ArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2013-01-01T00:51:58+01:00 https://brainmodular.org/forums/app.php/feed/topic/3665 2013-01-01T00:51:58+01:00 2013-01-01T00:51:58+01:00 https://brainmodular.org/forums/viewtopic.php?t=3665&p=25144#p25144 <![CDATA[kind of a pitch shifter]]> work well :D
Statistics: Posted by waolelaid — 01 Jan 2013, 00:51
2012-12-31T04:08:33+01:00 2012-12-31T04:08:33+01:00 https://brainmodular.org/forums/viewtopic.php?t=3665&p=25142#p25142 <![CDATA[kind of a pitch shifter]]> It's a bit cleaned up and simplified.
Have fun!
Download here: pitch shift delay
Statistics: Posted by percuson — 31 Dec 2012, 04:08
2012-12-21T21:19:05+01:00 2012-12-21T21:19:05+01:00 https://brainmodular.org/forums/viewtopic.php?t=3665&p=25125#p25125 <![CDATA[kind of a pitch shifter]]> i looked into the subpatch really clever learning a lot
congrat :D
Statistics: Posted by waolelaid — 21 Dec 2012, 21:19
2012-12-21T19:50:03+01:00 2012-12-21T19:50:03+01:00 https://brainmodular.org/forums/viewtopic.php?t=3665&p=25124#p25124 <![CDATA[kind of a pitch shifter]]> !
Check it out. I tried to make it the most simple way... It should be no problem to get how it works.
It took some time to find out which ramp type is needed (down for tronsposing up and up for transposing down) and how to calculate the pitch. Have a look at control sub-patch to see how I did it.
The pitch delay sub-patch is the heart of the patch. Don't wonder abaout the ramp in the main patch. It is only there, because I had some trouble synchronizing both delays without any noise. It only gives the start signal for the ramps inside the sub-patch.
If you have questions, don't hesitate to ask.
Statistics: Posted by percuson — 21 Dec 2012, 19:50
2012-12-21T18:16:43+01:00 2012-12-21T18:16:43+01:00 https://brainmodular.org/forums/viewtopic.php?t=3665&p=25123#p25123 <![CDATA[kind of a pitch shifter]]> thank to share
Statistics: Posted by joffo78 — 21 Dec 2012, 18:16
2012-12-21T15:28:12+01:00 2012-12-21T15:28:12+01:00 https://brainmodular.org/forums/viewtopic.php?t=3665&p=25121#p25121 <![CDATA[kind of a pitch shifter]]> pitch shifting in Max
I tried to rebuild this in usine...
download:pitch shift delay
I also added a feedback, which results in strange sound effects.
The tempo sync button is not really a tempo sync. It only sets the delay time to the selected time period. But it helps to get something like a sync.
It's not finished yet, but maybe you can test it and give me some feedback.
Merry Christmas!!!
Statistics: Posted by percuson — 21 Dec 2012, 15:28
Have fun!
congrat :D
Merry Christmas!!!
