ArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2013-02-11T10:51:13+01:00 https://brainmodular.org/forums/app.php/feed/topic/3695 2013-02-11T10:51:13+01:00 2013-02-11T10:51:13+01:00 https://brainmodular.org/forums/viewtopic.php?t=3695&p=25383#p25383 <![CDATA[dynamic List box]]>
Statistics: Posted by noise2sine — 11 Feb 2013, 10:51
2013-02-11T10:38:51+01:00 2013-02-11T10:38:51+01:00 https://brainmodular.org/forums/viewtopic.php?t=3695&p=25382#p25382 <![CDATA[dynamic List box]]> which ensemble do you use ( if it's a public one) ?
Statistics: Posted by nay-seven — 11 Feb 2013, 10:38
2013-02-11T09:31:43+01:00 2013-02-11T09:31:43+01:00 https://brainmodular.org/forums/viewtopic.php?t=3695&p=25379#p25379 <![CDATA[dynamic List box]]>
I'm using a Reaktor instrument with your patch and it's working fine : i can create and rename a preset in reaktor and then it appears in Usine list box . If i'm clicking on names in the Usine list box i can see the preset moving in Reaktor.
The problem i'm facing now is that when i'm using the conductor, the different preset in Usine list box change but it has not effect in Reaktor !!! Like the list box doesn't transfer anything to Reaktor while using the conductor ?
What's wrong ?
Statistics: Posted by noise2sine — 11 Feb 2013, 09:31
2013-02-01T15:03:33+01:00 2013-02-01T15:03:33+01:00 https://brainmodular.org/forums/viewtopic.php?t=3695&p=25315#p25315 <![CDATA[dynamic List box]]> Statistics: Posted by noise2sine — 01 Feb 2013, 15:03
2013-01-31T14:07:22+01:00 2013-01-31T14:07:22+01:00 https://brainmodular.org/forums/viewtopic.php?t=3695&p=25314#p25314 <![CDATA[dynamic List box]]> i rename a preset in the VST, change of preset in the list box= the new name appears
Download
Statistics: Posted by nay-seven — 31 Jan 2013, 14:07
2013-01-31T13:43:17+01:00 2013-01-31T13:43:17+01:00 https://brainmodular.org/forums/viewtopic.php?t=3695&p=25313#p25313 <![CDATA[dynamic List box]]>
http://www.sensomusic.com/forums/upload ... M_VSTi.rar
Statistics: Posted by noise2sine — 31 Jan 2013, 13:43
2013-01-31T12:23:51+01:00 2013-01-31T12:23:51+01:00 https://brainmodular.org/forums/viewtopic.php?t=3695&p=25312#p25312 <![CDATA[dynamic List box]]> the has changed module must be connected to the array outlet.., maybe you don't see it with the missing VST
what is the VST you use..?
And remember the new name will appear only the next time you change of preset in the listbox ( when refresh)
Statistics: Posted by nay-seven — 31 Jan 2013, 12:23
2013-01-31T12:09:15+01:00 2013-01-31T12:09:15+01:00 https://brainmodular.org/forums/viewtopic.php?t=3695&p=25311#p25311 <![CDATA[dynamic List box]]>
Unfortunatly i couldn't make it work :(
I have used yr patch but i had to delete yr vst plug in because i don't have it. So i have replaced it with a new vsti and created a new list box.
I have right clicked on the vsti for renaming it and same for the list box.
I can see the preset names in the list box but if i'm changing a preset name, the new name won't appear in the list box.
What am i doing wrong ?
Statistics: Posted by noise2sine — 31 Jan 2013, 12:09
2013-01-31T09:26:08+01:00 2013-01-31T09:26:08+01:00 https://brainmodular.org/forums/viewtopic.php?t=3695&p=25310#p25310 <![CDATA[dynamic List box]]> once you have change a name or add a new preset the listbox will be updated ( when you change of preset)
Download
Statistics: Posted by nay-seven — 31 Jan 2013, 09:26
2013-01-31T09:03:16+01:00 2013-01-31T09:03:16+01:00 https://brainmodular.org/forums/viewtopic.php?t=3695&p=25309#p25309 <![CDATA[dynamic List box]]>
I wanted to know how i can make list box dynamic ? I'm using a vst instrument and my wish is that when i create or rename a preset with the VST instrument ,it would be autamoticly updated in the list box ?
Statistics: Posted by noise2sine — 31 Jan 2013, 09:03
What's wrong ?
Download
Download
