]]>2013-03-06T09:56:58+01:002013-03-06T09:56:58+01:00https://brainmodular.org/forums/viewtopic.php?t=3610&p=25600#p25600Statistics: Posted by percuson — 06 Mar 2013, 09:56
]]>2013-03-06T08:43:50+01:002013-03-06T08:43:50+01:00https://brainmodular.org/forums/viewtopic.php?t=3610&p=25599#p25599Statistics: Posted by seamus — 06 Mar 2013, 08:43
]]>2013-03-05T20:14:08+01:002013-03-05T20:14:08+01:00https://brainmodular.org/forums/viewtopic.php?t=3610&p=25598#p25598Statistics: Posted by seamus — 05 Mar 2013, 20:14
]]>2013-03-05T12:40:35+01:002013-03-05T12:40:35+01:00https://brainmodular.org/forums/viewtopic.php?t=3610&p=25596#p25596I totally forgot that there is an option for doing that at the top of the patch window .
I think your patch should work now. I cannot check this out, because I couldn't get the errors happen on my computer. So seamus has to do the test.
Statistics: Posted by percuson — 05 Mar 2013, 12:40
]]>2013-03-05T00:46:23+01:002013-03-05T00:46:23+01:00https://brainmodular.org/forums/viewtopic.php?t=3610&p=25586#p25586it 'looks' like is working now but im note sure, maybe give a try: http://sensomusic.com/forums/uploads.ph ... r%2002.wkp
]]>2013-03-05T00:24:05+01:002013-03-05T00:24:05+01:00https://brainmodular.org/forums/viewtopic.php?t=3610&p=25585#p25585 try with enabling it on each patch, and also click each list box and text field and clic 'edit layout' and enable both swichs 'not stored in preset ' and ' not saved in conductor', this may solve the problem maybe.. gonna try to check more deeply
]]>2013-03-05T00:10:30+01:002013-03-05T00:10:30+01:00https://brainmodular.org/forums/viewtopic.php?t=3610&p=25584#p25584mmm wait ... now i remember.. indeed it has later benn changed and items such list box got this swich in the edit layout now, maybe this was later than when i uploaded it.. man has to check it is unchecked too maybe this would fix the pb, cause teorically if booth are unchecked there won't be any recall. (i must admit i don't got usine on the computer, made a fresh install recently and was very busy, i ll try to check tomorrow)
]]>2013-03-05T00:06:59+01:002013-03-05T00:06:59+01:00https://brainmodular.org/forums/viewtopic.php?t=3610&p=25583#p25583Statistics: Posted by seamus — 05 Mar 2013, 00:06
]]>2013-03-04T12:48:34+01:002013-03-04T12:48:34+01:00https://brainmodular.org/forums/viewtopic.php?t=3610&p=25581#p25581This could have been the cause for mixing up between tracks. When enabled, Usine produces strange things. I found this hint on the IML wiki site nearly at the top. About the setdont I'm not really shure in your script. I fixed my problems when building the hardwired version with it. It also changes preset saving. I enabled this only to eliminate all possible errors. Since your script has no outputs, the chance is high, that it is not necesary.
What do you mean with the "the patch itself got 'don't store to preset ' activeted normally"? Did you mean the list box?
Statistics: Posted by percuson — 04 Mar 2013, 12:48
]]>2013-03-04T11:31:11+01:002013-03-04T11:31:11+01:00https://brainmodular.org/forums/viewtopic.php?t=3610&p=25579#p25579Statistics: Posted by 23fx23 — 04 Mar 2013, 11:31
]]>2013-03-04T06:30:53+01:002013-03-04T06:30:53+01:00https://brainmodular.org/forums/viewtopic.php?t=3610&p=25574#p25574 Try it out please: download
I set "SetFastCallBack - false" for all inputs and I set the "setdontsave" command for the text inputs. I'm annoyed that I didn't take a closer look at the script earlier.... This should really solve the problems. If not... I finished my hardwired version before finding the errors and could share it.
Statistics: Posted by percuson — 04 Mar 2013, 06:30
]]>2013-03-03T21:39:23+01:002013-03-03T21:39:23+01:00https://brainmodular.org/forums/viewtopic.php?t=3610&p=25571#p25571That's really a shame there isn't a simple solution. I guess it's best to just stick to the simple senso 16 presets.
]]>2013-03-03T16:26:51+01:002013-03-03T16:26:51+01:00https://brainmodular.org/forums/viewtopic.php?t=3610&p=25570#p25570iml causes the problem, and maybe sertting it via wire would solve the problem, but indeed it makes a huge array and is quite cpu violent..not ideal mmmmm
]]>2013-03-03T08:47:58+01:002013-03-03T08:47:58+01:00https://brainmodular.org/forums/viewtopic.php?t=3610&p=25569#p25569Statistics: Posted by seamus — 03 Mar 2013, 08:47
]]>2013-03-03T05:51:49+01:002013-03-03T05:51:49+01:00https://brainmodular.org/forums/viewtopic.php?t=3610&p=25568#p25568The script is saved in the preset and it is recalled at older preset values, so the names switch to recent values. I'll try to build a simple demo to show the effect. But this doesn't explain the mixup between the patches. Maybe this is called by copy and paste. The solution would be, to set the names by patch and not by script. The prob is, that to create comma text, you need a script.....
Statistics: Posted by percuson — 03 Mar 2013, 05:51
]]>2013-03-03T03:13:06+01:002013-03-03T03:13:06+01:00https://brainmodular.org/forums/viewtopic.php?t=3610&p=25567#p25567Statistics: Posted by seamus — 03 Mar 2013, 03:13
]]>2013-03-03T03:11:30+01:002013-03-03T03:11:30+01:00https://brainmodular.org/forums/viewtopic.php?t=3610&p=25566#p25566Statistics: Posted by seamus — 03 Mar 2013, 03:11
]]>2013-03-02T04:34:36+01:002013-03-02T04:34:36+01:00https://brainmodular.org/forums/viewtopic.php?t=3610&p=25565#p25565 But I have a totally different idea....
@Seamus: Did you check already, if only the names get confused, or if also the settings of faders, etc... mix up?
Statistics: Posted by percuson — 02 Mar 2013, 04:34
]]>2013-03-01T17:31:26+01:002013-03-01T17:31:26+01:00https://brainmodular.org/forums/viewtopic.php?t=3610&p=25564#p25564Statistics: Posted by 23fx23 — 01 Mar 2013, 17:31
]]>2013-03-01T11:25:08+01:002013-03-01T11:25:08+01:00https://brainmodular.org/forums/viewtopic.php?t=3610&p=25563#p25563Increasing the level for higher nb values isn't possible, I think... Hm.... no solution at this time. If I could reproduce the error, it would be much easier.
Statistics: Posted by percuson — 01 Mar 2013, 11:25
]]>2013-03-01T09:03:01+01:002013-03-01T09:03:01+01:00https://brainmodular.org/forums/viewtopic.php?t=3610&p=25561#p25561So the question is can I run a full setup of several synths with bus audio and bus midi with a setting of nb1? Or better yet is there a way to make these presets behave in higher nb values? It seems like I am limited to a certain number of tracks with a NB setting of only one.
