ArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2012-10-25T02:41:03+02:00https://brainmodular.org/forums/app.php/feed/topic/36132012-10-25T02:41:03+02:002012-10-25T02:41:03+02:00https://brainmodular.org/forums/viewtopic.php?t=3613&p=24632#p24632 I ended up taking on init out because it wasn't working. I used on activation, which works, but then it toggles fullscreen every time I save the wkp.
For now, I have a button for fullscreen that I will just have to press every time I startup.
-e
Statistics: Posted by woodslanding — 25 Oct 2012, 02:41
]]>2012-10-25T00:05:59+02:002012-10-25T00:05:59+02:00https://brainmodular.org/forums/viewtopic.php?t=3613&p=24631#p24631Statistics: Posted by nay-seven — 25 Oct 2012, 00:05
2012-10-24T23:02:36+02:002012-10-24T23:02:36+02:00https://brainmodular.org/forums/viewtopic.php?t=3613&p=24630#p24630 Is there a way to tell a module to hold a value until the wkp is finished opening? I guess I could put a data delay in, but the startup time doesn't seem to be all that consistent.
Alternatively, is there any way to query usine for the state of fullscreen mode?
Statistics: Posted by woodslanding — 24 Oct 2012, 23:02
]]>2012-10-24T21:13:41+02:002012-10-24T21:13:41+02:00https://brainmodular.org/forums/viewtopic.php?t=3613&p=24629#p24629 I tried to modify it, and ran into the problem that regardless of what value you send out the midi, it toggles fullscreen state. Even when set to ABSOLUTE in the global MIDI list. The secret is to turn it on on startup, and don't let anything else change it.
Thanks and sorry to bug you twice about this
Statistics: Posted by woodslanding — 24 Oct 2012, 21:13
My layout is very precise, and if any scrolling occurs, all the controls (about 300) are moved slightly relative to each other (I have everything at grid 4) and I have to lay them all out again. This can happen anytime I'm not in fullscreen mode, so I'd like to make that impossible.
thanks! -eric
Statistics: Posted by woodslanding — 21 Oct 2012, 22:23
]]>BrainModularBrainModular Users Forum2012-10-25T02:41:03+02:00https://brainmodular.org/forums/app.php/feed/topic/36132012-10-25T02:41:03+02:002012-10-25T02:41:03+02:00https://brainmodular.org/forums/viewtopic.php?t=3613&p=24632#p24632 I ended up taking on init out because it wasn't working. I used on activation, which works, but then it toggles fullscreen every time I save the wkp.
-e
]]>2012-10-24T23:02:36+02:002012-10-24T23:02:36+02:00https://brainmodular.org/forums/viewtopic.php?t=3613&p=24630#p24630 Is there a way to tell a module to hold a value until the wkp is finished opening? I guess I could put a data delay in, but the startup time doesn't seem to be all that consistent.
thanks! -eric
