ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2013-01-27T13:19:16+01:00 https://brainmodular.org/forums/app.php/feed/topic/3694 2013-01-27T13:19:16+01:00 2013-01-27T13:19:16+01:00 https://brainmodular.org/forums/viewtopic.php?t=3694&p=25308#p25308 <![CDATA[How to add a midi note OFF , and set a variable for it ?]]>
I think i must delete the old demo... xD
hey man , this is working perfectly :D thank you very very much nay !
Statistics: Posted by Taysete_DJ — 27 Jan 2013, 13:19
2013-01-27T10:46:57+01:00 2013-01-27T10:46:57+01:00 https://brainmodular.org/forums/viewtopic.php?t=3694&p=25307#p25307 <![CDATA[How to add a midi note OFF , and set a variable for it ?]]> this method can't keep the old advanced counter, so I've simplify this one with only a reverse button
Download
btw, still curious to know the Usine version you use..mm
Statistics: Posted by nay-seven — 27 Jan 2013, 10:46
2013-01-27T00:23:48+01:00 2013-01-27T00:23:48+01:00 https://brainmodular.org/forums/viewtopic.php?t=3694&p=25305#p25305 <![CDATA[How to add a midi note OFF , and set a variable for it ?]]>
I have tryied changing parameters because the step limiter is set to 16 steps and i want to have a control to swap between 8 steps to 64 steps maxium..
also if i connect the step data inlet to the advanced counter , doesent respond to the main sequencer
If you can solve this last problem, my sequencer will be finished , and i will not spam you no more with so many questions :P
heehhe
Thank you very much :D im near to have this project finished
here is the .pat : download
Statistics: Posted by Taysete_DJ — 27 Jan 2013, 00:23
2013-01-26T18:20:10+01:00 2013-01-26T18:20:10+01:00 https://brainmodular.org/forums/viewtopic.php?t=3694&p=25304#p25304 <![CDATA[How to add a midi note OFF , and set a variable for it ?]]>
so you have to copy a part of the sequenaya, then use the same system with the toggle to alternate..?
Download
allrite , so then is not possible to make a loop to jump left to right .. ok then , well anyway changing between reversed and forward will be enought to do that
Thank you so so much nay , and sorry for make you work hehe
Regards
Statistics: Posted by Taysete_DJ — 26 Jan 2013, 18:20
2013-01-26T18:13:41+01:00 2013-01-26T18:13:41+01:00 https://brainmodular.org/forums/viewtopic.php?t=3694&p=25303#p25303 <![CDATA[How to add a midi note OFF , and set a variable for it ?]]> Download
Statistics: Posted by nay-seven — 26 Jan 2013, 18:13
2013-01-26T17:43:32+01:00 2013-01-26T17:43:32+01:00 https://brainmodular.org/forums/viewtopic.php?t=3694&p=25302#p25302 <![CDATA[How to add a midi note OFF , and set a variable for it ?]]>
No reverse function but you play with array
here a forward.reverse version, when OFF you can use 3 modes , roll need you move the knob
Download
oh well that makes a similiar function , but i dont mean this , sorry maybe i explained bad,
I mean the bar of the sequence , i want to do like in sequenaya some direction buttons for the main sequence process
In sequenaya goes to right and left , my sequencer just goes to left
i want to make 3 modes if possible
From left to right (Normal mode)
From right to left (Reversed)
Left to right and right to left (Loop mode) Like in Blip 1000 and 2000 VSt ( in this mode is like to duplicate the size of the sequence)
Like you see here :
Statistics: Posted by Taysete_DJ — 26 Jan 2013, 17:43
2013-01-26T17:27:00+01:00 2013-01-26T17:27:00+01:00 https://brainmodular.org/forums/viewtopic.php?t=3694&p=25301#p25301 <![CDATA[How to add a midi note OFF , and set a variable for it ?]]>
Download
thank you again :D you are the faster answering
Statistics: Posted by Taysete_DJ — 26 Jan 2013, 17:27
2013-01-26T17:22:36+01:00 2013-01-26T17:22:36+01:00 https://brainmodular.org/forums/viewtopic.php?t=3694&p=25300#p25300 <![CDATA[How to add a midi note OFF , and set a variable for it ?]]> here a forward.reverse version, when OFF you can use 3 modes , roll need you move the knob
Download
Statistics: Posted by nay-seven — 26 Jan 2013, 17:22
2013-01-26T16:30:01+01:00 2013-01-26T16:30:01+01:00 https://brainmodular.org/forums/viewtopic.php?t=3694&p=25299#p25299 <![CDATA[How to add a midi note OFF , and set a variable for it ?]]>
i want to make reversed direction and if is possible backward+forward loop
By the way the sequencer is looking good
Thank you for all the help :D and yea usine is addicting
Statistics: Posted by Taysete_DJ — 26 Jan 2013, 16:30
2013-01-26T14:44:57+01:00 2013-01-26T14:44:57+01:00 https://brainmodular.org/forums/viewtopic.php?t=3694&p=25298#p25298 <![CDATA[How to add a midi note OFF , and set a variable for it ?]]>
here an example , i suppose pression=velocity..?
Download
OH yes , thats it , works perfect thank you so much nay!
Regards
Statistics: Posted by Taysete_DJ — 26 Jan 2013, 14:44
2013-01-26T14:18:53+01:00 2013-01-26T14:18:53+01:00 https://brainmodular.org/forums/viewtopic.php?t=3694&p=25297#p25297 <![CDATA[How to add a midi note OFF , and set a variable for it ?]]> pression=velocity..?
Download
Statistics: Posted by nay-seven — 26 Jan 2013, 14:18
2013-01-26T13:26:45+01:00 2013-01-26T13:26:45+01:00 https://brainmodular.org/forums/viewtopic.php?t=3694&p=25296#p25296 <![CDATA[How to add a midi note OFF , and set a variable for it ?]]>
I have a problem with some panels and workspaces , i want to make a midi sequencer , im going good ...
but the problem is , when i send the midi notes , it just send NOTE ON messages , i have triyed many modules and all are more or less the same , SO when i send the midi it just send all notes with a continue pression , i want to make a fader or something to controll the note pression ; (see the problem in the image)
Here im just testing with lazysnake sequencer to have a example , im building a sequencer learning from this sequencer , but the main problem is to add a specific note pression ...
If its possible to make it in a fader that would be cool
Statistics: Posted by Taysete_DJ — 26 Jan 2013, 13:26
Download
heehhe
Download
Regards
Download
Like you see here :
Download
Download
Download
Regards
Download
