ArrayArrayArrayArray BrainModular BrainModular Users Forum 2014-04-06T09:52:02+02:00 https://brainmodular.org/forums/app.php/feed/topic/4215 2014-04-06T09:52:02+02:00 2014-04-06T09:52:02+02:00 https://brainmodular.org/forums/viewtopic.php?t=4215&p=29298#p29298 <![CDATA[oscillator module suggestions]]> they are many free synth (vst) which can do the trick?
Statistics: Posted by senso — 06 Apr 2014, 09:52
2014-03-31T14:13:06+02:00 2014-03-31T14:13:06+02:00 https://brainmodular.org/forums/viewtopic.php?t=4215&p=29251#p29251 <![CDATA[oscillator module suggestions]]> Indeed this little oscillator module is quite capable and fun.
I did some experiment with FM and was amazed that audio signals can be happily routed in the frequency an amplitude inputs (or is it a misuse ?)
[s]Now it could be very cool to have saw tooth wave form as well[/s]
also I made an audio rectifier with the abs(x) module, is it ok ?
try sync one osc with another one (in audio mode) but no success
Statistics: Posted by oli_lab — 31 Mar 2014, 14:13
2014-02-06T14:26:21+02:00 2014-02-06T14:26:21+02:00 https://brainmodular.org/forums/viewtopic.php?t=4215&p=28914#p28914 <![CDATA[oscillator module suggestions]]> 1) implemented in the next release (1.1) as 'init phase button' and 'init phase value'
2) don't forget that you can expand modules to display more inlets...
3) maybe later, the osc is made very simple
Statistics: Posted by senso — 06 Feb 2014, 13:26
2013-12-12T00:31:59+02:00 2013-12-12T00:31:59+02:00 https://brainmodular.org/forums/viewtopic.php?t=4215&p=28565#p28565 <![CDATA[oscillator module suggestions]]>
1) ability to reset the phase of the wave to a specified position.
2) an input pin to set the wave shape from the control panel.
3) This one may be far fetched but how about the ability to accept an array as a user defined waveform?
any of this possible?
Statistics: Posted by soundmind — 11 Dec 2013, 23:31
