ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2012-09-12T09:12:11+01:00https://brainmodular.org/forums/app.php/feed/topic/35662012-09-12T09:12:11+01:002012-09-12T09:12:11+01:00https://brainmodular.org/forums/viewtopic.php?t=3566&p=24251#p24251 Do you think Max for Live would allow this ?
Statistics: Posted by noise2sine — 12 Sep 2012, 10:12
]]>2012-09-06T13:15:35+01:002012-09-06T13:15:35+01:00https://brainmodular.org/forums/viewtopic.php?t=3566&p=24220#p24220i suppose we need a midi filter or mapper here, don't know enough Live ...
alternative : 2 use 2 instance of Usine...
Statistics: Posted by nay-seven — 06 Sep 2012, 14:15
]]>2012-09-06T12:17:59+01:002012-09-06T12:17:59+01:00https://brainmodular.org/forums/viewtopic.php?t=3566&p=24219#p24219really curious, how Live support for example a midi file with several midi canal inside..?
Statistics: Posted by nay-seven — 06 Sep 2012, 13:17
]]>2012-09-06T11:29:36+01:002012-09-06T11:29:36+01:00https://brainmodular.org/forums/viewtopic.php?t=3566&p=24218#p24218 I think what you describe is what i'm doing at the moment in Live :
- One midi track with Usine (the Usine workspace contains 2 piano roll, one set on channel 1 and the second one on channel 2) - another midi track which grab the midi flow from Usine . The problem is i can't set "midi from" Usine and thenchoosing a midi channel from Usine ! Live let pass all midi channel.
My wish is :
- One Midi track with usine - a Second midi track which grab midi channel 1 from Usine - a Third Track which grab the midi channel 2 from Usine
Do you think it's possible ?
Statistics: Posted by noise2sine — 06 Sep 2012, 12:29
]]>2012-09-06T10:51:48+01:002012-09-06T10:51:48+01:00https://brainmodular.org/forums/viewtopic.php?t=3566&p=24217#p24217Live constrains us to have only one midi channel per track. It also drives us to tweak things a bit when you need midi from a track where there is already an instrument (= a midi consumer)
You have to use source routing in that case.
Let's say that: track 1 the midi clip and your instrument track 2 the track where you want to grab midi from the track 1
both midi tracks of course
you have to choose in the track two as a midi source the track 1 and, in order to switch the input of track 1 to be processed, you have to put the monitor forced on IN .
does it answer ?
Statistics: Posted by protofuse — 06 Sep 2012, 11:51
]]>2012-09-06T10:26:36+01:002012-09-06T10:26:36+01:00https://brainmodular.org/forums/viewtopic.php?t=3566&p=24216#p24216we have protofuse here on the forum who is a certified ableton guy, I'll ask him...
Statistics: Posted by nay-seven — 06 Sep 2012, 11:26
Statistics: Posted by noise2sine — 06 Sep 2012, 08:57
]]>2012-09-06T00:05:27+01:002012-09-06T00:05:27+01:00https://brainmodular.org/forums/viewtopic.php?t=3566&p=24213#p24213Statistics: Posted by nay-seven — 06 Sep 2012, 01:05
2012-09-05T23:21:59+01:002012-09-05T23:21:59+01:00https://brainmodular.org/forums/viewtopic.php?t=3566&p=24212#p24212 The second solution is working fine for me. But i was thinking about a way to have in the same workspace the possiblity to send midi output from two different piano roll ,and with Usine used as a VSTi in Ableton Live ? my wish is to record these two piano roll in two different track in Live.
I can't configure midi output from Usine because it is used as a VSTi and if i'm using to different instance of Usine, i'm losing the sync process described above ...
Any solution ?
Statistics: Posted by noise2sine — 06 Sep 2012, 00:21
]]>2012-08-30T09:19:55+01:002012-08-30T09:19:55+01:00https://brainmodular.org/forums/viewtopic.php?t=3566&p=24185#p24185then a button with data buses..?
or each one a button but with the same midi learn
or use the starting outlet of the first piano roll to send the play to the second
and certainly others ways
Statistics: Posted by nay-seven — 30 Aug 2012, 10:19
]]>2012-08-30T09:08:04+01:002012-08-30T09:08:04+01:00https://brainmodular.org/forums/viewtopic.php?t=3566&p=24184#p24184 I'm using Usine as a VST in Ableton Live . The Usine patch consist of two tracks with a piano on each one . My wish is to be able to start the two piano roll in sync ? I mean one play button for the two ?
Or any other solution ?
Statistics: Posted by noise2sine — 30 Aug 2012, 10:08
]]>BrainModularBrainModular Users Forum2012-09-12T09:12:11+01:00https://brainmodular.org/forums/app.php/feed/topic/35662012-09-12T09:12:11+01:002012-09-12T09:12:11+01:00https://brainmodular.org/forums/viewtopic.php?t=3566&p=24251#p24251 Do you think Max for Live would allow this ?
My wish is :
does it answer ?
]]>2012-09-05T23:21:59+01:002012-09-05T23:21:59+01:00https://brainmodular.org/forums/viewtopic.php?t=3566&p=24212#p24212 The second solution is working fine for me. But i was thinking about a way to have in the same workspace the possiblity to send midi output from two different piano roll ,and with Usine used as a VSTi in Ableton Live ? my wish is to record these two piano roll in two different track in Live.
Any solution ?
