ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2012-09-22T07:56:39+01:00 https://brainmodular.org/forums/app.php/feed/topic/3582 2012-09-22T07:56:39+01:00 2012-09-22T07:56:39+01:00 https://brainmodular.org/forums/viewtopic.php?t=3582&p=24332#p24332 <![CDATA[automatic fade out]]> And your constant research gives the community some good tools !
Statistics: Posted by nay-seven — 22 Sep 2012, 08:56
2012-09-21T23:11:07+01:00 2012-09-21T23:11:07+01:00 https://brainmodular.org/forums/viewtopic.php?t=3582&p=24331#p24331 <![CDATA[automatic fade out]]> I'm always preocupated by specificities of my job.
time management is a little different...
Statistics: Posted by joffo78 — 22 Sep 2012, 00:11
2012-09-21T21:54:26+01:00 2012-09-21T21:54:26+01:00 https://brainmodular.org/forums/viewtopic.php?t=3582&p=24330#p24330 <![CDATA[automatic fade out]]> ariajazz was looking for an automatic fade, so if he need change the gain he can do it before the fade..so yes my solution is always 0dB at first .
Statistics: Posted by nay-seven — 21 Sep 2012, 22:54
2012-09-21T20:15:36+01:00 2012-09-21T20:15:36+01:00 https://brainmodular.org/forums/viewtopic.php?t=3582&p=24326#p24326 <![CDATA[automatic fade out]]> http://www.sensomusic.com/forums/upload ... 20time.pat
Image ?
Statistics: Posted by joffo78 — 21 Sep 2012, 21:15
2012-09-21T19:23:16+01:00 2012-09-21T19:23:16+01:00 https://brainmodular.org/forums/viewtopic.php?t=3582&p=24324#p24324 <![CDATA[automatic fade out]]> Statistics: Posted by joffo78 — 21 Sep 2012, 20:23
2012-09-21T17:27:11+01:00 2012-09-21T17:27:11+01:00 https://brainmodular.org/forums/viewtopic.php?t=3582&p=24323#p24323 <![CDATA[automatic fade out]]> Statistics: Posted by nay-seven — 21 Sep 2012, 18:27
2012-09-21T17:24:38+01:00 2012-09-21T17:24:38+01:00 https://brainmodular.org/forums/viewtopic.php?t=3582&p=24322#p24322 <![CDATA[automatic fade out]]> Statistics: Posted by Ariajazz — 21 Sep 2012, 18:24
2012-09-21T07:03:21+01:00 2012-09-21T07:03:21+01:00 https://brainmodular.org/forums/viewtopic.php?t=3582&p=24320#p24320 <![CDATA[automatic fade out]]> here an other version, mono and with a reset button , you can edit duration in seconds and minimum out
Download
Statistics: Posted by nay-seven — 21 Sep 2012, 08:03
2012-09-21T02:04:24+01:00 2012-09-21T02:04:24+01:00 https://brainmodular.org/forums/viewtopic.php?t=3582&p=24319#p24319 <![CDATA[automatic fade out]]>
FADERRATIC can be found at:
http://www.delamancha.co.uk/faderratic.htm
Statistics: Posted by Ariajazz — 21 Sep 2012, 03:04
2012-09-20T13:28:39+01:00 2012-09-20T13:28:39+01:00 https://brainmodular.org/forums/viewtopic.php?t=3582&p=24316#p24316 <![CDATA[automatic fade out]]> if you are working in mono, you don't have to connect anything on all the inputs on the right.
thats all.
the fader called "time" is there to set the time of your fade.
Using vst plugging is a good solution but if you want to share it with another pepole.
Statistics: Posted by joffo78 — 20 Sep 2012, 14:28
2012-09-20T06:32:59+01:00 2012-09-20T06:32:59+01:00 https://brainmodular.org/forums/viewtopic.php?t=3582&p=24306#p24306 <![CDATA[automatic fade out]]> Statistics: Posted by Ariajazz — 20 Sep 2012, 07:32
2012-09-20T02:55:18+01:00 2012-09-20T02:55:18+01:00 https://brainmodular.org/forums/viewtopic.php?t=3582&p=24305#p24305 <![CDATA[automatic fade out]]> http://sensomusic.com/forums/uploads.ph ... volume.JPG
above is the link of the image for the patch I made. For some reason I can't upload it
Statistics: Posted by Ariajazz — 20 Sep 2012, 03:55
2012-09-20T02:46:11+01:00 2012-09-20T02:46:11+01:00 https://brainmodular.org/forums/viewtopic.php?t=3582&p=24303#p24303 <![CDATA[automatic fade out]]>
Thanks a lot for your reply. This is what I've done so far however some modules are not exactly the same such as the crossfade one since I can't find the one you used. I'm using USINE 5.20
I don´t know exactly how it will work, I asume that by pressing the GO buttom will do the fade. How do I control the duration of the fade out????
You will see that the incoming signal comes from the Amp sim AT3 outputs and the output of this patch is mono not stereo as you describe in your example. I'm a little confuse since this patch is a little tricky. I'd like you to clear things a little bit. The intention is to produce the fade (10 seconds duration) by a press of a button.
THANKS
Statistics: Posted by Ariajazz — 20 Sep 2012, 03:46
2012-09-20T00:13:02+01:00 2012-09-20T00:13:02+01:00 https://brainmodular.org/forums/viewtopic.php?t=3582&p=24301#p24301 <![CDATA[automatic fade out]]> Image
download
Statistics: Posted by joffo78 — 20 Sep 2012, 01:13
2012-09-20T00:05:08+01:00 2012-09-20T00:05:08+01:00 https://brainmodular.org/forums/viewtopic.php?t=3582&p=24300#p24300 <![CDATA[automatic fade out]]> I think i found a good solution :
http://www.sensomusic.com/forums/upload ... 0level.jpg
It's a little tricky but seems powerfull.
Look at the workspace :
set next level
Statistics: Posted by joffo78 — 20 Sep 2012, 01:05
2012-09-19T22:13:25+01:00 2012-09-19T22:13:25+01:00 https://brainmodular.org/forums/viewtopic.php?t=3582&p=24298#p24298 <![CDATA[automatic fade out]]>
USINE is able to do whatever you can imagine, I believe that. Now my question is:
Is there any way to automatically decrease an audio signal gradually from a given level to a lower one like a fade out with a 10 seconds of fade???
Probably using a counter an a fader together. Have no idea how to do it. Any help will be highly appreciated
Statistics: Posted by Ariajazz — 19 Sep 2012, 23:13
Image ?
Download
thats all.
THANKS
download
set next level
