ArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2012-12-12T23:14:34+01:00https://brainmodular.org/forums/app.php/feed/topic/36562012-12-12T23:14:34+01:002012-12-12T23:14:34+01:00https://brainmodular.org/forums/viewtopic.php?t=3656&p=25061#p25061Join the party. First public beta is in the add-ons storage.
Statistics: Posted by hesspet — 12 Dec 2012, 23:14
]]>2012-12-12T23:03:44+01:002012-12-12T23:03:44+01:00https://brainmodular.org/forums/viewtopic.php?t=3656&p=25060#p25060 think i will soon dive into arduino world.
]]>2012-12-11T11:09:47+01:002012-12-11T11:09:47+01:00https://brainmodular.org/forums/viewtopic.php?t=3656&p=25037#p25037 I will post the module soon as possible. The current version has some smal bugs in high pressure situations, but it works under nomal conditions. I'll try to implement a little bit of the Firmata protocol, so the Arduino guys will have a lot of fun with it.
To solve the array buffering part, I decided to write my own CreateArray Module in C++ to get the maximum performance
Peter
Statistics: Posted by hesspet — 11 Dec 2012, 11:09
]]>2012-12-11T00:27:19+01:002012-12-11T00:27:19+01:00https://brainmodular.org/forums/viewtopic.php?t=3656&p=25035#p25035 ) btwn this serial arduino thing looks so sexy!!
]]>2012-12-10T23:00:04+01:002012-12-10T23:00:04+01:00https://brainmodular.org/forums/viewtopic.php?t=3656&p=25033#p25033 Thanks, I'll try it. I never used this modules before. For the first time I found an other solution which gives also a good result:
(The green chain gang )
Maybe not the best way, but it works
Statistics: Posted by hesspet — 10 Dec 2012, 23:00
]]>2012-12-10T22:31:35+01:002012-12-10T22:31:35+01:00https://brainmodular.org/forums/viewtopic.php?t=3656&p=25032#p25032Statistics: Posted by bsork — 10 Dec 2012, 22:31
2012-12-10T22:19:47+01:002012-12-10T22:19:47+01:00https://brainmodular.org/forums/viewtopic.php?t=3656&p=25030#p25030 maybe it still exists, but I've tomatos on my eyes.
I need a sort of a module like the "midi create" for arrays or a way how to retrigger the sending of an array. The array editor send everytime when I change a value a new array but I need a "first fill and send on demand" logic to have atomar change on all fields at the same time.
Is there's a way to do this with a patch or should I write a script (I know how to do this) but I would like to do this with the modules (and learn something)
To understand the usage:
I'm testing a new born Serial module and I like to implement a protocol which must send 3 bytes. It makes no sense to send the bytes one after an other, cause this underruns the idea of a Serial send buffer and needs 3 times more cpu load than sending a array with a "record". Works perfect with the array editor but I can't manage the retrigger technic.
You know ....tomatos...
Thanks, Peter
Statistics: Posted by hesspet — 10 Dec 2012, 22:19
]]>BrainModularBrainModular Users Forum2012-12-12T23:14:34+01:00https://brainmodular.org/forums/app.php/feed/topic/36562012-12-12T23:14:34+01:002012-12-12T23:14:34+01:00https://brainmodular.org/forums/viewtopic.php?t=3656&p=25061#p25061Join the party. First public beta is in the add-ons storage.
Peter
]]>2012-12-10T22:19:47+01:002012-12-10T22:19:47+01:00https://brainmodular.org/forums/viewtopic.php?t=3656&p=25030#p25030 maybe it still exists, but I've tomatos on my eyes.
Thanks, Peter
