ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2012-12-14T12:07:59+01:00https://brainmodular.org/forums/app.php/feed/topic/36502012-12-14T12:07:59+01:002012-12-14T12:07:59+01:00https://brainmodular.org/forums/viewtopic.php?t=3650&p=25071#p25071Statistics: Posted by percuson — 14 Dec 2012, 12:07
2012-12-14T11:51:25+01:002012-12-14T11:51:25+01:00https://brainmodular.org/forums/viewtopic.php?t=3650&p=25070#p25070Statistics: Posted by GDLive — 14 Dec 2012, 11:51
]]>2012-12-13T16:51:03+01:002012-12-13T16:51:03+01:00https://brainmodular.org/forums/viewtopic.php?t=3650&p=25066#p25066I think there are 2 options. 1st (what joffo did): play the slice to the end and leave silence between, or 2nd: play the origional sample until the next slice is triggerd. maybe a 3 one: repeat the till the next trigger (I think this would work not really good, since it would result in some nonrhythmical stuff). For 1st and 2nd option: It depends, what you want. I think, its Joffos addon and he dicided to do it the first way...
@ Joffo: You use the "peak follower and threshold" patch to detect the peaks. This works quite well with rhythmical stuff like drum beats. When testing it with more melodical samples it doesn't detect the "beats" (I mean the different tones in a melody) correctly. I was working on a peak follower not only with a threshold, but also with an analyse of the waveform to detect even little peaks. But it doesn't work well. It sets the peaks a bit to late. I'll try to improve that, so also melodical things could be seperated in slices. Also soundfiles with crescendo and decrescendo. Even though this kind of detection also only works with sounds with an attack in the beginning. Swelling sounds won't work I'll have a look at this. It could also be usefull for others.
Statistics: Posted by percuson — 13 Dec 2012, 16:51
]]>2012-12-12T21:01:51+01:002012-12-12T21:01:51+01:00https://brainmodular.org/forums/viewtopic.php?t=3650&p=25058#p25058Maybe it could also help to understand when cracks occur
]]>2012-12-12T20:58:45+01:002012-12-12T20:58:45+01:00https://brainmodular.org/forums/viewtopic.php?t=3650&p=25057#p25057 I'm asking myself what append if the step duration is shorter than the interval between the two markers, may be we should add a test on that ?
nb : I haven't uSine here to test the last patch version, I'll try ... this we
]]>2012-12-12T20:06:19+01:002012-12-12T20:06:19+01:00https://brainmodular.org/forums/viewtopic.php?t=3650&p=25056#p25056 I tested it for a while an its really great work!!
@gdlive:
I tested your version too and also your subpatch you made a good working approach! When testing it out, I found that it would be better to seperate attack and release, since I recognized more crackles on the end of each slice. I tried to set different values and integrated a range fader in your patch for doing that. So you can get a hard attack and a long fade e.g.. (I tried this with a Vibraphone loop which has a very long sustain) Check it out, if you want: http://www.sensomusic.com/forums/upload ... lume-1.pat
Statistics: Posted by percuson — 12 Dec 2012, 20:06
]]>2012-12-12T15:39:08+01:002012-12-12T15:39:08+01:00https://brainmodular.org/forums/viewtopic.php?t=3650&p=25045#p25045http://www.sensomusic.com/downloadaddon.php?file=Len%202%20Pitched%20Len.pat, with could be useful for other
]]>2012-12-12T15:28:51+01:002012-12-12T15:28:51+01:00https://brainmodular.org/forums/viewtopic.php?t=3650&p=25044#p25044 I propose a updated version, with an ASR declenched and calculated for each step and taking in account pitch to avoid clics (when len pitched sample < len step). I spent time to retreive a formula to calculate pitched len, but it seem's ok now. :rolleyes:
No sure what he could detect as beat with a monophonic instrument like clarinet
i think it works
Statistics: Posted by joffo78 — 09 Dec 2012, 23:16
]]>2012-12-09T12:09:27+01:002012-12-09T12:09:27+01:00https://brainmodular.org/forums/viewtopic.php?t=3650&p=25005#p25005No sure what he could detect as beat with a monophonic instrument like clarinet, but I will try
]]>2012-12-07T22:08:18+01:002012-12-07T22:08:18+01:00https://brainmodular.org/forums/viewtopic.php?t=3650&p=24992#p24992you want with 4 second of record really clever thanx to share
Statistics: Posted by waolelaid — 07 Dec 2012, 22:08
]]>2012-12-06T11:04:53+01:002012-12-06T11:04:53+01:00https://brainmodular.org/forums/viewtopic.php?t=3650&p=24958#p24958i've some clicks if i use the pitch option time to time ( no drums recording) but you approach your goal a little more each time !
Statistics: Posted by nay-seven — 06 Dec 2012, 11:04
Statistics: Posted by Clearscreen — 06 Dec 2012, 01:38
]]>2012-12-06T00:34:30+01:002012-12-06T00:34:30+01:00https://brainmodular.org/forums/viewtopic.php?t=3650&p=24947#p24947I think my news will a little bit eclipsed by new usine annoucement. but i'd upload a very fun addons : real time slicer This is a real time slicer inspired by sergio slicer. With it you can rec audio from input card or sampler. it makes detection of beats during the recording. when you finished it instantanly make a beat with slices. you can generate a random pattern, modify pitch reverse and multiply or divide the tempo. Enjoy and give me your impressions ! Joffo
Statistics: Posted by joffo78 — 06 Dec 2012, 00:34
]]>BrainModularBrainModular Users Forum2012-12-14T12:07:59+01:00https://brainmodular.org/forums/app.php/feed/topic/36502012-12-14T12:07:59+01:002012-12-14T12:07:59+01:00https://brainmodular.org/forums/viewtopic.php?t=3650&p=25071#p25071Statistics: Posted by percuson — 14 Dec 2012, 12:07
]]>2012-12-14T11:51:25+01:002012-12-14T11:51:25+01:00https://brainmodular.org/forums/viewtopic.php?t=3650&p=25070#p25070Statistics: Posted by GDLive — 14 Dec 2012, 11:51
@gdlive:
i think it works
