Statistics: Posted by r.erorr — 09 Jul 2012, 17:24
]]>2012-07-09T14:46:46+01:002012-07-09T14:46:46+01:00https://brainmodular.org/forums/viewtopic.php?t=3515&p=23837#p23837about XY , maybe edit layout/inverse Y axis ..?
Statistics: Posted by nay-seven — 09 Jul 2012, 15:46
]]>2012-07-09T11:26:04+01:002012-07-09T11:26:04+01:00https://brainmodular.org/forums/viewtopic.php?t=3515&p=23836#p23836maybe it is possible convert XY values to array? because I got this trayectory on panner module symetric XY mode.
Statistics: Posted by r.erorr — 09 Jul 2012, 12:26
]]>2012-07-09T06:26:19+01:002012-07-09T06:26:19+01:00https://brainmodular.org/forums/viewtopic.php?t=3515&p=23832#p23832swap array module can be a start..?
Statistics: Posted by nay-seven — 09 Jul 2012, 07:26
]]>2012-07-08T19:27:55+01:002012-07-08T19:27:55+01:00https://brainmodular.org/forums/viewtopic.php?t=3515&p=23830#p23830I want to invert manually drawn log scale to exp scale. fore example if array size is 10 then exp = log 1 = 9 2 = 8 3 = 7 4 = 6 5 = 5 6 = 4 7 = 3 8 = 2 9 = 1
But I have max array size and not only integer values. So I need some system how to do that. any ideas?
Statistics: Posted by r.erorr — 08 Jul 2012, 20:27
]]>BrainModularBrainModular Users Forum2012-07-09T22:10:19+01:00https://brainmodular.org/forums/app.php/feed/topic/35152012-07-09T22:10:19+01:002012-07-09T22:10:19+01:00https://brainmodular.org/forums/viewtopic.php?t=3515&p=23844#p23844Statistics: Posted by r.erorr — 09 Jul 2012, 23:10
]]>2012-07-09T17:26:59+01:002012-07-09T17:26:59+01:00https://brainmodular.org/forums/viewtopic.php?t=3515&p=23839#p238391-x module works :
Statistics: Posted by nay-seven — 09 Jul 2012, 18:26
