]]>2012-12-14T18:22:56+01:002012-12-14T18:22:56+01:00https://brainmodular.org/forums/viewtopic.php?t=3657&p=25082#p25082Statistics: Posted by nay-seven — 14 Dec 2012, 18:22
Published a new version. Think we should move to the SDK area, it's a better place for discussion about technical details. Posted there a invitation to join the test
Statistics: Posted by hesspet — 14 Dec 2012, 16:52
]]>2012-12-13T21:59:05+01:002012-12-13T21:59:05+01:00https://brainmodular.org/forums/viewtopic.php?t=3657&p=25068#p25068Statistics: Posted by nay-seven — 13 Dec 2012, 21:59
]]>2012-12-13T21:33:49+01:002012-12-13T21:33:49+01:00https://brainmodular.org/forums/viewtopic.php?t=3657&p=25067#p25067 see: http://sensomusic.com/wiki/doku.php?id= ... ers:serial
I started to publish some examples how to use the serial module. In the example section you'll find the Arduino source and in the module package the corresponding patch.
Peter
Statistics: Posted by hesspet — 13 Dec 2012, 21:33
]]>2012-12-12T22:21:23+01:002012-12-12T22:21:23+01:00https://brainmodular.org/forums/viewtopic.php?t=3657&p=25059#p25059 The Firmata stack you can find unter File->Examples->Firmata use the "Standard Firmata". That's all you need. Baudrate 57600! That's im portant to know. I will add this description to the module description. But this needs a lot of time Xmas is calling....
I'll make some additional patches and testscripts in the next weeks. What do you think? Should I transfer the source to Github or to an other repository? Maybe when it is finished it can be added to the next Usine version. The code is build with "STL" and "boost", so it should be possible to compile it on a Mac also (I've no access to Mac, so I can't compile it).
Statistics: Posted by hesspet — 12 Dec 2012, 22:21
]]>2012-12-12T19:02:32+01:002012-12-12T19:02:32+01:00https://brainmodular.org/forums/viewtopic.php?t=3657&p=25053#p25053 Do you plan to share your arduino test program..?
Statistics: Posted by nay-seven — 12 Dec 2012, 19:02
]]>2012-12-12T18:31:54+01:002012-12-12T18:31:54+01:00https://brainmodular.org/forums/viewtopic.php?t=3657&p=25052#p25052now your link for the wiki page don't work.. here an example:
CODE:
<i>Have a look at the wiki page <a href="http://www.sensomusic.com/wiki/doku.php?id=manual:modules:users:serial">here</a> to learn more and how to use it...</i>
Statistics: Posted by nay-seven — 12 Dec 2012, 18:31
]]>2012-12-12T17:03:37+01:002012-12-12T17:03:37+01:00https://brainmodular.org/forums/viewtopic.php?t=3657&p=25049#p25049 was my fault. I used a wrong image format (jng) instead of (jpg).
Peter
Statistics: Posted by hesspet — 12 Dec 2012, 17:03
]]>2012-12-12T16:40:43+01:002012-12-12T16:40:43+01:00https://brainmodular.org/forums/viewtopic.php?t=3657&p=25048#p25048 where do you want upload a picture..?
Statistics: Posted by nay-seven — 12 Dec 2012, 16:40
think you must wait some days, the input channel works, but needs a little bit better buffering logic and a array out to handle "non string data"
I'll tried to post the first version to the modules section, but I can't upload a picture.
Peter
Statistics: Posted by hesspet — 12 Dec 2012, 16:26
]]>2012-12-12T16:06:51+01:002012-12-12T16:06:51+01:00https://brainmodular.org/forums/viewtopic.php?t=3657&p=25046#p25046I'm really curious to see what's happen when i'll connect my arduinome...
Statistics: Posted by nay-seven — 12 Dec 2012, 16:06
]]>2012-12-14T16:52:30+01:002012-12-14T16:52:30+01:00https://brainmodular.org/forums/viewtopic.php?t=3657&p=25080#p25080
Peter
CODE:
Peter
Peter
