ArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2013-11-12T02:40:54+01:00https://brainmodular.org/forums/app.php/feed/topic/41642013-11-12T02:40:54+01:002013-11-12T02:40:54+01:00https://brainmodular.org/forums/viewtopic.php?t=4164&p=28315#p28315 edit: derp. just figured it out. I am dumb. Thanks for the help, this whole "click the arrow for more" should keep me occupied for a few more weeks before I run into trouble again!
Statistics: Posted by Aaron_Owlex — 12 Nov 2013, 02:40
]]>2013-11-11T21:31:47+01:002013-11-11T21:31:47+01:00https://brainmodular.org/forums/viewtopic.php?t=4164&p=28314#p28314button module, you can link its mouse down outlet to the create Midi
Statistics: Posted by nay-seven — 11 Nov 2013, 21:31
]]>2013-11-11T20:56:06+01:002013-11-11T20:56:06+01:00https://brainmodular.org/forums/viewtopic.php?t=4164&p=28313#p28313 Bsork, I gave that a shot but for some reason it seems the 1to0 module triggers immediately, no matter how long I hold the button for. The result is a quick short note. Not sure why... it seems that the button is sending out the 0 too quickly! All i have set for the button is default OFF value 0 and ON value 1...
Statistics: Posted by Aaron_Owlex — 11 Nov 2013, 20:56
]]>2013-11-11T10:06:00+01:002013-11-11T10:06:00+01:00https://brainmodular.org/forums/viewtopic.php?t=4164&p=28307#p28307 ( "I'm trying to build a simple grid to send MIDI notes" so in this case, it's not always easy, the next version will contains some new array modules to solve this.
Statistics: Posted by nay-seven — 11 Nov 2013, 10:06
]]>2013-11-11T08:30:13+01:002013-11-11T08:30:13+01:00https://brainmodular.org/forums/viewtopic.php?t=4164&p=28305#p28305Statistics: Posted by bsork — 11 Nov 2013, 08:30
2013-11-11T05:28:14+01:002013-11-11T05:28:14+01:00https://brainmodular.org/forums/viewtopic.php?t=4164&p=28303#p28303 I feel like I'm not asking for a complicated result as this is how most, if not all, MIDI controllers work, akin to a piano. You press it, it goes on, you release, it goes off.
Statistics: Posted by Aaron_Owlex — 11 Nov 2013, 05:28
]]>2013-11-11T03:43:57+01:002013-11-11T03:43:57+01:00https://brainmodular.org/forums/viewtopic.php?t=4164&p=28301#p28301Statistics: Posted by ceasless — 11 Nov 2013, 03:43
]]>2013-11-10T06:27:19+01:002013-11-10T06:27:19+01:00https://brainmodular.org/forums/viewtopic.php?t=4164&p=28297#p28297 My ultimate goal, however, is to just use Usine as a midi controller for Ableton, now that I've gotten a fancy convertible touch laptop, to give me an extra control interface as well as for long bus/plane rides so I can stay productive even if I don't have my regular gear.
Anyway, as an exercise I'm trying to build a simple grid to send MIDI notes, but I'm having trouble with sending note OFF messages.
Right now each pad is a button, patched to a create MIDI message module. I managed to create a VERY complicated and roundabout way of triggering the OFF message (through a number of conditional and math modules) but this seems all too unnecessary... is there an easy way to have a button that sends a note ON when pressed, and sends a note OFF when released? Any help would be much appreciated.
Aaron
Statistics: Posted by Aaron_Owlex — 10 Nov 2013, 06:27
]]>BrainModularBrainModular Users Forum2013-11-12T02:40:54+01:00https://brainmodular.org/forums/app.php/feed/topic/41642013-11-12T02:40:54+01:002013-11-12T02:40:54+01:00https://brainmodular.org/forums/viewtopic.php?t=4164&p=28315#p28315 edit: derp. just figured it out. I am dumb. Thanks for the help, this whole "click the arrow for more" should keep me occupied for a few more weeks before I run into trouble again!
]]>2013-11-11T05:28:14+01:002013-11-11T05:28:14+01:00https://brainmodular.org/forums/viewtopic.php?t=4164&p=28303#p28303 I feel like I'm not asking for a complicated result as this is how most, if not all, MIDI controllers work, akin to a piano. You press it, it goes on, you release, it goes off.
Aaron
