ArrayArrayArrayArray BrainModular BrainModular Users Forum 2012-05-28T04:06:54+02:00 https://brainmodular.org/forums/app.php/feed/topic/3473 2012-05-28T04:06:54+02:00 2012-05-28T04:06:54+02:00 https://brainmodular.org/forums/viewtopic.php?t=3473&p=23497#p23497 <![CDATA[DISPLAY PRESETS IN TEXT FIELD]]> http://www.sensomusic.com/forums/upload ... ductor.PNG
This seems like a patching question so it is in the wrong forum category. The above method works well for me. I can send program change messages to the conductor and also use buttons for forward and backwards.
Nay Seven helped me put this together.
Hope it helps
Statistics: Posted by seamus — 28 May 2012, 04:06
2012-05-28T01:48:24+02:00 2012-05-28T01:48:24+02:00 https://brainmodular.org/forums/viewtopic.php?t=3473&p=23495#p23495 <![CDATA[DISPLAY PRESETS IN TEXT FIELD]]> KORE 2 to make things simpler and easier and create sub-patches as presets in stead so I can load them through load preset module. What I'm looking for now is to make all this thing work as described, Switch presets throug midi PC messages and display the name and information of presets on screen. Any tips ???
Thanks again
Statistics: Posted by Ariajazz — 28 May 2012, 01:48
2012-05-26T09:53:40+02:00 2012-05-26T09:53:40+02:00 https://brainmodular.org/forums/viewtopic.php?t=3473&p=23492#p23492 <![CDATA[DISPLAY PRESETS IN TEXT FIELD]]> drag a wire from the inlet program of the VST to create a combo box , is the combo has created a list of the programs.?
if yes, you can create a patch like this one, the filter module is set to filter=program change
then, play with the layout of the combo box to display it in your patch.
if not, you have to fill the combo box yourself.
btw, try to use the patching forum for this type of question... ;-)
Statistics: Posted by nay-seven — 26 May 2012, 09:53
2012-05-26T01:45:05+02:00 2012-05-26T01:45:05+02:00 https://brainmodular.org/forums/viewtopic.php?t=3473&p=23490#p23490 <![CDATA[DISPLAY PRESETS IN TEXT FIELD]]>
I have a USINE project which contains KORE 2 vst plugin inserted in channels. KORE has different presets that are switched through midi program change messages. What I intend to do is to place a TEXT FIELD displaying the name of the current preset being used. I have no idea how to do it but I'm sure it can be done:. I'm new to USINE but I know that it is extremely powerful.
I will appreciate a lot some help about where to place the text module and how to configure it to work as explained.
Thanks very much in advance
Statistics: Posted by Ariajazz — 26 May 2012, 01:45
Hope it helps
Thanks again
