ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2012-10-19T13:21:29+01:00https://brainmodular.org/forums/app.php/feed/topic/36052012-10-19T13:21:29+01:002012-10-19T13:21:29+01:00https://brainmodular.org/forums/viewtopic.php?t=3605&p=24593#p24593what is even more strange is that if man put an array display or set it work correctly, but not with a simple array out.. I see no reason why it would behave like this..mmm
]]>2012-10-19T12:31:49+01:002012-10-19T12:31:49+01:00https://brainmodular.org/forums/viewtopic.php?t=3605&p=24592#p24592Statistics: Posted by r.erorr — 19 Oct 2012, 13:31
Statistics: Posted by r.erorr — 18 Oct 2012, 22:55
]]>2012-10-18T20:14:04+01:002012-10-18T20:14:04+01:00https://brainmodular.org/forums/viewtopic.php?t=3605&p=24587#p24587(i temp disabled the color handling wich was more a dedicaced to pm fuction by waiting to find best way to handle) if want in/decrasecrease max mx size eit script first line and recompile. hope can help. could be errors as it's hard for my little brain to come back to this but seems ok.. hope it's like biking http://sensomusic.com/forums/uploads.ph ... l%2005.wkp
]]>2012-10-18T18:08:56+01:002012-10-18T18:08:56+01:00https://brainmodular.org/forums/viewtopic.php?t=3605&p=24586#p24586Statistics: Posted by 23fx23 — 18 Oct 2012, 19:08
]]>2012-10-10T11:43:18+01:002012-10-10T11:43:18+01:00https://brainmodular.org/forums/viewtopic.php?t=3605&p=24524#p24524 Yes, great script of course!
Statistics: Posted by r.erorr — 10 Oct 2012, 12:43
]]>2012-10-10T11:26:50+01:002012-10-10T11:26:50+01:00https://brainmodular.org/forums/viewtopic.php?t=3605&p=24523#p24523 and mine was also a 23FX script, so maybe we have to kidnap 23FX for this one...or find another script guru
Statistics: Posted by nay-seven — 10 Oct 2012, 12:26
]]>2012-10-10T11:07:25+01:002012-10-10T11:07:25+01:00https://brainmodular.org/forums/viewtopic.php?t=3605&p=24522#p245222. 32fx32 example is caption scrolling
I assume that joffo think about visual scrolling with definite values and caption, but maybe I'm wrong
Statistics: Posted by r.erorr — 10 Oct 2012, 12:07
Statistics: Posted by nay-seven — 10 Oct 2012, 09:46
]]>2012-10-10T01:44:49+01:002012-10-10T01:44:49+01:00https://brainmodular.org/forums/viewtopic.php?t=3605&p=24520#p24520move&resize script can do the job but it's very CPU hungry
Statistics: Posted by r.erorr — 10 Oct 2012, 02:44
]]>2012-10-10T01:33:40+01:002012-10-10T01:33:40+01:00https://brainmodular.org/forums/viewtopic.php?t=3605&p=24519#p24519Maybe you can also scroll whole usine window like this? http://www.sensomusic.com/forums/upload ... oll_MX.wkp
Statistics: Posted by r.erorr — 10 Oct 2012, 02:33
]]>2012-10-09T23:59:05+01:002012-10-09T23:59:05+01:00https://brainmodular.org/forums/viewtopic.php?t=3605&p=24518#p24518you can't switch a cell.
Statistics: Posted by joffo78 — 10 Oct 2012, 00:59
]]>2012-10-09T23:35:35+01:002012-10-09T23:35:35+01:00https://brainmodular.org/forums/viewtopic.php?t=3605&p=24517#p24517Statistics: Posted by joffo78 — 10 Oct 2012, 00:35
]]>2012-10-09T22:51:13+01:002012-10-09T22:51:13+01:00https://brainmodular.org/forums/viewtopic.php?t=3605&p=24516#p24516Statistics: Posted by r.erorr — 09 Oct 2012, 23:51
]]>2012-10-09T22:42:29+01:002012-10-09T22:42:29+01:00https://brainmodular.org/forums/viewtopic.php?t=3605&p=24515#p24515I wonder if it's possible to add scrooler function in a matrix It means if i had a lot of row i would be able to display for example the 10 first and comind donw to display de next.
Statistics: Posted by joffo78 — 09 Oct 2012, 23:42
]]>BrainModularBrainModular Users Forum2012-10-19T13:21:29+01:00https://brainmodular.org/forums/app.php/feed/topic/36052012-10-19T13:21:29+01:002012-10-19T13:21:29+01:00https://brainmodular.org/forums/viewtopic.php?t=3605&p=24593#p24593what is even more strange is that if man put an array display or set it work correctly, but not with a simple array out.. I see no reason why it would behave like this..mmm
]]>2012-10-18T23:50:54+01:002012-10-18T23:50:54+01:00https://brainmodular.org/forums/viewtopic.php?t=3605&p=24590#p24590
