ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2013-06-06T07:58:35+01:00 https://brainmodular.org/forums/app.php/feed/topic/3856 2013-06-06T07:58:35+01:00 2013-06-06T07:58:35+01:00 https://brainmodular.org/forums/viewtopic.php?t=3856&p=26702#p26702 <![CDATA[aux tracks]]> For exemple i have a pitch shift on track 1. A delay on Track 2. And a REC-Sampler on Track 3 etc ... I don't realy kwow what will be happening and how i will play with them. It depend about what the other musicians will play, and what sounds will come in my microphones ...
So i can decide for exemple to send the track-1 on track-2 and suddenly send the track 1 and 2 on track 3 for recording a sample on the fly, and send the Track-3 on track-2 etc ... there is a lot of possibility that i can use and decide on the fly. It is very easy with the Aux Send.
With Hollyhock i feel a little bit more close. I don't find the way to work with this flexibility ... Is there a way to manage something like that ?
Statistics: Posted by cmodica — 06 Jun 2013, 08:58
2013-06-05T05:00:11+01:00 2013-06-05T05:00:11+01:00 https://brainmodular.org/forums/viewtopic.php?t=3856&p=26685#p26685 <![CDATA[aux tracks]]>
I like the new mixer, but I don't need an input control, and I would like an aux send....
Statistics: Posted by woodslanding — 05 Jun 2013, 06:00
2013-06-02T00:28:25+01:00 2013-06-02T00:28:25+01:00 https://brainmodular.org/forums/viewtopic.php?t=3856&p=26641#p26641 <![CDATA[aux tracks]]> I am getting more clicks even at only 20% CPU in hollyhock. Probably there is more optimizing to be done.
Statistics: Posted by seamus — 02 Jun 2013, 01:28
2013-06-02T00:19:19+01:00 2013-06-02T00:19:19+01:00 https://brainmodular.org/forums/viewtopic.php?t=3856&p=26640#p26640 <![CDATA[aux tracks]]> Statistics: Posted by joffo78 — 02 Jun 2013, 01:19
2013-05-31T17:25:47+01:00 2013-05-31T17:25:47+01:00 https://brainmodular.org/forums/viewtopic.php?t=3856&p=26613#p26613 <![CDATA[aux tracks]]>
Statistics: Posted by joffo78 — 31 May 2013, 18:25
2013-05-31T17:19:07+01:00 2013-05-31T17:19:07+01:00 https://brainmodular.org/forums/viewtopic.php?t=3856&p=26612#p26612 <![CDATA[aux tracks]]>
Statistics: Posted by joffo78 — 31 May 2013, 18:19
2013-05-31T17:19:00+01:00 2013-05-31T17:19:00+01:00 https://brainmodular.org/forums/viewtopic.php?t=3856&p=26611#p26611 <![CDATA[aux tracks]]> Statistics: Posted by seamus — 31 May 2013, 18:19
2013-05-31T16:42:47+01:00 2013-05-31T16:42:47+01:00 https://brainmodular.org/forums/viewtopic.php?t=3856&p=26609#p26609 <![CDATA[aux tracks]]> With the rack and the devices concept you manage your routing as you want !
For example create a new device with a reverb inside.
You just have to put any rack you want on it.
You can also create a rack with your reverb routed on your hardware output an drag any rack on the input.
Statistics: Posted by joffo78 — 31 May 2013, 17:42
2013-05-31T16:35:02+01:00 2013-05-31T16:35:02+01:00 https://brainmodular.org/forums/viewtopic.php?t=3856&p=26608#p26608 <![CDATA[aux tracks]]> Statistics: Posted by seamus — 31 May 2013, 17:35
2013-05-31T16:33:05+01:00 2013-05-31T16:33:05+01:00 https://brainmodular.org/forums/viewtopic.php?t=3856&p=26607#p26607 <![CDATA[aux tracks]]> Statistics: Posted by joffo78 — 31 May 2013, 17:33
2013-05-31T15:34:43+01:00 2013-05-31T15:34:43+01:00 https://brainmodular.org/forums/viewtopic.php?t=3856&p=26600#p26600 <![CDATA[aux tracks]]> Statistics: Posted by seamus — 31 May 2013, 16:34
