ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2013-04-07T18:31:52+01:00 https://brainmodular.org/forums/app.php/feed/topic/3728 2013-04-07T18:31:52+01:00 2013-04-07T18:31:52+01:00 https://brainmodular.org/forums/viewtopic.php?t=3728&p=25834#p25834 <![CDATA[Usine Hollyhock march news]]>
Any Usine Hollyhock april news?:)
Statistics: Posted by headphoner — 07 Apr 2013, 19:31
2013-04-05T14:49:47+01:00 2013-04-05T14:49:47+01:00 https://brainmodular.org/forums/viewtopic.php?t=3728&p=25823#p25823 <![CDATA[Usine Hollyhock march news]]>
Looking forward to try it !
Thanks for your work.
Statistics: Posted by Zat0 — 05 Apr 2013, 15:49
2013-04-04T23:16:42+01:00 2013-04-04T23:16:42+01:00 https://brainmodular.org/forums/viewtopic.php?t=3728&p=25816#p25816 <![CDATA[Usine Hollyhock march news]]>
Statistics: Posted by woodslanding — 05 Apr 2013, 00:16
2013-03-28T17:32:16+01:00 2013-03-28T17:32:16+01:00 https://brainmodular.org/forums/viewtopic.php?t=3728&p=25766#p25766 <![CDATA[Usine Hollyhock march news]]>
Cheers,
Tom
Statistics: Posted by Thomas Helzle — 28 Mar 2013, 17:32
2013-03-16T15:20:11+01:00 2013-03-16T15:20:11+01:00 https://brainmodular.org/forums/viewtopic.php?t=3728&p=25686#p25686 <![CDATA[Usine Hollyhock march news]]> Statistics: Posted by ahonoe — 16 Mar 2013, 15:20
2013-03-11T21:55:22+01:00 2013-03-11T21:55:22+01:00 https://brainmodular.org/forums/viewtopic.php?t=3728&p=25656#p25656 <![CDATA[Usine Hollyhock march news]]>
Statistics: Posted by Alain Vankenhove — 11 Mar 2013, 21:55
2013-03-11T08:59:28+01:00 2013-03-11T08:59:28+01:00 https://brainmodular.org/forums/viewtopic.php?t=3728&p=25651#p25651 <![CDATA[Usine Hollyhock march news]]>
The other day I got the disk access / DSP freeze issue I haven't had since switching from XP to OSX 5 years ago.
Statistics: Posted by secretkillerofnames — 11 Mar 2013, 08:59
2013-03-11T04:40:46+01:00 2013-03-11T04:40:46+01:00 https://brainmodular.org/forums/viewtopic.php?t=3728&p=25650#p25650 <![CDATA[Usine Hollyhock march news]]> Statistics: Posted by seamus — 11 Mar 2013, 04:40
2013-03-10T20:13:28+01:00 2013-03-10T20:13:28+01:00 https://brainmodular.org/forums/viewtopic.php?t=3728&p=25649#p25649 <![CDATA[Usine Hollyhock march news]]>
andrewchi: Interesting! I was never sure what exactly is causing the problems. I use a very old LMK3 Keyboard from Doepfer which tends to send "Midi Noise" from sheer age on some controllers every now and then, which surely doesn't help the issue, but no other DAW I use ever got confused as Usine by this.
And I never found a keyboard I like better (It's the very first pre-hammer-action version).
But I think the real trouble with Usine started with Windows 8, which otherwise doesn't give me any audio related problems.
Do you find LoopMidi better than CopperLan? I recently switched from the first to the latter but haven't put it through it's paces yet.
Thanks for the ideas and inspiration!
And best of luck with the concert :-)
Cheers,
Tom
Statistics: Posted by Thomas Helzle — 10 Mar 2013, 20:13
2013-03-10T16:01:47+01:00 2013-03-10T16:01:47+01:00 https://brainmodular.org/forums/viewtopic.php?t=3728&p=25648#p25648 <![CDATA[Usine Hollyhock march news]]> Midi issues of the V5 belong to the past, the Midi engine has been totally rewritten.
Statistics: Posted by senso — 10 Mar 2013, 16:01
2013-03-10T15:42:59+01:00 2013-03-10T15:42:59+01:00 https://brainmodular.org/forums/viewtopic.php?t=3728&p=25647#p25647 <![CDATA[Usine Hollyhock march news]]>
My impatience is driven by the fact that the old Usine no longer works on my Windows 8 x64 machine. It gets confused all the time and interprets midi off as on and more such nonsense, so it's pretty much unusable.
The old/current Usine always had a buggy MIDI-implementation, it drove me near nuts in the past, but I found a workaround!
Get a solid MIDI-capable DAW (like Reaper or Cubase), install LoopMidi (freeware) and route all your hardware midi from the DAW to seperate virtual MIDI-ports from loopMIDI. Then, get Usine to recieve only the loopMIDI-channels and it should work 10 times more solid. It works for me on Win7 64bit, I only get MIDI-gibberish every now and then in Usine this way.
If you make your setup completely MIDI-remotely controlled (no on screen actions) you can even record your full set in your DAW as MIDI tracks, and play it back in different tempo's, pitch,... This way you have true event-based recordings of your sets and the possibilities for re-recording and additional production are endless! But that's just a plus!
Hope this can help you.
I also respect Senso's choices about the release-date, but I must say I'm also impatient, since I have a big release-concert end of this week and the biggest risk on stage is still my Usine standalone version...
Godspeed Senso!
Statistics: Posted by AndrewChi — 10 Mar 2013, 15:42
2013-03-10T15:25:00+01:00 2013-03-10T15:25:00+01:00 https://brainmodular.org/forums/viewtopic.php?t=3728&p=25646#p25646 <![CDATA[Usine Hollyhock march news]]> Statistics: Posted by Thomas Helzle — 10 Mar 2013, 15:25
2013-03-09T23:06:21+01:00 2013-03-09T23:06:21+01:00 https://brainmodular.org/forums/viewtopic.php?t=3728&p=25641#p25641 <![CDATA[Usine Hollyhock march news]]>
Very nice!
But I fully agree with your choices anyway ;-)
Cheers and thanks for the update!
Tom
Hey, does OSC work on win8 machine?
Statistics: Posted by r.erorr — 09 Mar 2013, 23:06
2013-03-09T21:51:17+01:00 2013-03-09T21:51:17+01:00 https://brainmodular.org/forums/viewtopic.php?t=3728&p=25640#p25640 <![CDATA[Usine Hollyhock march news]]>
Tom
Statistics: Posted by Thomas Helzle — 09 Mar 2013, 21:51
2013-03-09T19:56:26+01:00 2013-03-09T19:56:26+01:00 https://brainmodular.org/forums/viewtopic.php?t=3728&p=25639#p25639 <![CDATA[Usine Hollyhock march news]]> Statistics: Posted by 23fx23 — 09 Mar 2013, 19:56
2013-03-09T15:47:49+01:00 2013-03-09T15:47:49+01:00 https://brainmodular.org/forums/viewtopic.php?t=3728&p=25638#p25638 <![CDATA[Usine Hollyhock march news]]> and thanks for the big manual i hope it 'll be
illustrative more than the actual manual
will it be downloadable ?
i have real troubles to read on a computer
Thanx in advance
and take the time you need
Regards
Statistics: Posted by waolelaid — 09 Mar 2013, 15:47
2013-03-09T14:15:48+01:00 2013-03-09T14:15:48+01:00 https://brainmodular.org/forums/viewtopic.php?t=3728&p=25637#p25637 <![CDATA[Usine Hollyhock march news]]>
Statistics: Posted by caco — 09 Mar 2013, 14:15
2013-03-09T12:30:47+01:00 2013-03-09T12:30:47+01:00 https://brainmodular.org/forums/viewtopic.php?t=3728&p=25633#p25633 <![CDATA[Usine Hollyhock march news]]> Good work and good luck !
Statistics: Posted by daviche — 09 Mar 2013, 12:30
2013-03-08T22:46:18+01:00 2013-03-08T22:46:18+01:00 https://brainmodular.org/forums/viewtopic.php?t=3728&p=25628#p25628 <![CDATA[Usine Hollyhock march news]]> For upgraders, given the changes from the old version there's no doubt the manual will be an important piece for Hollyhock :cool:
Statistics: Posted by Floego — 08 Mar 2013, 22:46
2013-03-08T22:13:54+01:00 2013-03-08T22:13:54+01:00 https://brainmodular.org/forums/viewtopic.php?t=3728&p=25627#p25627 <![CDATA[Usine Hollyhock march news]]>
We are all impatient to discover the new version of Usine.
We are so busy that we forgot to give news. We apologize.
I know, we are late... But we prefer delayed the launching date and give you a good first beta version. It's a choice and I'm sure that you understand.
Actually we are focusing on
- the patch library
- the quick start manual
- the user manual (more than 3000 pages)
We can't announce a precise date but be sure that it will arrive very soon.
You can take a look on the following screen shot.
Senso & the Sensomusic team.
Statistics: Posted by senso — 08 Mar 2013, 22:13
Cheers,
Tom
Cheers,
Tom
Godspeed Senso!
Very nice!
Tom
Tom
Thanx in advance
Regards
- the patch library
