ArrayArrayArrayArray BrainModular BrainModular Users Forum 2013-08-30T12:11:00+02:00 https://brainmodular.org/forums/app.php/feed/topic/4026 2013-08-30T12:11:00+02:00 2013-08-30T12:11:00+02:00 https://brainmodular.org/forums/viewtopic.php?t=4026&p=27596#p27596 <![CDATA[Pass if changed for grid items]]> Statistics: Posted by seamus — 30 Aug 2013, 12:11
2013-08-29T16:59:09+02:00 2013-08-29T16:59:09+02:00 https://brainmodular.org/forums/viewtopic.php?t=4026&p=27592#p27592 <![CDATA[Pass if changed for grid items]]> Pass if changed doesn't help when the grid has taken over though
How can I enjoy this style of control with an item controlled by the grid?
Statistics: Posted by seamus — 29 Aug 2013, 16:59
2013-08-29T16:13:08+02:00 2013-08-29T16:13:08+02:00 https://brainmodular.org/forums/viewtopic.php?t=4026&p=27590#p27590 <![CDATA[Pass if changed for grid items]]>
"Pass if changed" doesn't lock up the inlet it's connected to; it operates as if you connected something to an inlet, which gets the current value, and then disconnect,
Statistics: Posted by bsork — 29 Aug 2013, 16:13
2013-08-29T14:52:28+02:00 2013-08-29T14:52:28+02:00 https://brainmodular.org/forums/viewtopic.php?t=4026&p=27588#p27588 <![CDATA[Pass if changed for grid items]]> It is handy to be able to select a preset and then have the delay either bypassed or active depending on the grid patch but I would like to be able to also with a midi controller bypass the delay so that I can freely toggle it. At the moment when an item is controlled by the grid I am not able to control the switch or even change it. Adding a pass if change module somehow? Is that the secret?
Statistics: Posted by seamus — 29 Aug 2013, 14:52
