ArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2013-06-19T18:18:14+02:00 https://brainmodular.org/forums/app.php/feed/topic/3904 2013-06-19T18:18:14+02:00 2013-06-19T18:18:14+02:00 https://brainmodular.org/forums/viewtopic.php?t=3904&p=26921#p26921 <![CDATA[Like Aux Send and Receive with Hollyhock]]>
AUX IN/OUT-2
I try to build a device with the "AUX IN.Pat" that i built (you can find it in the join workspace), but if i use it like a device it is impossible to choose a different AUX IN for each Rack ... I can only choose a général AUX IN for the Workspace ...
Is there a solution for that ?
Is it possible, in the same way, to built, an AUX device OUT with can drive the 4 AUX OUT with 4 independant Gain knob ?
So i can replace AUX OUT 1, AUX OUT 2, AUX OUT 3 and AUX OUT 4 Devices by only one AUX OUT Device.
I know i can do it in each patch. But i search a way to do it with devices because it would be easy for use it very often and in a lot of Rack.
Statistics: Posted by cmodica — 19 Jun 2013, 18:18
2013-06-19T11:58:59+02:00 2013-06-19T11:58:59+02:00 https://brainmodular.org/forums/viewtopic.php?t=3904&p=26914#p26914 <![CDATA[Like Aux Send and Receive with Hollyhock]]>
AUX In and Out Devices
It is not totaly as usefull as i need but it seems to be a simple way to built it.
Statistics: Posted by cmodica — 19 Jun 2013, 11:58
2013-06-19T11:10:22+02:00 2013-06-19T11:10:22+02:00 https://brainmodular.org/forums/viewtopic.php?t=3904&p=26913#p26913 <![CDATA[Like Aux Send and Receive with Hollyhock]]>
But i realy don't understand ... it is too complex for me. The Aux send/receive should be easy to use on any rack ... All rack could receive AUX 1 - AUX 2 -AUX 3 and AUX 4 and i play with the Aux send because all rack could send AUX 1 - AUX 2 -AUX 3 and AUX 4.
I don't understand how your workspace work, i am sorry. Prehap's i should still work with Usine ...
Statistics: Posted by cmodica — 19 Jun 2013, 11:10
2013-06-18T19:35:57+02:00 2013-06-18T19:35:57+02:00 https://brainmodular.org/forums/viewtopic.php?t=3904&p=26912#p26912 <![CDATA[Like Aux Send and Receive with Hollyhock]]>
try this file
I reckon you could also put some Aux busses inside the device module <AUX1>----<audio to usine / audio 7> so you could select aux busses with the selector.
Statistics: Posted by oli_lab — 18 Jun 2013, 19:35
2013-06-18T16:24:45+02:00 2013-06-18T16:24:45+02:00 https://brainmodular.org/forums/viewtopic.php?t=3904&p=26908#p26908 <![CDATA[Like Aux Send and Receive with Hollyhock]]>
When i improvise with Usine I send on the fly the Track 1 on Track 3, the T5 on T2 and T1, the T4 on T6 etc ...I use the Aux send and Input assignation for that. Sometimes i change the Input of a track on the fly (IN 1 change in AUX3). It is very easy to send and receive everything on everything on the fly, and built complex sound improvisation in reaction with the others performers.
But i can't find the way to reproduce that with Hollyhock ...
I imagine it would be possible by create new complex devices but i didn't find the way to start ... ?
Audio Bus ???
Any idea ?
Statistics: Posted by cmodica — 18 Jun 2013, 16:24
AUX IN/OUT-2
try this file
Audio Bus ???
Any idea ?
