ArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2007-04-28T01:33:55+01:00 https://brainmodular.org/forums/app.php/feed/topic/361 2007-04-28T01:33:55+01:00 2007-04-28T01:33:55+01:00 https://brainmodular.org/forums/viewtopic.php?t=361&p=1815#p1815 <![CDATA[This May be Basic Questions]]>
Working on the PunchInLoops, replaced the midi/vsti on track 5 with the Echoplexx, works fine but CPU overload sometimes !
Now I'm trying to make a force tempo in the PunchInSampler.
Statistics: Posted by grego mondo — 28 Apr 2007, 02:33
2007-04-27T22:06:37+01:00 2007-04-27T22:06:37+01:00 https://brainmodular.org/forums/viewtopic.php?t=361&p=1814#p1814 <![CDATA[This May be Basic Questions]]> Statistics: Posted by grego mondo — 27 Apr 2007, 23:06
2007-04-27T20:03:38+01:00 2007-04-27T20:03:38+01:00 https://brainmodular.org/forums/viewtopic.php?t=361&p=1812#p1812 <![CDATA[This May be Basic Questions]]>
Why don't you use more tracks? Of course they are stereo, but you can use any Input you want and only One Audio In. I think that with one audio in, you'll have anyway to put the L and the R, as it seems to me that Usine automatically sets the first to L and the second to R.
What do you mean by Theremin? Do you have one? I mean, a real one Theremin?
Statistics: Posted by Guest — 27 Apr 2007, 21:03
2007-04-27T19:34:01+01:00 2007-04-27T19:34:01+01:00 https://brainmodular.org/forums/viewtopic.php?t=361&p=1810#p1810 <![CDATA[This May be Basic Questions]]> Can't understand outlet 3,4,5 and 6 on the "additional input" module.
I had to use 3 "add input" to achieve my 8 inputs. Is it normal ? what have I missed ?
Statistics: Posted by grego mondo — 27 Apr 2007, 20:34
2007-04-27T19:10:58+01:00 2007-04-27T19:10:58+01:00 https://brainmodular.org/forums/viewtopic.php?t=361&p=1809#p1809 <![CDATA[This May be Basic Questions]]>
Just having some time to build my Usine-set and I have a few questions :
- I have a Presonus FirePod (8 mic preamps) and several mono instruments. I look for the easiest way of switch between my inputs (Piezo, Tuba, Theremin and others things) to send them to my Usine patch. By default, Usine set my input as :
Input 1 = in1L-FirePod input1, in1R-Firepod input2 / Input 2 = in2L-FirePod input3, in2R-Firepod input4 / etc.
but I'd like mono inputs.
Should I just set it like :
Input 1 = in1L-FirePod input1, in1R-Firepod input1 / Input 2 = in2L-FirePod input2, in2R-Firepod input2 / etc.
In fact, I tried and it seems to work, but you may have already experienced it and may know if that cause any problem of latency, (audio)phase or CPU ?
Trying to build an audio input selector in my first track and setting all other tracks input on "track1"
Statistics: Posted by grego mondo — 27 Apr 2007, 20:10
