ArrayArrayArrayArray BrainModular BrainModular Users Forum 2012-10-23T08:28:26+01:00 https://brainmodular.org/forums/app.php/feed/topic/3616 2012-10-23T08:28:26+01:00 2012-10-23T08:28:26+01:00 https://brainmodular.org/forums/viewtopic.php?t=3616&p=24612#p24612 <![CDATA[enabling 1 vst while disabling all others...]]>
i use track 1 as source :
Edit the list box as
VST 1 =1
VST 2 =2
VST 3 =3
Statistics: Posted by nay-seven — 23 Oct 2012, 09:28
2012-10-23T08:18:23+01:00 2012-10-23T08:18:23+01:00 https://brainmodular.org/forums/viewtopic.php?t=3616&p=24611#p24611 <![CDATA[enabling 1 vst while disabling all others...]]>
edit: I suppose it would make more sense to not enable the "at least one" function on the group switches so that all FX can be off at some time.
Statistics: Posted by gurulogic — 23 Oct 2012, 09:18
2012-10-23T07:10:38+01:00 2012-10-23T07:10:38+01:00 https://brainmodular.org/forums/viewtopic.php?t=3616&p=24610#p24610 <![CDATA[enabling 1 vst while disabling all others...]]> 3 vst
i use 3 vst so you'll have to replace there.
Statistics: Posted by joffo78 — 23 Oct 2012, 08:10
2012-10-23T05:12:36+01:00 2012-10-23T05:12:36+01:00 https://brainmodular.org/forums/viewtopic.php?t=3616&p=24609#p24609 <![CDATA[enabling 1 vst while disabling all others...]]> let's say I have 3 vsts loaded and I want to use only one at a time and disable all others, at the push of a single button on my midi controller.
here's how it would work:
I have 3 buttons assigned, when i push the first, I want only the 1st plugin to be enabled while the 2 others are being disabled
when I push the 2nd button, I want the 2nd plugin to be enabled while the 2 others are disabled... so on so forth...
I'm trying to figure it out right now... your input will be appreciated!
Statistics: Posted by Bovo — 23 Oct 2012, 06:12
VST 1 =1
VST 2 =2
VST 3 =3
