ArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2013-11-20T15:54:29+02:00 https://brainmodular.org/forums/app.php/feed/topic/4179 2013-11-20T15:54:29+02:00 2013-11-20T15:54:29+02:00 https://brainmodular.org/forums/viewtopic.php?t=4179&p=28380#p28380 <![CDATA[Use knob and lines to control pitch]]>
I imagined to built something like that. I will try your patch later cause i had to stop patching now.
Thank you, so much.
Statistics: Posted by cmodica — 20 Nov 2013, 14:54
2013-11-20T15:51:34+02:00 2013-11-20T15:51:34+02:00 https://brainmodular.org/forums/viewtopic.php?t=4179&p=28379#p28379 <![CDATA[Use knob and lines to control pitch]]>
But with your patch it is impossible to stop the line when i turn the knob
of course, cause was not in your specifications/question... :)
Here a try, but you must add your midi interface as input of the rack, and to set the CC number used for the knob in the patch ( the midi filter module)
Download
Statistics: Posted by nay-seven — 20 Nov 2013, 14:51
2013-11-20T14:37:12+02:00 2013-11-20T14:37:12+02:00 https://brainmodular.org/forums/viewtopic.php?t=4179&p=28378#p28378 <![CDATA[Use knob and lines to control pitch]]> A powerfull combination of pass en stop event flow ... of course.
But with your patch it is impossible to stop the line when i turn the knob ...
Statistics: Posted by cmodica — 20 Nov 2013, 13:37
2013-11-20T13:19:26+02:00 2013-11-20T13:19:26+02:00 https://brainmodular.org/forums/viewtopic.php?t=4179&p=28377#p28377 <![CDATA[Use knob and lines to control pitch]]> Download
great for the live tonight , hope we can listen or see somewhere..? ;)
have fun
Statistics: Posted by nay-seven — 20 Nov 2013, 12:19
2013-11-20T12:43:40+02:00 2013-11-20T12:43:40+02:00 https://brainmodular.org/forums/viewtopic.php?t=4179&p=28376#p28376 <![CDATA[Use knob and lines to control pitch]]>
Knob-and-Curve-ControlPitch-2
But there is something not solve yet. If i remote my knob with a motorised control surface, when the pitch is controlled by the sequenced line the motorised knob on the control surface is not update ... and i can't find a solution ...
The problem is that the value send by the knob go to the pitch and the '' value 0 '' (min value) of the sequenced line. And when the knob value change it stopped the sequenced line. It is a good way for playing with automating pitch control and manuel but it is hard to update the motorised controller.
This evening i will play improvisation in live with 2 others musician Guitar, Trumpet and me with electronic dispositif. I will play with hollyhock and not Usine for the first time in live. I will tell you.
thank you Nay.
Statistics: Posted by cmodica — 20 Nov 2013, 11:43
2013-11-19T21:57:18+02:00 2013-11-19T21:57:18+02:00 https://brainmodular.org/forums/viewtopic.php?t=4179&p=28371#p28371 <![CDATA[Use knob and lines to control pitch]]> Image
Statistics: Posted by nay-seven — 19 Nov 2013, 20:57
2013-11-19T18:40:43+02:00 2013-11-19T18:40:43+02:00 https://brainmodular.org/forums/viewtopic.php?t=4179&p=28369#p28369 <![CDATA[Use knob and lines to control pitch]]>
I tried to build a patch to control the pitch of a sampler with a knob and a sequenced line (or a curve).
I built 3 options :
1 - UP. the min value is the current value of the knob and the max is 24
2 - DOWN. the min is the current value of the knob and the max is -24
3 - NO. Curve or sequenced line not playing because it just play until the end or i use the knob.
Everything works fine, when i use knob the curve stop playing, when i press UP or DOWN the pith is going on.
But i can't find a way to transmit the current curve value to the knob and when the curve finish to play, the pitch is +24 semi tone and suddenly return to the current knob value (for exemple -3) :mad:
i upload my patch, because it seems more complex to tell than play.
I have the sensation that i build a more complex than necessary patch ...
Use knob and Lines to control pitch
Statistics: Posted by cmodica — 19 Nov 2013, 17:40
Thank you, so much.
Download
have fun
thank you Nay.
I built 3 options :
