ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2016-04-20T15:46:07+02:00 https://brainmodular.org/forums/app.php/feed/topic/3968 2016-04-20T15:46:07+02:00 2016-04-20T15:46:07+02:00 https://brainmodular.org/forums/viewtopic.php?t=3968&p=35144#p35144 <![CDATA[vst version of Hollyhock?]]> now with sdk added to make custom usine powered vsti plugins that would be so powerfull and spreadable..
Statistics: Posted by 23fx23 — 20 Apr 2016, 15:46
2016-04-20T10:22:21+02:00 2016-04-20T10:22:21+02:00 https://brainmodular.org/forums/viewtopic.php?t=3968&p=35135#p35135 <![CDATA[vst version of Hollyhock?]]> Statistics: Posted by Shintylla — 20 Apr 2016, 10:22
2016-04-20T07:40:57+02:00 2016-04-20T07:40:57+02:00 https://brainmodular.org/forums/viewtopic.php?t=3968&p=35133#p35133 <![CDATA[vst version of Hollyhock?]]> about rewire:
rewire is a useful feature if anybody(like myself) uses another daw to record and you need to record your GIGANTIC Usine's patch.
+1 on rewire
I personally fell the lackof ergonomics in editing patches. A full screen editor and a undo that works better would be +2
A question, in which language or languages is usine written?
Statistics: Posted by Shintylla — 20 Apr 2016, 07:40
2016-04-05T22:24:21+02:00 2016-04-05T22:24:21+02:00 https://brainmodular.org/forums/viewtopic.php?t=3968&p=35094#p35094 <![CDATA[vst version of Hollyhock?]]> Statistics: Posted by oli_lab — 05 Apr 2016, 22:24
2016-04-05T12:21:18+02:00 2016-04-05T12:21:18+02:00 https://brainmodular.org/forums/viewtopic.php?t=3968&p=35093#p35093 <![CDATA[vst version of Hollyhock?]]> For this reason I haven't renewed my membership in quite a while and at this point I've basically abandoned/replaced Usine, but I still come here from time to time and specifically search for news on the VST front. I have no realistic expectations anymore but there's always that bit of irrational faith lurking... ;)
Statistics: Posted by Juanjo — 05 Apr 2016, 12:21
2016-02-05T22:43:01+02:00 2016-02-05T22:43:01+02:00 https://brainmodular.org/forums/viewtopic.php?t=3968&p=34654#p34654 <![CDATA[vst version of Hollyhock?]]> Statistics: Posted by gurulogic — 05 Feb 2016, 21:43
2016-02-05T15:41:25+02:00 2016-02-05T15:41:25+02:00 https://brainmodular.org/forums/viewtopic.php?t=3968&p=34650#p34650 <![CDATA[vst version of Hollyhock?]]> Statistics: Posted by damstraversaz — 05 Feb 2016, 14:41
2016-02-05T15:13:39+02:00 2016-02-05T15:13:39+02:00 https://brainmodular.org/forums/viewtopic.php?t=3968&p=34647#p34647 <![CDATA[vst version of Hollyhock?]]> There was Usine Pro, Easine, Usine Stage before and I think a free version too. It was all rather confusing and I never really understood what the idea behind all those versions was. Easine had the most output channels if I remember correctly.
Addons are not compatible between that old line of versions and the new one - AFAIK the old versions were coded in Delphi (correct me if I'm wrong) and now everything is C++, so it's a pretty much total re-write as far as I understand.
A VST verson of Hollyhock would be stil very welcome. My main Host is Bitwig Studio and it does not support ReWire, so that would be useless for me personally.
Cheers,
Tom
Statistics: Posted by Thomas Helzle — 05 Feb 2016, 14:13
2016-02-01T02:42:21+02:00 2016-02-01T02:42:21+02:00 https://brainmodular.org/forums/viewtopic.php?t=3968&p=34599#p34599 <![CDATA[vst version of Hollyhock?]]>
I use some VST versions of Easine (Usine 5 in a single patch) in Reaper.
There seems to be no problem with Windows 10 and the VST has the benefit of multitouch.
Hello jean-marc duchenne,
Thanks for your input.
It seems to me that Easine is the modular part of Usine which can be used independently of Usine. http://www.sensomusic.com/wiki/doku.php ... st_version . Or is it that Easine can have one addon? In my case I am primary interested using the multi-touch midi controller addons so a midi input and output is essential.
The Version 5 addons and the Hollyhock addons are not compatible. Too bad! http://www.sensomusic.org/addons.php (Use the drop down menu to select the version)
So for the detailed questions. I am very new to Usine so very likely I have this all wrong.
Edti: On second thought I would like to use all the available compatible addons.
Statistics: Posted by Vas — 01 Feb 2016, 01:42
2016-01-31T09:38:25+02:00 2016-01-31T09:38:25+02:00 https://brainmodular.org/forums/viewtopic.php?t=3968&p=34595#p34595 <![CDATA[vst version of Hollyhock?]]> I use some VST versions of Easine (Usine 5 in a single patch) in Reaper.
Statistics: Posted by jean-marc duchenne — 31 Jan 2016, 08:38
2016-01-31T01:10:36+02:00 2016-01-31T01:10:36+02:00 https://brainmodular.org/forums/viewtopic.php?t=3968&p=34593#p34593 <![CDATA[vst version of Hollyhock?]]>
Will all the current modules and addons be compatible with Usine 5?
Is Usine 5 compatible with Windows 10, 64 bit?
Will Usine 5 work as a VSTi in FL Studio 12, Studio One v3 and Reaper? MY interest in multitouch is in the performance of music not so much the editing and mixing.
If so it may be worth purchasing Usine Hollyhock 2 now and hope that eventually other DAW’s will be able host Usine Hollyhock as a VSTi.
Statistics: Posted by Vas — 31 Jan 2016, 00:10
2016-01-30T23:49:59+02:00 2016-01-30T23:49:59+02:00 https://brainmodular.org/forums/viewtopic.php?t=3968&p=34592#p34592 <![CDATA[vst version of Hollyhock?]]> Statistics: Posted by nay-seven — 30 Jan 2016, 22:49
2016-01-30T23:20:22+02:00 2016-01-30T23:20:22+02:00 https://brainmodular.org/forums/viewtopic.php?t=3968&p=34590#p34590 <![CDATA[vst version of Hollyhock?]]>
How does one become a Platinum Member so I can get the free Uisine Hollyhock V1.1 which can be a VST. Or what is the most economical way to get the free Uisine Hollyhock V1.1. I mostly will like to use the multitouch midi controllers. (addons? Modules?)
I would be even happier if the addons or modules were available as VST/VSTi's to use in any DAW.
Statistics: Posted by Vas — 30 Jan 2016, 22:20
2015-04-27T04:03:07+02:00 2015-04-27T04:03:07+02:00 https://brainmodular.org/forums/viewtopic.php?t=3968&p=32516#p32516 <![CDATA[vst version of Hollyhock?]]> Statistics: Posted by symplx — 27 Apr 2015, 04:03
2015-04-21T09:50:59+02:00 2015-04-21T09:50:59+02:00 https://brainmodular.org/forums/viewtopic.php?t=3968&p=32378#p32378 <![CDATA[vst version of Hollyhock?]]>
[sub]coque htc one m9[/sub] [sub]housse htc one m9[/sub]
Statistics: Posted by lgbtten — 21 Apr 2015, 09:50
2015-04-20T19:06:10+02:00 2015-04-20T19:06:10+02:00 https://brainmodular.org/forums/viewtopic.php?t=3968&p=32370#p32370 <![CDATA[vst version of Hollyhock?]]> but many ppl prefere handle one single project ina single main daw, with saving / reloading a projectmeans all vst are ok in one shot,
also i guess most 'oustside' solutions are more suspect to extra latency buffers for audio/midi flows, extra cpu and less precision vsttime info/ midi clock, roundings jitter ect.
Statistics: Posted by 23fx23 — 20 Apr 2015, 19:06
2015-04-20T18:35:32+02:00 2015-04-20T18:35:32+02:00 https://brainmodular.org/forums/viewtopic.php?t=3968&p=32369#p32369 <![CDATA[vst version of Hollyhock?]]> Statistics: Posted by oli_lab — 20 Apr 2015, 18:35
2015-04-20T18:10:38+02:00 2015-04-20T18:10:38+02:00 https://brainmodular.org/forums/viewtopic.php?t=3968&p=32368#p32368 <![CDATA[vst version of Hollyhock?]]> :)
that's the only little thing to truely convert all my friends to usine. sadly no one wants to give a shot if outside usual daw, worklow is a bit affected.
imo when usine will be re-avaible as a vst/i and remote avaible for ios/android devices it will instant blast out anything avaible on earth, and for a decade :D.
Statistics: Posted by 23fx23 — 20 Apr 2015, 18:10
2015-04-20T17:05:46+02:00 2015-04-20T17:05:46+02:00 https://brainmodular.org/forums/viewtopic.php?t=3968&p=32367#p32367 <![CDATA[vst version of Hollyhock?]]> Is VST version still on the map for Hollyhock II ?
Thanks.
Statistics: Posted by FarfadetFarfelu — 20 Apr 2015, 17:05
2014-07-28T06:24:51+02:00 2014-07-28T06:24:51+02:00 https://brainmodular.org/forums/viewtopic.php?t=3968&p=30074#p30074 <![CDATA[vst version of Hollyhock?]]> Statistics: Posted by magickz — 28 Jul 2014, 06:24
2014-07-19T18:28:00+02:00 2014-07-19T18:28:00+02:00 https://brainmodular.org/forums/viewtopic.php?t=3968&p=30022#p30022 <![CDATA[vst version of Hollyhock?]]> Statistics: Posted by sephult — 19 Jul 2014, 18:28
2014-07-17T15:08:54+02:00 2014-07-17T15:08:54+02:00 https://brainmodular.org/forums/viewtopic.php?t=3968&p=30019#p30019 <![CDATA[vst version of Hollyhock?]]>
Beyond the joke,if i can give you an advice :is to keep the things simple.For my part i'm still using Usine v5, and it works fine according to my simple needs.As an average musician and composer,i realised that the tool can't replace the worker.I have tried many "complex configuration" but for better emotions and result, i returned to the simpliest form.As soon as you have found your simpliest configuration(i mean, the one you can master,even if it's just a sampler and it can be enough (or maybe two samplers :)),your flow of inspiration will come and will be easy to capture.I do understand that many people are crazy about patching and it's fine only if you have the level for that or if you are really ok for struggling for that.
I hope you had a great time walking. :)
Statistics: Posted by noise2sine — 17 Jul 2014, 15:08
2014-07-17T13:52:02+02:00 2014-07-17T13:52:02+02:00 https://brainmodular.org/forums/viewtopic.php?t=3968&p=30018#p30018 <![CDATA[vst version of Hollyhock?]]> and why "tennis" there are others things to do i don't like sport i prefer
long walk in the forest
and as the sun is shinning i going to do one
and i want to Thank you for your open-mindedness
Cheers :lol:
Statistics: Posted by waolelaid — 17 Jul 2014, 13:52
2014-07-17T12:37:38+02:00 2014-07-17T12:37:38+02:00 https://brainmodular.org/forums/viewtopic.php?t=3968&p=30017#p30017 <![CDATA[vst version of Hollyhock?]]> Statistics: Posted by noise2sine — 17 Jul 2014, 12:37
2014-07-16T19:25:18+02:00 2014-07-16T19:25:18+02:00 https://brainmodular.org/forums/viewtopic.php?t=3968&p=30015#p30015 <![CDATA[vst version of Hollyhock?]]>
What i can tell you is that that we have a huge todo list for next months , and Rewire will be more in priority than VST version
my question is what Is "Rewire" the vst version doesn't interest me as i still understand nothing in usine both two versions
since 7 years i'm not able to build anything in usine i don't understand the explanations of the modules when i read example
"Voice Dispatcher
Dispatch Midi events to the appropriate polyphonic voice in a sub patch.
Used to create polyphonic synthesizers. See Polyphonic sub-Patches to learn more about the subject.
In a polyphonic sub-patch, the first NOTE_ON event is affected to the first voice, the second to the second voice and so on. When the maximum polyphony is reached, it restart the process from the first voice.
In other words, the oldest voice is canceled (a NOTE_OFF is sent to the output).
Settings
in
Midi input to dispatch.
out
Dispatched Midi output events
pass
Sends a 1 value when a Midi event is sent to the output.
note ON
Sends a 1 value when a NOTE_ON Midi event is sent to the output.
note OFF
Sends a 1 value when a NOTE_OFF Midi event is sent to the output.
code1 (pitch)
Pitch of the current note ON
See also"
if i follow the see also i fall on another thing as hermetic as this explanation
when will there be some examples on how to wire the principals functions of the modules ???
i wait for this since 7 years
i've never made electronic music and i really don't know anything of how it works
i don't know anybody who can help me to understand ( i don't speak of Usine especially )
but the only thing i can do is to assemble samples in a daw that's all ! i don't know MIDI
i don't understand what are CC# and all these things
Another thing will there be a version which does'nt change every month with a new GUI
for me the adaptability is not easy now
Sorry if its not the right place but i wanted to tell what i think and as i was in this post i did it
wish you a good evening and night too
Best :)
Statistics: Posted by waolelaid — 16 Jul 2014, 19:25
+1 on rewire
Cheers,
Tom
Thanks.
Cheers :lol:
"Voice Dispatcher
Settings
in
out
pass
note ON
note OFF
code1 (pitch)
See also"
Best :)
