&p=29256#p29256Statistics: Posted by seamus — 31 Mar 2014, 21:55
]]>2014-03-29T23:48:16+02:002014-03-29T23:48:16+02:00https://brainmodular.org/forums/viewtopic.php?t=4269&p=29237#p29237I've found (today!) my solution : a script in Mobius vst that sends a midi message each time the loop restarts. In Usine, I use this midi note to trigger the cycle.
