ArrayArrayArray
BrainModularBrainModular Users Forum2013-08-03T07:35:41+02:00https://brainmodular.org/forums/app.php/feed/topic/39762013-08-03T07:35:41+02:002013-08-03T07:35:41+02:00https://brainmodular.org/forums/viewtopic.php?t=3976&p=27411#p27411Statistics: Posted by woodslanding — 03 Aug 2013, 07:35
2013-07-26T07:37:59+02:002013-07-26T07:37:59+02:00https://brainmodular.org/forums/viewtopic.php?t=3976&p=27342#p27342 However, I just set up a simplest possible test, and I get this result:
2 of the icons are found and display, so the idea is correct. One Icon won't display, and one won't display but also gives a 'file not found' error. (EDIT: this version of the patch only has 3 options, of which 2 display.)
Can someone try and test this? Unzip the file, and put the icons in a folder called PNGs inside the config folder.
I tried reloading and restarting several times, and got the same result.
Also, I notice that the fileselector is disabled when a cable is plugged into the icon input on the switch, but not re-enabled when I disconnect the wire. Also, the icon listed in the parameter display sometimes stops updating, even though the icon is changing.
Also, I'd like to keep my icons in the usine folder, rather than hard-coding a path. Ideally, I'd put them in a subfolder inside config, as that's the folder I update with new releases. Then the icons would always be found.
Is there a syntax for this? Does usine have a %HOME% folder??
If not, consider this a feature request
cheers, -eric
P.S. I realized I'm sending these path strings down a buss, so the bug where text doesn't work in busses may play a part in these crashes.
Statistics: Posted by woodslanding — 26 Jul 2013, 07:17
]]>BrainModularBrainModular Users Forum2013-08-03T07:35:41+02:00https://brainmodular.org/forums/app.php/feed/topic/39762013-08-03T07:35:41+02:002013-08-03T07:35:41+02:00https://brainmodular.org/forums/viewtopic.php?t=3976&p=27411#p27411Statistics: Posted by woodslanding — 03 Aug 2013, 07:35
]]>2013-07-26T07:37:59+02:002013-07-26T07:37:59+02:00https://brainmodular.org/forums/viewtopic.php?t=3976&p=27342#p27342 However, I just set up a simplest possible test, and I get this result:
cheers, -eric
