ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2013-07-11T22:11:55+02:00 https://brainmodular.org/forums/app.php/feed/topic/3541 2013-07-11T22:11:55+02:00 2013-07-11T22:11:55+02:00 https://brainmodular.org/forums/viewtopic.php?t=3541&p=27176#p27176 <![CDATA[USINE AS A LIVE LOOPER]]> Statistics: Posted by tanabarbier — 11 Jul 2013, 22:11
2013-07-11T22:08:43+02:00 2013-07-11T22:08:43+02:00 https://brainmodular.org/forums/viewtopic.php?t=3541&p=27175#p27175 <![CDATA[USINE AS A LIVE LOOPER]]> 5.80 asio setup page
Statistics: Posted by nay-seven — 11 Jul 2013, 22:08
2013-07-11T21:49:38+02:00 2013-07-11T21:49:38+02:00 https://brainmodular.org/forums/viewtopic.php?t=3541&p=27174#p27174 <![CDATA[USINE AS A LIVE LOOPER]]>
Any improvement on looping with Hollyhock? I really haven't the time right now to learn the new version and convert all my workspaces etc, so I keep on using 5.8 (that I love, besides this looping problem).
I tried a lot of different approaches to that clic problem, and I don't know, I feel that it could be a sync problem, something to do with bloc size and how it make syncronization imposible for an accuracy smaller than what this bloc is, in time.
This may be a really stupid question, but, is there a way to know what the bloc size is in seconds?
Have a good day!
Statistics: Posted by tanabarbier — 11 Jul 2013, 21:49
2013-06-09T13:57:37+02:00 2013-06-09T13:57:37+02:00 https://brainmodular.org/forums/viewtopic.php?t=3541&p=26777#p26777 <![CDATA[USINE AS A LIVE LOOPER]]> @Farfadet : I hope I'll switch to hollyhock soon, but untill now I can't try your patch as I'm running 5Stage version. Please leave it available for some time on your server!
In fact, as it took me some time to try to solve this problem unsuccessfully, I decided to come back to a physical looper between my physical effect chain and Usine... So I have unfortunately only one sampler (I would have liked 2 or 3 virtual in Usine) but I can now concentrate on patching.
Statistics: Posted by XpiR — 09 Jun 2013, 13:57
2013-05-27T00:46:17+02:00 2013-05-27T00:46:17+02:00 https://brainmodular.org/forums/viewtopic.php?t=3541&p=26529#p26529 <![CDATA[USINE AS A LIVE LOOPER]]> The mute is placed on the output of the sampler.
It has the advantage of being consistent whether the loop is 5 seconds or 5 minutes, the mute will always be triggered X ms before the end.
The following patch is a basic Hollyhock sampler (press once to record, a second time to overdub in the loop) with the system i just described.
http://thebin.free.fr/KVR/Usine/GregBasicLooper.pat
Statistics: Posted by FarfadetFarfelu — 27 May 2013, 00:46
2013-05-21T21:24:43+02:00 2013-05-21T21:24:43+02:00 https://brainmodular.org/forums/viewtopic.php?t=3541&p=26374#p26374 <![CDATA[USINE AS A LIVE LOOPER]]> What was said in 2009 is still true :).
http://www.sensomusic.com/forums/viewtopic.php?id=1801
If there is a way, i have not been able to find it.
Statistics: Posted by FarfadetFarfelu — 21 May 2013, 21:24
2013-05-21T10:25:26+02:00 2013-05-21T10:25:26+02:00 https://brainmodular.org/forums/viewtopic.php?t=3541&p=26336#p26336 <![CDATA[USINE AS A LIVE LOOPER]]>
Statistics: Posted by joffo78 — 21 May 2013, 10:25
2013-05-20T21:56:18+02:00 2013-05-20T21:56:18+02:00 https://brainmodular.org/forums/viewtopic.php?t=3541&p=26313#p26313 <![CDATA[USINE AS A LIVE LOOPER]]> Percuson, did you or Joffo or somebody else proceeded to live sampling tests with Hollyhock ?
Finger crossed..........
Statistics: Posted by XpiR — 20 May 2013, 21:56
2013-05-05T22:56:29+02:00 2013-05-05T22:56:29+02:00 https://brainmodular.org/forums/viewtopic.php?t=3541&p=26037#p26037 <![CDATA[USINE AS A LIVE LOOPER]]> Sorry for the delay, I was out of home for three weeks...And back to this tomorrow !
I'll let you know soon.
Statistics: Posted by XpiR — 05 May 2013, 22:56
2013-04-17T21:00:10+02:00 2013-04-17T21:00:10+02:00 https://brainmodular.org/forums/viewtopic.php?t=3541&p=25958#p25958 <![CDATA[USINE AS A LIVE LOOPER]]> Maybe I found an easier solution for you:
GLoop is a very simple user and does only serve the essentials (also undo redo -> called clear and recall)
download here:
http://www.gvst.co.uk/beta.htm
Statistics: Posted by percuson — 17 Apr 2013, 21:00
2013-04-14T02:37:50+02:00 2013-04-14T02:37:50+02:00 https://brainmodular.org/forums/viewtopic.php?t=3541&p=25917#p25917 <![CDATA[USINE AS A LIVE LOOPER]]> I didn't find the time yet to send you a basic workspace...
I also have to reset möbius to get rid of everything not needed.
And some question to make it easier for me:
How many inputs do you have?
Möbius as master, or as slave? And do you work with prerecorded samples?
Because you are playing Sax, I assume, you want to control Möbius via footswitch?
I'll try to make it soon, but I'm not shure when I'll have time to do it. I had a lot of unexpected work this week....
Statistics: Posted by percuson — 14 Apr 2013, 02:37
2013-04-12T00:23:08+02:00 2013-04-12T00:23:08+02:00 https://brainmodular.org/forums/viewtopic.php?t=3541&p=25901#p25901 <![CDATA[USINE AS A LIVE LOOPER]]> Statistics: Posted by percuson — 12 Apr 2013, 00:23
2013-04-11T17:22:08+02:00 2013-04-11T17:22:08+02:00 https://brainmodular.org/forums/viewtopic.php?t=3541&p=25899#p25899 <![CDATA[USINE AS A LIVE LOOPER]]> If you do have time to quickly test this in Hollyhock :
-Pluging a mic in your soundcard
-Building a basic live sampler recorder patch with only rec/clear buttons and with the overdub and zerocross activated
-Singing and overdubing...
Which result with Hollyhock ? Same as Usine5 ? Clicks at the loop junction ?
Statistics: Posted by XpiR — 11 Apr 2013, 17:22
2013-04-11T17:16:23+02:00 2013-04-11T17:16:23+02:00 https://brainmodular.org/forums/viewtopic.php?t=3541&p=25898#p25898 <![CDATA[USINE AS A LIVE LOOPER]]>
Statistics: Posted by XpiR — 11 Apr 2013, 17:16
2013-04-11T17:12:44+02:00 2013-04-11T17:12:44+02:00 https://brainmodular.org/forums/viewtopic.php?t=3541&p=25897#p25897 <![CDATA[USINE AS A LIVE LOOPER]]>
@xpir: I got your E-Mail. I'll try to send you something tonight.
And you are right, we should open a new thread...
... I live very close to UT Connewitz :-)
Statistics: Posted by percuson — 11 Apr 2013, 17:12
2013-04-11T16:33:18+02:00 2013-04-11T16:33:18+02:00 https://brainmodular.org/forums/viewtopic.php?t=3541&p=25893#p25893 <![CDATA[USINE AS A LIVE LOOPER]]> here
you can test a basic version of my looper.
I could have some bugs but synchro is effective.
Statistics: Posted by joffo78 — 11 Apr 2013, 16:33
2013-04-11T12:30:09+02:00 2013-04-11T12:30:09+02:00 https://brainmodular.org/forums/viewtopic.php?t=3541&p=25891#p25891 <![CDATA[USINE AS A LIVE LOOPER]]> Statistics: Posted by XpiR — 11 Apr 2013, 12:30
2013-04-11T12:29:37+02:00 2013-04-11T12:29:37+02:00 https://brainmodular.org/forums/viewtopic.php?t=3541&p=25890#p25890 <![CDATA[USINE AS A LIVE LOOPER]]> Statistics: Posted by nay-seven — 11 Apr 2013, 12:29
2013-04-11T12:19:36+02:00 2013-04-11T12:19:36+02:00 https://brainmodular.org/forums/viewtopic.php?t=3541&p=25889#p25889 <![CDATA[USINE AS A LIVE LOOPER]]>
@nayseven : Nay, could give my mail to percuson please?
@laTenaille&percuson : maybe a good idea to open a new thread about Mobius in Usine? And leave this one dedicated to Usine as a live looper...
Statistics: Posted by XpiR — 11 Apr 2013, 12:19
2013-04-11T02:36:18+02:00 2013-04-11T02:36:18+02:00 https://brainmodular.org/forums/viewtopic.php?t=3541&p=25888#p25888 <![CDATA[USINE AS A LIVE LOOPER]]>
The main problem is to decide, how to trigger the script. Scripts are only called once in Möbius, you should call it every time, the feedback should change (e.g. the footswitch for record should also be triggered to the script). For blinking buttons this will be much more difficult, but it should also be possible with a loop with wait commands.
I posted a little demo in the Möbius Forum -> here!
... But I'm not shure if it really works...
Statistics: Posted by percuson — 11 Apr 2013, 02:36
2013-04-10T22:36:30+02:00 2013-04-10T22:36:30+02:00 https://brainmodular.org/forums/viewtopic.php?t=3541&p=25887#p25887 <![CDATA[USINE AS A LIVE LOOPER]]> Statistics: Posted by seamus — 10 Apr 2013, 22:36
2013-04-10T22:21:07+02:00 2013-04-10T22:21:07+02:00 https://brainmodular.org/forums/viewtopic.php?t=3541&p=25886#p25886 <![CDATA[USINE AS A LIVE LOOPER]]>
@percuson : I don't use Usine' sequencer, Mobius is kind of "stand alone". But I know one day I'll have to find a way to sync the loops with my effects (delays, chorus...).
I still don't understand how I can get a midi message out of Mobius to illuminate my pads. For example I'd love the pads to turn red when a track is armed, green when playing, off when mute, blinking when waiting for a record sync... I can do that by sending midi messages to the pads, it's on the Mobius side I don't know where to start :|
Statistics: Posted by La Tenaille — 10 Apr 2013, 22:21
2013-04-10T18:48:55+02:00 2013-04-10T18:48:55+02:00 https://brainmodular.org/forums/viewtopic.php?t=3541&p=25881#p25881 <![CDATA[USINE AS A LIVE LOOPER]]> Statistics: Posted by seamus — 10 Apr 2013, 18:48
2013-04-10T17:02:19+02:00 2013-04-10T17:02:19+02:00 https://brainmodular.org/forums/viewtopic.php?t=3541&p=25880#p25880 <![CDATA[USINE AS A LIVE LOOPER]]>
What kind of Midi problems do you have? Möbius seems to send everything besides MidiClock to the plugin outlet.
My question to you is:
How do you sync Möbius to Usine (Möbius as master). I still have some sync drift.
Statistics: Posted by percuson — 10 Apr 2013, 17:02
2013-04-10T13:59:30+02:00 2013-04-10T13:59:30+02:00 https://brainmodular.org/forums/viewtopic.php?t=3541&p=25870#p25870 <![CDATA[USINE AS A LIVE LOOPER]]> I also have troubles getting midi out of Mobius, but haven't dug a lot. It seems you can use scripts to send midi out (have a look to this thread) .
Using a Steinberg CMC-PD 4x4 pad, I'd love to have visual feedback of what happens in Mobius....
Statistics: Posted by La Tenaille — 10 Apr 2013, 13:59
Have a good day!
download here:
