Statistics: Posted by headphoner — 30 Nov 2012, 12:59
]]>2012-11-29T23:08:43+01:002012-11-29T23:08:43+01:00https://brainmodular.org/forums/viewtopic.php?t=3559&p=24881#p24881Statistics: Posted by nay-seven — 29 Nov 2012, 23:08
I've started writing a SerialCommunication module. SDK installed and the first steps are done(Modulebodies and so on). If I have enough time I'll finish it until the end of the year. Hope so.
There must be a set of 3 modules
1. Serial Info - Get's information about the exisiting ComPorts. Must have a refresh pin it com ports are added dynamic (Eg. FTTI ports) 2. SerialOut - A buffered Serial output. Receives values and array data. Sending must bei buffered in a backgroundprocess (not sure if this a good idea in Usine, but I'll find out) 3. SerialIn - A buffered Serial input. Pin receives values as array data, pin current buffer length, pin overflow.
SerialIn/Out needs some configuration pins like baud, parity etc. (Mabe in the first version 1n8 is OK)
Peter
Statistics: Posted by hesspet — 29 Nov 2012, 22:54
]]>2012-09-08T17:45:57+01:002012-09-08T17:45:57+01:00https://brainmodular.org/forums/viewtopic.php?t=3559&p=24247#p24247to understand technical details in english good evening
Statistics: Posted by waolelaid — 08 Sep 2012, 18:45
]]>2012-09-08T07:24:15+01:002012-09-08T07:24:15+01:00https://brainmodular.org/forums/viewtopic.php?t=3559&p=24242#p24242but i suppose we still need a serial port module.. if you looking for info about arduino, here a French website : http://arduino.cc/fr/
Statistics: Posted by nay-seven — 08 Sep 2012, 08:24
]]>2012-09-08T00:41:15+01:002012-09-08T00:41:15+01:00https://brainmodular.org/forums/viewtopic.php?t=3559&p=24241#p24241trying to learn something and i found this http://www.kickstarter.com/projects/dig ... oard?ref=l in the "elektor newsletter" if it interest someone ?
Statistics: Posted by waolelaid — 08 Sep 2012, 01:41
]]>2012-09-02T16:38:12+01:002012-09-02T16:38:12+01:00https://brainmodular.org/forums/viewtopic.php?t=3559&p=24197#p24197Statistics: Posted by Floego — 02 Sep 2012, 17:38
]]>2012-08-25T07:44:22+01:002012-08-25T07:44:22+01:00https://brainmodular.org/forums/viewtopic.php?t=3559&p=24140#p24140
it would be very great!
Statistics: Posted by headphoner — 25 Aug 2012, 08:44
]]>2012-08-25T07:41:48+01:002012-08-25T07:41:48+01:00https://brainmodular.org/forums/viewtopic.php?t=3559&p=24139#p24139About arduino, yes could be interesting to have a serial solution and the best way will be to develop a specific module with the SDK , feel free to test !
Statistics: Posted by nay-seven — 25 Aug 2012, 08:41
]]>2012-08-25T00:56:18+01:002012-08-25T00:56:18+01:00https://brainmodular.org/forums/viewtopic.php?t=3559&p=24136#p24136 I work as a proffessional software developer and I've writte serveral communication implementations. Is there a interesst to develop a serial communication patch like the patches in PD or MAX?
Peter
BTW: for simple communication to an arduino I prefer this solution
]]>2012-11-29T22:54:47+01:002012-11-29T22:54:47+01:00https://brainmodular.org/forums/viewtopic.php?t=3559&p=24880#p24880
Peter
Peter
