ArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2012-06-02T22:00:41+02:00 https://brainmodular.org/forums/app.php/feed/topic/3479 2012-06-02T22:00:41+02:00 2012-06-02T22:00:41+02:00 https://brainmodular.org/forums/viewtopic.php?t=3479&p=23560#p23560 <![CDATA[OSCLister]]>
after reading through the *Handbook of Usine modules, patch and libraries in pdf ?*-thread, i did some research on the possibilities of getting a pdf out of DokuWiki, which is the wiki engine currently used. i found out about the dw2pdf plugin, which could do that job and had a look at some sites using this plugin. by chance, i landed on the CD-HIT User's Guide, a manual for a protein clustering program..and funny enough every time i generated a pdf from that wiki, the OSClister put out the values mentioned in the first post..that also explains the bioinformatics reference...weird.
case closed!
~io
Statistics: Posted by iococoi — 02 Jun 2012, 22:00
2012-06-02T16:59:40+02:00 2012-06-02T16:59:40+02:00 https://brainmodular.org/forums/viewtopic.php?t=3479&p=23556#p23556 <![CDATA[OSCLister]]> Try to push the button show packets in the global setup/OSC tab, you'll see all incoming data's... ;-) you'll be surprised
Statistics: Posted by nay-seven — 02 Jun 2012, 16:59
2012-06-02T12:08:18+02:00 2012-06-02T12:08:18+02:00 https://brainmodular.org/forums/viewtopic.php?t=3479&p=23555#p23555 <![CDATA[OSCLister]]>
i'm just curious, where that other "thing" is coming from..i did not install this application and comparing biological sequences is just not in my portfolio :]]..
~io
Statistics: Posted by iococoi — 02 Jun 2012, 12:08
2012-06-02T11:53:00+02:00 2012-06-02T11:53:00+02:00 https://brainmodular.org/forums/viewtopic.php?t=3479&p=23554#p23554 <![CDATA[OSCLister]]> Statistics: Posted by nay-seven — 02 Jun 2012, 11:53
2012-06-02T11:40:32+02:00 2012-06-02T11:40:32+02:00 https://brainmodular.org/forums/viewtopic.php?t=3479&p=23553#p23553 <![CDATA[OSCLister]]>
can anyone help me on this matter? i was playing around with the OSClister to get some idea, what kind of OSC data Usine is actually receiving from Animata, a lowtech but real-time animation software..so i patched along and suddenly there shows up a rather strange entry in the incoming message values. I checked the URL, which points to some medpub about a web server for clustering and comparing biological sequences..
http://www.ncbi.nlm.nih.gov/pubmed/20053844
...havent got a clue whats that all about..OSC is listening at 7111
~ io
Statistics: Posted by iococoi — 02 Jun 2012, 11:40
case closed!
~io
~io
~ io
