ArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2013-11-10T02:24:01+02:00https://brainmodular.org/forums/app.php/feed/topic/41602013-11-10T02:24:01+02:002013-11-10T02:24:01+02:00https://brainmodular.org/forums/viewtopic.php?t=4160&p=28293#p28293i've test again with a nanoKontrol II and several parameters move on the plug-in can you test this patch, here i see knobs moving Download
Statistics: Posted by nay-seven — 10 Nov 2013, 01:24
]]>2013-11-10T00:21:47+02:002013-11-10T00:21:47+02:00https://brainmodular.org/forums/viewtopic.php?t=4160&p=28291#p28291 Thanks for taking the time, I appreciate it
]]>2013-11-08T23:59:13+02:002013-11-08T23:59:13+02:00https://brainmodular.org/forums/viewtopic.php?t=4160&p=28280#p28280Statistics: Posted by nay-seven — 08 Nov 2013, 22:59
2013-11-08T23:18:59+02:002013-11-08T23:18:59+02:00https://brainmodular.org/forums/viewtopic.php?t=4160&p=28279#p28279Statistics: Posted by Bovo — 08 Nov 2013, 22:18
]]>2013-11-08T23:03:56+02:002013-11-08T23:03:56+02:00https://brainmodular.org/forums/viewtopic.php?t=4160&p=28278#p28278do you use a midi learn feature of the plug-in or have you create a knob from an inlet..?
Statistics: Posted by nay-seven — 08 Nov 2013, 22:03
]]>2013-11-08T22:48:51+02:002013-11-08T22:48:51+02:00https://brainmodular.org/forums/viewtopic.php?t=4160&p=28277#p28277 I'm controling a plugin with an external keyboard with knobs...
I'm able to control the vst parameters (I'm hearing the changes) but the plugin knobs don't move... How do I get the vst to reflect the changes I'm hearing?
]]>BrainModularBrainModular Users Forum2013-11-10T02:24:01+02:00https://brainmodular.org/forums/app.php/feed/topic/41602013-11-10T02:24:01+02:002013-11-10T02:24:01+02:00https://brainmodular.org/forums/viewtopic.php?t=4160&p=28293#p28293i've test again with a nanoKontrol II and several parameters move on the plug-in can you test this patch, here i see knobs moving Download
]]>2013-11-08T23:18:59+02:002013-11-08T23:18:59+02:00https://brainmodular.org/forums/viewtopic.php?t=4160&p=28279#p28279Statistics: Posted by Bovo — 08 Nov 2013, 22:18
