ArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2014-02-06T11:09:59+01:00 https://brainmodular.org/forums/app.php/feed/topic/4265 2014-02-06T11:09:59+01:00 2014-02-06T11:09:59+01:00 https://brainmodular.org/forums/viewtopic.php?t=4265&p=28913#p28913 <![CDATA[Poly-Rythm sequencer enigma]]>
Statistics: Posted by nay-seven — 06 Feb 2014, 11:09
2014-02-06T11:03:24+01:00 2014-02-06T11:03:24+01:00 https://brainmodular.org/forums/viewtopic.php?t=4265&p=28912#p28912 <![CDATA[Poly-Rythm sequencer enigma]]> Statistics: Posted by noise2sine — 06 Feb 2014, 11:03
2014-02-06T10:59:09+01:00 2014-02-06T10:59:09+01:00 https://brainmodular.org/forums/viewtopic.php?t=4265&p=28911#p28911 <![CDATA[Poly-Rythm sequencer enigma]]> here an example for an other question:
Statistics: Posted by nay-seven — 06 Feb 2014, 10:59
2014-02-06T10:44:35+01:00 2014-02-06T10:44:35+01:00 https://brainmodular.org/forums/viewtopic.php?t=4265&p=28910#p28910 <![CDATA[Poly-Rythm sequencer enigma]]>
I'm facing the same problem with the other step sequencer in the patch, i can't find the other matrix corresponding to the others sequencer in the patch.Even with right click and "find in patch" nothing happen contrary to the first sequencer. I think it's because of polyphony.
How can i solve that ?
Thank you
Statistics: Posted by noise2sine — 06 Feb 2014, 10:44
2014-01-23T19:04:17+01:00 2014-01-23T19:04:17+01:00 https://brainmodular.org/forums/viewtopic.php?t=4265&p=28846#p28846 <![CDATA[Poly-Rythm sequencer enigma]]> Statistics: Posted by noise2sine — 23 Jan 2014, 19:04
2014-01-23T17:19:39+01:00 2014-01-23T17:19:39+01:00 https://brainmodular.org/forums/viewtopic.php?t=4265&p=28845#p28845 <![CDATA[Poly-Rythm sequencer enigma]]> mouse mode of this matrix change for x reason, so it sometimes it's jump from fade to toggle..
add a constant module of 1 to the mouse mode inlet, will solve the problem ?
Statistics: Posted by nay-seven — 23 Jan 2014, 17:19
2014-01-23T16:37:36+01:00 2014-01-23T16:37:36+01:00 https://brainmodular.org/forums/viewtopic.php?t=4265&p=28844#p28844 <![CDATA[Poly-Rythm sequencer enigma]]>
Here's the new link :
http://www.sensomusic.com/forums/upload ... st%202.wkp
The values of the steps should work in this patch, my question is where can fix something if it's blocked again ?
Nay
thank you
Statistics: Posted by noise2sine — 23 Jan 2014, 16:37
2014-01-23T16:20:39+01:00 2014-01-23T16:20:39+01:00 https://brainmodular.org/forums/viewtopic.php?t=4265&p=28843#p28843 <![CDATA[Poly-Rythm sequencer enigma]]>
Nothing is working ?
Statistics: Posted by noise2sine — 23 Jan 2014, 16:20
2014-01-23T16:16:55+01:00 2014-01-23T16:16:55+01:00 https://brainmodular.org/forums/viewtopic.php?t=4265&p=28842#p28842 <![CDATA[Poly-Rythm sequencer enigma]]> when i open it's look strange and with many faders ( named faders) and nothing seems to work..?
Statistics: Posted by nay-seven — 23 Jan 2014, 16:16
2014-01-23T15:10:14+01:00 2014-01-23T15:10:14+01:00 https://brainmodular.org/forums/viewtopic.php?t=4265&p=28841#p28841 <![CDATA[Poly-Rythm sequencer enigma]]>
I have made a simple a version of a patch named "Polyrythm sequencer". In my version there is no more sampler or Fx. The patch is only for midi.This tool is really great.But i have a regular bug at some point.When you press the edit button, you have access to the different steps where you can choose how to tune each step.You can can to -12 to 12 . At some point while using the conductor or whatever, there is bug and the only value i can choose are -12 or 12 :( Then it's impossible to choose another value .
Where can i rewrite those values ?
http://www.sensomusic.com/forums/upload ... uencer.wkp
Thank you
Statistics: Posted by noise2sine — 23 Jan 2014, 15:10
Thank you
Nay
thank you
Thank you
