ArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2013-09-25T22:14:27+02:00 https://brainmodular.org/forums/app.php/feed/topic/4089 2013-09-25T22:14:27+02:00 2013-09-25T22:14:27+02:00 https://brainmodular.org/forums/viewtopic.php?t=4089&p=27901#p27901 <![CDATA[Problem with controller and Midi "motorized" mode]]> Statistics: Posted by nay-seven — 25 Sep 2013, 22:14
2013-09-25T21:57:26+02:00 2013-09-25T21:57:26+02:00 https://brainmodular.org/forums/viewtopic.php?t=4089&p=27900#p27900 <![CDATA[Problem with controller and Midi "motorized" mode]]> I really don't know how i missed that.
Thanks !
Statistics: Posted by FarfadetFarfelu — 25 Sep 2013, 21:57
2013-09-25T21:16:30+02:00 2013-09-25T21:16:30+02:00 https://brainmodular.org/forums/viewtopic.php?t=4089&p=27899#p27899 <![CDATA[Problem with controller and Midi "motorized" mode]]> Statistics: Posted by nay-seven — 25 Sep 2013, 21:16
2013-09-25T20:49:24+02:00 2013-09-25T20:49:24+02:00 https://brainmodular.org/forums/viewtopic.php?t=4089&p=27898#p27898 <![CDATA[Problem with controller and Midi "motorized" mode]]>
lividinstruments.com, they mainly sell finished midi controllers.
Do you think the problem comes from the controller ? It seems to work well because the leds turn on when usine generates a midi out.
Statistics: Posted by FarfadetFarfelu — 25 Sep 2013, 20:49
2013-09-25T20:32:23+02:00 2013-09-25T20:32:23+02:00 https://brainmodular.org/forums/viewtopic.php?t=4089&p=27897#p27897 <![CDATA[Problem with controller and Midi "motorized" mode]]> Statistics: Posted by nay-seven — 25 Sep 2013, 20:32
2013-09-25T20:25:41+02:00 2013-09-25T20:25:41+02:00 https://brainmodular.org/forums/viewtopic.php?t=4089&p=27896#p27896 <![CDATA[Problem with controller and Midi "motorized" mode]]>
In mackie mode, The mouse click on the switch does not send midi ouput to the controller (no midi out in the trace panel) and when i turn on the switch with the midi controller is it the same thing, no midi out.
It's a simple midi controller it only understands midi notes and cc.
Statistics: Posted by FarfadetFarfelu — 25 Sep 2013, 20:25
2013-09-25T20:10:32+02:00 2013-09-25T20:10:32+02:00 https://brainmodular.org/forums/viewtopic.php?t=4089&p=27894#p27894 <![CDATA[Problem with controller and Midi "motorized" mode]]> Statistics: Posted by nay-seven — 25 Sep 2013, 20:10
2013-09-25T19:27:17+02:00 2013-09-25T19:27:17+02:00 https://brainmodular.org/forums/viewtopic.php?t=4089&p=27892#p27892 <![CDATA[Problem with controller and Midi "motorized" mode]]> The midi controller turns on switch A and the switch B is supposed to send a midi note out in motorized mode, but it's not working either.
Statistics: Posted by FarfadetFarfelu — 25 Sep 2013, 19:27
2013-09-25T19:20:25+02:00 2013-09-25T19:20:25+02:00 https://brainmodular.org/forums/viewtopic.php?t=4089&p=27891#p27891 <![CDATA[Problem with controller and Midi "motorized" mode]]> I'll try to explain my situation here.
I have a midi controller sending note on/note off signals into usine to control a switch > it works, the switch toggles on and of.
I have the switch configured in motorized mode so that it sends a midi out NOTE ON signal to control the LED on my midi footcontroller.
When i toggle the switch with the mouse in usine, the midi out works and the led lights up on the controller.
BUT if i use the controller to toggle the switch, the switch turns on in Hollyhock but there is no midi out and the led does not turn on !!
I configured my midi out device with the motorized mode turned ON.
I believe in motorized mode, the motorized fader for example should always follow the position of the fader in usine, if the fader is moved by hand, by mouse, or by an external midi device ?
I'm stuck here, how to i make this work so that when i turn on the switch with midi, it sends the corresponding MIDI out signal ?
Thanks.
upd7 1.02.011e.zip win 8 64 bits
Statistics: Posted by FarfadetFarfelu — 25 Sep 2013, 19:20
Thanks !
Thanks.
