ArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2013-09-04T00:16:09+01:00 https://brainmodular.org/forums/app.php/feed/topic/4030 2013-09-04T00:16:09+01:00 2013-09-04T00:16:09+01:00 https://brainmodular.org/forums/viewtopic.php?t=4030&p=27657#p27657 <![CDATA[Layout]]> Thanks for the suggestions and also about the toolbox I am going to try to explore!
-S
Statistics: Posted by sephult — 04 Sep 2013, 01:16
2013-09-03T14:07:44+01:00 2013-09-03T14:07:44+01:00 https://brainmodular.org/forums/viewtopic.php?t=4030&p=27648#p27648 <![CDATA[Layout]]> Not exactly the same than a floating panel but can be a workaround..?
Statistics: Posted by nay-seven — 03 Sep 2013, 15:07
2013-09-03T11:51:23+01:00 2013-09-03T11:51:23+01:00 https://brainmodular.org/forums/viewtopic.php?t=4030&p=27646#p27646 <![CDATA[Layout]]>
1. I was wondering about the toolbox, at this time I have not really dug deep into it's use yet.
2. The icon control, I mean the "Main Menu" Icons.
3. I did try to reproduce the "momentary" detached Syncro problem and could not duplicate on my other system. I will try and see if I can duplicate again on the specific machine.
-S
Statistics: Posted by sephult — 03 Sep 2013, 12:51
2013-08-31T17:21:14+01:00 2013-08-31T17:21:14+01:00 https://brainmodular.org/forums/viewtopic.php?t=4030&p=27607#p27607 <![CDATA[Layout]]>
2_Can you precise a bit..? not sure to understand what you call the "icon control"
3_Can you give us a precise configuration where you can reproduce..?
Statistics: Posted by nay-seven — 31 Aug 2013, 18:21
2013-08-31T15:57:48+01:00 2013-08-31T15:57:48+01:00 https://brainmodular.org/forums/viewtopic.php?t=4030&p=27603#p27603 <![CDATA[Layout]]>
I was playing around with my current setup and starting to notice a few things that would be cool the have.
1. I started playing around with floating windows.
-I would like to see the ability to float the individual racks in windows. In my current setup I use a multiple monitor setup, where the primary monitor is a control station and the secondary is at the keyboard and synth setup. Would be nice to split up the racks that are related between each setup.
2. I wish I could reposition the icon control in it's own window like a floating icon control menu.
3. I did notice Syncro being removed from header was giving me odd response, unsure yet if a bug but seems it would not stay open when click, almost like a momentary activation.
Statistics: Posted by sephult — 31 Aug 2013, 16:57
-S
-S
