ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2013-11-29T22:25:27+01:00https://brainmodular.org/forums/app.php/feed/topic/41722013-11-29T22:25:27+01:002013-11-29T22:25:27+01:00https://brainmodular.org/forums/viewtopic.php?t=4172&p=28480#p28480 Perhaps a grid line to recall your settings, and another one without preset recall to perform ?
Statistics: Posted by La Tenaille — 29 Nov 2013, 22:25
]]>2013-11-29T10:36:58+01:002013-11-29T10:36:58+01:00https://brainmodular.org/forums/viewtopic.php?t=4172&p=28478#p28478But during the live i need to change some of the setup. For example the preset feedback of the delay is 60% but when i am playing i change it according to the music. The problem is that each time the line loop restart, the preset is recall and my feedback come back to 60% ...
The same if i bybass an effect, change the state during the live and it suddenly return to his bybass state ...
In fact i'd like to recall a general preset of the workspace but i need to be able to interact with all parameter when i am playing ... so i can't link the preset number with the grid line automation ...
Statistics: Posted by cmodica — 29 Nov 2013, 10:36
]]>2013-11-28T23:11:59+01:002013-11-28T23:11:59+01:00https://brainmodular.org/forums/viewtopic.php?t=4172&p=28477#p28477Statistics: Posted by La Tenaille — 28 Nov 2013, 23:11
2013-11-27T09:21:22+01:002013-11-27T09:21:22+01:00https://brainmodular.org/forums/viewtopic.php?t=4172&p=28455#p28455 The grid is more complex to build than the conductor of Usine 5. With the conductor it is easy to make snapshot of the interface, and very easy to change something and rewrite the snapshot.
With the grid it is more flexible but more complex. I had to add an automation in the grid line (to mute or unmute something for example), and change manualy each automation if i decide to change the state of the mute button in the line. Not possible to rewrite the snapshot ... I had to build the grid step by step too. No snapshot for all the rack state ...
So perhap's the good deal is to do that with a mix of grid, rack preset and workspace preset ?
I will try.
Thanks.
Statistics: Posted by cmodica — 27 Nov 2013, 09:21
]]>2013-11-26T10:06:35+01:002013-11-26T10:06:35+01:00https://brainmodular.org/forums/viewtopic.php?t=4172&p=28444#p28444Statistics: Posted by La Tenaille — 26 Nov 2013, 10:06
]]>2013-11-26T09:26:35+01:002013-11-26T09:26:35+01:00https://brainmodular.org/forums/viewtopic.php?t=4172&p=28442#p28442Statistics: Posted by cmodica — 26 Nov 2013, 09:26
]]>2013-11-26T09:22:58+01:002013-11-26T09:22:58+01:00https://brainmodular.org/forums/viewtopic.php?t=4172&p=28441#p28441Here an example of preset 1 for grid element 1 and preset 2 for grid element 2 :
Statistics: Posted by La Tenaille — 26 Nov 2013, 09:22
]]>2013-11-26T08:36:50+01:002013-11-26T08:36:50+01:00https://brainmodular.org/forums/viewtopic.php?t=4172&p=28439#p28439Statistics: Posted by cmodica — 26 Nov 2013, 08:36
]]>2013-11-25T23:17:15+01:002013-11-25T23:17:15+01:00https://brainmodular.org/forums/viewtopic.php?t=4172&p=28435#p28435 You need to drag a fader from the num preset manager in your patch and add it to the grid if you want to remote from a patch.
Statistics: Posted by La Tenaille — 25 Nov 2013, 23:17
]]>2013-11-25T15:29:12+01:002013-11-25T15:29:12+01:00https://brainmodular.org/forums/viewtopic.php?t=4172&p=28428#p28428I try with the ''recall preset on activation'' and select the rack preset number but nothing change in my rack preset when i change the grid line ?
Statistics: Posted by cmodica — 25 Nov 2013, 15:29
]]>2013-11-14T12:40:44+01:002013-11-14T12:40:44+01:00https://brainmodular.org/forums/viewtopic.php?t=4172&p=28344#p28344workspace and link a fader to its number inlet . Then you can remote this fader in your grid
Statistics: Posted by nay-seven — 14 Nov 2013, 12:40
]]>2013-11-14T12:25:14+01:002013-11-14T12:25:14+01:00https://brainmodular.org/forums/viewtopic.php?t=4172&p=28343#p28343I can recall a rack preset number with the grid, but not for the workspace. How can I do that ? Is there a way to remote this preset panel ? Thanks
Statistics: Posted by La Tenaille — 14 Nov 2013, 12:25
]]>BrainModularBrainModular Users Forum2013-11-29T22:25:27+01:00https://brainmodular.org/forums/app.php/feed/topic/41722013-11-29T22:25:27+01:002013-11-29T22:25:27+01:00https://brainmodular.org/forums/viewtopic.php?t=4172&p=28480#p28480 Perhaps a grid line to recall your settings, and another one without preset recall to perform ?
]]>2013-11-27T09:21:22+01:002013-11-27T09:21:22+01:00https://brainmodular.org/forums/viewtopic.php?t=4172&p=28455#p28455 The grid is more complex to build than the conductor of Usine 5. With the conductor it is easy to make snapshot of the interface, and very easy to change something and rewrite the snapshot.
I will try.
Thanks.
