ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2012-07-02T09:58:22+01:00 https://brainmodular.org/forums/app.php/feed/topic/3509 2012-07-02T09:58:22+01:00 2012-07-02T09:58:22+01:00 https://brainmodular.org/forums/viewtopic.php?t=3509&p=23792#p23792 <![CDATA[muddling up an array]]> GetDataArrayValue and a variable to get the min & max then set them back
or a GetMin equivalent to the GetLength we have yet
definitively need a parallel life...;)
Statistics: Posted by nay-seven — 02 Jul 2012, 10:58
2012-07-02T08:28:51+01:00 2012-07-02T08:28:51+01:00 https://brainmodular.org/forums/viewtopic.php?t=3509&p=23791#p23791 <![CDATA[muddling up an array]]>
Made minor change so that Array Out is now saved in patch as was not being restored before.
CODE:
//////////////////////////////////////////////// Randomly reorders data in array // Version 1.01// 2 July 2012// By Caco//////////////////////////////////////////////var ArrayIn, ButtonIn, ArrayOut &#58; tparameter;///////////////////////////////////////////////procedure init;begin   ArrayIn&#58;= CreateParam&#40;'Array in',ptarray&#41;; SetisOutput&#40;ArrayIn,false&#41;; ButtonIn&#58;= CreateParam&#40;'Shuffle',ptbutton&#41;; SetisOutput&#40;ButtonIn,false&#41;; Arrayout&#58;= CreateParam&#40;'Array out',ptarray&#41;; Setisinput&#40;ArrayOut,false&#41;;  SetMin       &#40;ArrayIn, 1.4e-45&#41;;     // set min parameter value SetMax       &#40;ArrayIn, 3.4e38&#41;;     // set max parameter value SetMin       &#40;ArrayOut, 1.4e-45&#41;;     // set min parameter value SetMax       &#40;ArrayOut, 3.4e38&#41;;     // set max parameter value SetDontSave  &#40;ArrayOut, FALSE&#41;;end;//////////////////////////////////////Procedure Callback&#40;N&#58;integer&#41;; Var i, j &#58; Integer;Var temp &#58; real;begin    if &#40;N=ButtonIn&#41;  then begin        for i&#58;= 0 to GetLength&#40;ArrayIn&#41;-1 do begin            SetDataArrayValue&#40;ArrayOut, i, GetDataArrayValue&#40;ArrayIn, i&#41;&#41;;        end;            SetLength&#40;ArrayOut,  GetLength&#40;ArrayIn&#41;&#41;;        for i&#58;= GetLength&#40;ArrayOut&#41;-1 downto 0 do begin            j &#58;= random&#40;i&#41;;            temp &#58;= GetDataArrayValue&#40;ArrayOut, j&#41;;            SetDataArrayValue&#40;ArrayOut, j, GetDataArrayValue&#40;ArrayOut, i&#41;&#41;;            SetDataArrayValue&#40;ArrayOut, i, temp&#41;;        end;       end;end;
Statistics: Posted by caco — 02 Jul 2012, 09:28
2012-07-01T15:24:53+01:00 2012-07-01T15:24:53+01:00 https://brainmodular.org/forums/viewtopic.php?t=3509&p=23788#p23788 <![CDATA[muddling up an array]]> i suppose we need here 2 variable , min and max and get their value from the first array..?
but it's not a big deal , so don't waste time for this if you don't have..
Statistics: Posted by nay-seven — 01 Jul 2012, 16:24
2012-07-01T12:19:09+01:00 2012-07-01T12:19:09+01:00 https://brainmodular.org/forums/viewtopic.php?t=3509&p=23787#p23787 <![CDATA[muddling up an array]]>
CODE:
var ArrayIn, ButtonIn, ArrayOut &#58; tparameter;///////////////////////////////////////////////procedure init;begin   ArrayIn&#58;= CreateParam&#40;'Array in',ptarray&#41;; SetisOutput&#40;ArrayIn,false&#41;; ButtonIn&#58;= CreateParam&#40;'Shuffle',ptbutton&#41;; SetisOutput&#40;ButtonIn,false&#41;; Arrayout&#58;= CreateParam&#40;'Arrayout',ptarray&#41;; Setisinput&#40;ArrayOut,false&#41;;  SetMin   &#40;ArrayIn, 1.4e-45&#41;;     // set min parameter value SetMax   &#40;ArrayIn, 3.4e38&#41;;     // set max parameter value SetMin   &#40;ArrayOut, 1.4e-45&#41;;     // set min parameter value SetMax   &#40;ArrayOut, 3.4e38&#41;;     // set max parameter valueend;//////////////////////////////////////Procedure Callback&#40;N&#58;integer&#41;; Var i, j &#58; Integer;Var temp &#58; real;begin    if &#40;N=ButtonIn&#41;  then begin        for i&#58;= 0 to GetLength&#40;ArrayIn&#41;-1 do begin            SetDataArrayValue&#40;ArrayOut, i, GetDataArrayValue&#40;ArrayIn, i&#41;&#41;;        end;            SetLength&#40;ArrayOut,  GetLength&#40;ArrayIn&#41;&#41;;        for i&#58;= GetLength&#40;ArrayOut&#41;-1 downto 0 do begin            j &#58;= random&#40;i&#41;;            temp &#58;= GetDataArrayValue&#40;ArrayOut, j&#41;;            SetDataArrayValue&#40;ArrayOut, j, GetDataArrayValue&#40;ArrayOut, i&#41;&#41;;            SetDataArrayValue&#40;ArrayOut, i, temp&#41;;        end;       end;end;
Statistics: Posted by caco — 01 Jul 2012, 13:19
2012-06-29T20:45:28+01:00 2012-06-29T20:45:28+01:00 https://brainmodular.org/forums/viewtopic.php?t=3509&p=23786#p23786 <![CDATA[muddling up an array]]>
yes, but i just realize that modules like swap or shift array don't get (and set) those values automatically , so maybe it's normal ..?
In that case I suspect array in and out ranges have default of 0-100 and just need modifying.
Statistics: Posted by caco — 29 Jun 2012, 21:45
2012-06-29T20:32:26+01:00 2012-06-29T20:32:26+01:00 https://brainmodular.org/forums/viewtopic.php?t=3509&p=23785#p23785 <![CDATA[muddling up an array]]> Statistics: Posted by nay-seven — 29 Jun 2012, 21:32
2012-06-29T20:21:59+01:00 2012-06-29T20:21:59+01:00 https://brainmodular.org/forums/viewtopic.php?t=3509&p=23784#p23784 <![CDATA[muddling up an array]]>
works fine Caco, but only for array with min=0, max=100
if not you have to set those values manually
How strange, just to check you mean min and max value in array between 0-100? Will try and work out where I went wrong!
Statistics: Posted by caco — 29 Jun 2012, 21:21
2012-06-29T15:54:25+01:00 2012-06-29T15:54:25+01:00 https://brainmodular.org/forums/viewtopic.php?t=3509&p=23782#p23782 <![CDATA[muddling up an array]]> Leaving for the weekend, so i will test it more on monday,
now able to share a 'midi stochastic seq' in my midi harmonizing tools patch.
Thank you caco.
Statistics: Posted by Fléau — 29 Jun 2012, 16:54
2012-06-29T15:48:38+01:00 2012-06-29T15:48:38+01:00 https://brainmodular.org/forums/viewtopic.php?t=3509&p=23781#p23781 <![CDATA[muddling up an array]]> if not you have to set those values manually
Statistics: Posted by nay-seven — 29 Jun 2012, 16:48
2012-06-29T15:34:44+01:00 2012-06-29T15:34:44+01:00 https://brainmodular.org/forums/viewtopic.php?t=3509&p=23780#p23780 <![CDATA[muddling up an array]]>
CODE:
var ArrayIn, ButtonIn, ArrayOut &#58; tparameter;///////////////////////////////////////////////procedure init;begin   ArrayIn&#58;= CreateParam&#40;'Array in',ptarray&#41;; SetisOutput&#40;ArrayIn,false&#41;; ButtonIn&#58;= CreateParam&#40;'Shuffle',ptbutton&#41;; SetisOutput&#40;ButtonIn,false&#41;; Arrayout&#58;= CreateParam&#40;'Arrayout',ptarray&#41;; Setisinput&#40;ArrayOut,false&#41;; end;//////////////////////////////////////Procedure Callback&#40;N&#58;integer&#41;; Var i, j &#58; Integer;Var temp &#58; real;begin    if &#40;N=ButtonIn&#41;  then begin        for i&#58;= 0 to GetLength&#40;ArrayIn&#41;-1 do begin            SetDataArrayValue&#40;ArrayOut, i, GetDataArrayValue&#40;ArrayIn, i&#41;&#41;;        end;            SetLength&#40;ArrayOut,  GetLength&#40;ArrayIn&#41;&#41;;        for i&#58;= GetLength&#40;ArrayOut&#41;-1 downto 0 do begin            j &#58;= random&#40;i&#41;;            temp &#58;= GetDataArrayValue&#40;ArrayOut, j&#41;;            SetDataArrayValue&#40;ArrayOut, j, GetDataArrayValue&#40;ArrayOut, i&#41;&#41;;            SetDataArrayValue&#40;ArrayOut, i, temp&#41;;        end;       end;end;
Statistics: Posted by caco — 29 Jun 2012, 16:34
2012-06-29T15:15:02+01:00 2012-06-29T15:15:02+01:00 https://brainmodular.org/forums/viewtopic.php?t=3509&p=23779#p23779 <![CDATA[muddling up an array]]> Statistics: Posted by nay-seven — 29 Jun 2012, 16:15
2012-06-29T11:48:23+01:00 2012-06-29T11:48:23+01:00 https://brainmodular.org/forums/viewtopic.php?t=3509&p=23777#p23777 <![CDATA[muddling up an array]]> like 1/2/3/4/5/6/7/8 to 6/4/5/2/3/1/8/7 (inverse of the 'sort array' module)?
Statistics: Posted by Fléau — 29 Jun 2012, 12:48
CODE:
CODE:
Thank you caco.
CODE:
