ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2013-03-15T12:56:18+02:00 https://brainmodular.org/forums/app.php/feed/topic/3732 2013-03-15T12:56:18+02:00 2013-03-15T12:56:18+02:00 https://brainmodular.org/forums/viewtopic.php?t=3732&p=25675#p25675 <![CDATA[question of an idiot]]> If you do so, a popup opens which allows scrolling the values...
Statistics: Posted by percuson — 15 Mar 2013, 11:56
2013-03-15T02:48:49+02:00 2013-03-15T02:48:49+02:00 https://brainmodular.org/forums/viewtopic.php?t=3732&p=25673#p25673 <![CDATA[question of an idiot]]> i don't think to the Usine console and when there are a lot of info i can't follow them and i've problems
to interpret them it's the same for the clik on the square i've difficulties to find what i'm searching
there are huge data which scroll so i'm a little bit lost when i think to use it
i must train me to do that
thank you for all best wishes :D
Statistics: Posted by waolelaid — 15 Mar 2013, 01:48
2013-03-14T18:02:58+02:00 2013-03-14T18:02:58+02:00 https://brainmodular.org/forums/viewtopic.php?t=3732&p=25671#p25671 <![CDATA[question of an idiot]]>
And remember there's a cool way to know what's happen in a wire:
here I've add a listbox from the synchro inlet, then you click on the little square of the wire. Now, when you change item of the list you'll see the data flow incoming:
Or a second way : create a wire from the listbox and choose "trace value", this way you'll see infos in the Usine console.
Statistics: Posted by nay-seven — 14 Mar 2013, 17:02
2013-03-14T17:50:00+02:00 2013-03-14T17:50:00+02:00 https://brainmodular.org/forums/viewtopic.php?t=3732&p=25670#p25670 <![CDATA[question of an idiot]]> i spend 3 hours and didn't find how it's working i didn't know that sync have number !
if i well understand 0 is button mode ,1 is loop mode.. etc
but how to know that
i'am not sure of this deduction so if you can confirm it helps me to do the same with piano roll
as piano roll has the same kind of sync
in any case it's difficult to know all these subtilities in Usine there are too much
wish you a good evening and night too :D
@ joffo : yes you're right but you're a great patcher for you it's easy
but as i'm an old newbie and that there are a lot of matrix modules it's difficult to choose
the good module and as i said to nay i don't know the subtilities of usine
i can't find this patch by myself for exemple (excuse me if i change of post ) i like your
last addon "coolundoredo" i open it and i noticed that i'm not able to understand how
you build it
too much difficult for me really simple to use but too much complicated to build ;)
Statistics: Posted by waolelaid — 14 Mar 2013, 16:50
2013-03-14T10:35:23+02:00 2013-03-14T10:35:23+02:00 https://brainmodular.org/forums/viewtopic.php?t=3732&p=25669#p25669 <![CDATA[question of an idiot]]> i use it very often and it's the best solution to make connections between audio and data signals.
Statistics: Posted by joffo78 — 14 Mar 2013, 09:35
2013-03-14T09:23:53+02:00 2013-03-14T09:23:53+02:00 https://brainmodular.org/forums/viewtopic.php?t=3732&p=25668#p25668 <![CDATA[question of an idiot]]> matrix cells have numbers : 0,1,2...( i add a x+1 module to obtain: 1,2,3..)
In the seq sub-patch , we are in polyphonic mode , so each voice has a number too..(1,2,3...)
so when the cell 2 is ON and the module current voice is 2 too , the A=B module is ON and output 1
at this moment the synchro pass from 0 to 1 , so it pass from button to loop, so sequence play...:)
As you're now in loop mode , you can use the duration fader..
Statistics: Posted by nay-seven — 14 Mar 2013, 08:23
2013-03-14T04:47:45+02:00 2013-03-14T04:47:45+02:00 https://brainmodular.org/forums/viewtopic.php?t=3732&p=25667#p25667 <![CDATA[question of an idiot]]> to understand how it works because i've noticed that the sequencer is in button sync
and i believed that the speed of the loop works only in mode loop sync
while there i can change the speed of the loop Although it's in sync button
it remains a mystery for me hope i'll understand
In any case thank you very much
Best wishes :D
Statistics: Posted by waolelaid — 14 Mar 2013, 03:47
2013-03-13T10:44:57+02:00 2013-03-13T10:44:57+02:00 https://brainmodular.org/forums/viewtopic.php?t=3732&p=25665#p25665 <![CDATA[question of an idiot]]> Download
Statistics: Posted by nay-seven — 13 Mar 2013, 09:44
2013-03-13T05:49:31+02:00 2013-03-13T05:49:31+02:00 https://brainmodular.org/forums/viewtopic.php?t=3732&p=25664#p25664 <![CDATA[question of an idiot]]> i have always sound like if there was one which is activated how can i do to have only sound when one case is alight .
in the picture i send , the sound begin when i press one of the switches
isn't it possible to do the same with the matrix ? there , all the sequencers are always working
and it seems that the flux of the 8 sequencers is blended and i just need to heard one by one
i put the sync on loop like that i can change the speed of the loop and like that i change the sound
playing with the cutoff of the synth
i hope you understand what i want to mean it's not easy to explain but it's not very important for me
i know you have a lot of work with hollyhock and i don't want that you waste your time for futile question as this one
in quite way there's one thing i can't understand it's the script i i don't understand its function
so drop this question and it's better to go ahead on hollyhock
Best wishes ;)
Statistics: Posted by waolelaid — 13 Mar 2013, 04:49
2013-03-12T18:06:58+02:00 2013-03-12T18:06:58+02:00 https://brainmodular.org/forums/viewtopic.php?t=3732&p=25662#p25662 <![CDATA[question of an idiot]]> for the the error with the uploader i didn't understand that i must go in the uploader before
writing so when i begin to write my text when i clicked on the uploader link i don't fall on the right
page sorry that's me
i'll tell you if i understand your patch because it's my great problem i don't understand about 98%
of the modules of Usine but i persevere and a lot of time without success
good evening i hope you haven't been annoyed by the snow !
Statistics: Posted by waolelaid — 12 Mar 2013, 17:06
2013-03-12T09:56:56+02:00 2013-03-12T09:56:56+02:00 https://brainmodular.org/forums/viewtopic.php?t=3732&p=25660#p25660 <![CDATA[question of an idiot]]>
about your question, you have a patch in the browser/matrix/examples/ named matrix exclusive mode example
then you can use the polyphony to multiply your step midi
here an example, tell me if you need more explanations
DOWNLOAD
Statistics: Posted by nay-seven — 12 Mar 2013, 08:56
2013-03-12T03:08:10+02:00 2013-03-12T03:08:10+02:00 https://brainmodular.org/forums/viewtopic.php?t=3732&p=25659#p25659 <![CDATA[question of an idiot]]> i focused on the second step but didn't understand how to begin i hope its good now
it seems to work but i don't see the pictures
and now the rest of "question of an idiot
I would have liked to realize this patche with
the matrix but i didn't manage to do it i should
want that when i press one case of the matrix
it trigs one sequencer and let the others switched off
if i press case N°1 it trigs the first sequencer and when i press case N°2
it trigs the second sequencer and so ... i've tried to do
but after a long time i didn't succeed to do what i wanted to
so my question is which matrix must i use and how it works because i
understand nothing in fact is there anybody who can show me how to do
thanx in advance
I hope the pictures are visible
and good morning
Statistics: Posted by waolelaid — 12 Mar 2013, 02:08
2013-03-11T23:58:27+02:00 2013-03-11T23:58:27+02:00 https://brainmodular.org/forums/viewtopic.php?t=3732&p=25658#p25658 <![CDATA[question of an idiot]]> Statistics: Posted by nay-seven — 11 Mar 2013, 22:58
2013-03-11T23:39:50+02:00 2013-03-11T23:39:50+02:00 https://brainmodular.org/forums/viewtopic.php?t=3732&p=25657#p25657 <![CDATA[question of an idiot]]> to "upload a file" i have not access to the second step
Why ? i press the "Uploader link as described in the manual and
it is not as described in the manual and i don't get the step where there is written "upload a file"
i don't understand !!!! and i can't show you
so how can i do ????????
Statistics: Posted by waolelaid — 11 Mar 2013, 22:39
you build it
Best wishes :D
Best wishes ;)
DOWNLOAD
thanx in advance
and good morning
