ArrayArrayArrayArray BrainModular BrainModular Users Forum 2013-07-12T14:01:46+02:00 https://brainmodular.org/forums/app.php/feed/topic/3957 2013-07-12T14:01:46+02:00 2013-07-12T14:01:46+02:00 https://brainmodular.org/forums/viewtopic.php?t=3957&p=27191#p27191 <![CDATA[String To Integer?]]> Statistics: Posted by sephult — 12 Jul 2013, 14:01
2013-07-12T13:58:28+02:00 2013-07-12T13:58:28+02:00 https://brainmodular.org/forums/viewtopic.php?t=3957&p=27190#p27190 <![CDATA[String To Integer?]]> Confused expecting text/string output to be truly text/string...and now just realizing the value is ASCII
I started by testing the output and adjusted the output to a "What you see is what you get".....that was my error as the scripts are actually not String to Integer....they are ASCII to Integer.
Thanks I appreciate the help!
-S
Statistics: Posted by sephult — 12 Jul 2013, 13:58
2013-07-12T09:43:18+02:00 2013-07-12T09:43:18+02:00 https://brainmodular.org/forums/viewtopic.php?t=3957&p=27189#p27189 <![CDATA[String To Integer?]]> Download
Statistics: Posted by nay-seven — 12 Jul 2013, 09:43
2013-07-12T03:46:42+02:00 2013-07-12T03:46:42+02:00 https://brainmodular.org/forums/viewtopic.php?t=3957&p=27181#p27181 <![CDATA[String To Integer?]]> I setup a text field for inputting values, and trying to show the value input on a fader.
I inserted the String to Integer, String to Float, etc.... and no values seem to pass to the output.
(Subtracting the output of the text field by 48 to show the numeric value...btw)
I am thinking this will work after the fast-script gets implemented?
Or maybe I am just having issues?
-S
Statistics: Posted by sephult — 12 Jul 2013, 03:46
-S
-S
