ArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2012-08-06T14:10:03+02:00 https://brainmodular.org/forums/app.php/feed/topic/3540 2012-08-06T14:10:03+02:00 2012-08-06T14:10:03+02:00 https://brainmodular.org/forums/viewtopic.php?t=3540&p=24007#p24007 <![CDATA[some question about MIDI and poly]]> I know that extreme experiments not priority, but I just noticed polyphony voices and wanted to know...
Statistics: Posted by r.erorr — 06 Aug 2012, 14:10
2012-08-06T13:25:35+02:00 2012-08-06T13:25:35+02:00 https://brainmodular.org/forums/viewtopic.php?t=3540&p=24005#p24005 <![CDATA[some question about MIDI and poly]]>
what is pitch interpolation that it does not require independent sampler? just theoretically not in usine.
Senso can answer better to this question for Usine sampler but i suppose there's a difference between clones of the same sampler and individual different ones..?
is it possible to playback only those pitched interpolations from different samples? or change samples + keeping pitched interpolations from previous samples?
maybe i miss something but why you don't want to use polyphonic sub patch mode for this..?
Statistics: Posted by nay-seven — 06 Aug 2012, 13:25
2012-08-06T12:54:14+02:00 2012-08-06T12:54:14+02:00 https://brainmodular.org/forums/viewtopic.php?t=3540&p=24004#p24004 <![CDATA[some question about MIDI and poly]]> Statistics: Posted by r.erorr — 06 Aug 2012, 12:54
2012-08-06T12:29:12+02:00 2012-08-06T12:29:12+02:00 https://brainmodular.org/forums/viewtopic.php?t=3540&p=24003#p24003 <![CDATA[some question about MIDI and poly]]> midi mode in the sampler is only a pitch interpolation of one sample and don't give access to any of individual parameters of each voice.
The polyphonic mode for a sub-patch give you access of any of the parameters ( except , of course if you set it to once in poly)
Statistics: Posted by nay-seven — 06 Aug 2012, 12:29
2012-08-06T12:09:15+02:00 2012-08-06T12:09:15+02:00 https://brainmodular.org/forums/viewtopic.php?t=3540&p=24002#p24002 <![CDATA[some question about MIDI and poly]]> Statistics: Posted by r.erorr — 06 Aug 2012, 12:09
2012-08-06T11:41:16+02:00 2012-08-06T11:41:16+02:00 https://brainmodular.org/forums/viewtopic.php?t=3540&p=24001#p24001 <![CDATA[some question about MIDI and poly]]> when you use polyphonic VSTi sampler , it's the same, even if you don't see it
Statistics: Posted by nay-seven — 06 Aug 2012, 11:41
2012-08-06T11:30:29+02:00 2012-08-06T11:30:29+02:00 https://brainmodular.org/forums/viewtopic.php?t=3540&p=24000#p24000 <![CDATA[some question about MIDI and poly]]> Yes it is bit confusing to have one term for different things, or I must be more concrete. Most interesting for me is polyphony in sampler, not sub-patch. Because sampler can play only one sample at once, but in MIDI mode there is real polyphony. I hear several voices without multiplying samplers. So if the condition is only one sampler[without sub patch poly], how about my questions now?
Statistics: Posted by r.erorr — 06 Aug 2012, 11:30
2012-08-06T10:49:28+02:00 2012-08-06T10:49:28+02:00 https://brainmodular.org/forums/viewtopic.php?t=3540&p=23999#p23999 <![CDATA[some question about MIDI and poly]]> voice dispatcher module :
Download
Statistics: Posted by nay-seven — 06 Aug 2012, 10:49
2012-08-06T02:49:29+02:00 2012-08-06T02:49:29+02:00 https://brainmodular.org/forums/viewtopic.php?t=3540&p=23996#p23996 <![CDATA[some question about MIDI and poly]]>
1. how it is possible polyphony from one sample[in sampler], but not from two different?
2. is it possible slice the polyphony? that is to set different start/end position for each voice?
3. different fade in for each voice?
4. control voices via Array? [not sure what I mean with this right know... because in one moment we can see so much details, but describing all that takes half an hour]
Statistics: Posted by r.erorr — 06 Aug 2012, 02:49
Download
