ArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2014-01-16T23:00:47+01:00 https://brainmodular.org/forums/app.php/feed/topic/4186 2014-01-16T23:00:47+01:00 2014-01-16T23:00:47+01:00 https://brainmodular.org/forums/viewtopic.php?t=4186&p=28816#p28816 <![CDATA[How can I store a text with preset manager ?]]>
right, actually the text field is not stored in the preset but will be in the next release
Hi Senso,
It doesn't seem to work with the #9 update ?
Statistics: Posted by La Tenaille — 16 Jan 2014, 23:00
2013-12-31T19:11:21+01:00 2013-12-31T19:11:21+01:00 https://brainmodular.org/forums/viewtopic.php?t=4186&p=28680#p28680 <![CDATA[How can I store a text with preset manager ?]]>
http://www.sensomusic.com/forums/upload ... =pm512.pat
I will still welcome the new text field behaviour, though!
Statistics: Posted by woodslanding — 31 Dec 2013, 19:11
2013-12-31T18:29:25+01:00 2013-12-31T18:29:25+01:00 https://brainmodular.org/forums/viewtopic.php?t=4186&p=28678#p28678 <![CDATA[How can I store a text with preset manager ?]]> text field is not stored in the preset but will be in the next release, if, of course, the saved in preset setting is activated.
@ynohtna : Waiting for this new release, the script is a good option!
Statistics: Posted by senso — 31 Dec 2013, 18:29
2013-12-31T16:18:00+01:00 2013-12-31T16:18:00+01:00 https://brainmodular.org/forums/viewtopic.php?t=4186&p=28676#p28676 <![CDATA[How can I store a text with preset manager ?]]>
Given that I find text editing within Usine a bit clunky, my own work-around is a small piece of FastScript that can load a text file and extract a requested line - indexed from 0 - from it. It's behaviour when attempting to select invalid lines (beyond the file's end, for example) is selectable.
line-from-file.fastscript
I've got more highly featured text parsers for the larger systems I'm prototyping, but attaching this to the num outlet of a preset manager works well when all that's needed is varying text per preset (or whatever, e.g. it is also useful driven by the row/column selector of a matrix).
Statistics: Posted by ynohtna — 31 Dec 2013, 16:18
2013-12-27T22:44:29+01:00 2013-12-27T22:44:29+01:00 https://brainmodular.org/forums/viewtopic.php?t=4186&p=28668#p28668 <![CDATA[How can I store a text with preset manager ?]]>
My constant numbers are 0 (invisible) for the bottom module and 7 (popup window) for the top one.
Not simple, but I can edit the visible texts and store them with the PM.
Hope it helps ;)
Statistics: Posted by La Tenaille — 27 Dec 2013, 22:44
2013-12-27T17:03:12+01:00 2013-12-27T17:03:12+01:00 https://brainmodular.org/forums/viewtopic.php?t=4186&p=28667#p28667 <![CDATA[How can I store a text with preset manager ?]]>
I'm trying to save some text fields within a preset for a patch I'm currently building and am having the same problem with their outputs getting corrupted.
Statistics: Posted by ynohtna — 27 Dec 2013, 17:03
2013-11-22T15:49:31+01:00 2013-11-22T15:49:31+01:00 https://brainmodular.org/forums/viewtopic.php?t=4186&p=28414#p28414 <![CDATA[How can I store a text with preset manager ?]]> But the trouble remains. Now the texts are kind of mixed together, or a "i" appears for an empty field... strange.
Statistics: Posted by La Tenaille — 22 Nov 2013, 15:49
2013-11-22T12:30:14+01:00 2013-11-22T12:30:14+01:00 https://brainmodular.org/forums/viewtopic.php?t=4186&p=28410#p28410 <![CDATA[How can I store a text with preset manager ?]]> saved in preset option is activated in the text field module..?
Statistics: Posted by nay-seven — 22 Nov 2013, 12:30
2013-11-22T12:01:50+01:00 2013-11-22T12:01:50+01:00 https://brainmodular.org/forums/viewtopic.php?t=4186&p=28409#p28409 <![CDATA[How can I store a text with preset manager ?]]> I'd like to store text fields content with a PM. How can I do that ?
Or perhaps there's a workaround I don't know... I have a collection of labels in front of a collection of seq switches, and I'd like to store the text with the PM :
I can enter the text in the patch window if it's much simpler.
Thanks for your help !
Statistics: Posted by La Tenaille — 22 Nov 2013, 12:01
Hi Senso,
Hope it helps ;)
