ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2012-05-25T19:00:05+02:00https://brainmodular.org/forums/app.php/feed/topic/34702012-05-25T19:00:05+02:002012-05-25T19:00:05+02:00https://brainmodular.org/forums/viewtopic.php?t=3470&p=23489#p23489Statistics: Posted by seamus — 25 May 2012, 19:00
2012-05-25T08:27:44+02:002012-05-25T08:27:44+02:00https://brainmodular.org/forums/viewtopic.php?t=3470&p=23486#p23486You can use small presets for each tab and the conductor to store all ?. better is to try for a period
Statistics: Posted by nay-seven — 25 May 2012, 08:27
]]>2012-05-25T01:11:46+02:002012-05-25T01:11:46+02:00https://brainmodular.org/forums/viewtopic.php?t=3470&p=23483#p23483Statistics: Posted by seamus — 25 May 2012, 01:11
]]>2012-05-25T01:09:50+02:002012-05-25T01:09:50+02:00https://brainmodular.org/forums/viewtopic.php?t=3470&p=23482#p23482 yes and now i have a dispatch module controlling the midi flow. I may even build an arp and some other midi tricks in separate tabs.
Do you think it is unwise to have one tab be a preset tab that could store presets for the whole master patch?
BTW having access to geniuses like you is WAY better than the best manual!
]]>2012-05-25T00:55:19+02:002012-05-25T00:55:19+02:00https://brainmodular.org/forums/viewtopic.php?t=3470&p=23481#p23481Statistics: Posted by nay-seven — 25 May 2012, 00:55
]]>2012-05-25T00:44:43+02:002012-05-25T00:44:43+02:00https://brainmodular.org/forums/viewtopic.php?t=3470&p=23480#p23480Statistics: Posted by seamus — 25 May 2012, 00:44
]]>2012-05-25T00:40:00+02:002012-05-25T00:40:00+02:00https://brainmodular.org/forums/viewtopic.php?t=3470&p=23479#p23479Statistics: Posted by seamus — 25 May 2012, 00:40
]]>2012-05-25T00:38:57+02:002012-05-25T00:38:57+02:00https://brainmodular.org/forums/viewtopic.php?t=3470&p=23478#p23478Download
Statistics: Posted by nay-seven — 25 May 2012, 00:38
]]>2012-05-25T00:37:03+02:002012-05-25T00:37:03+02:00https://brainmodular.org/forums/viewtopic.php?t=3470&p=23477#p23477Statistics: Posted by seamus — 25 May 2012, 00:37
]]>2012-05-25T00:11:36+02:002012-05-25T00:11:36+02:00https://brainmodular.org/forums/viewtopic.php?t=3470&p=23475#p23475the midi in of the tab 2 is not linked to the main midi in, so can't receive midi flux..?
maybe you need a dispatch module who follow the tabs..? this way when you select tab1, midi in is send to tab1, when you select tab 2, midi in is sent to tab 2 ( if i understand correctly..)
Statistics: Posted by nay-seven — 25 May 2012, 00:11
i am having a problem with sending the midi to tab 2. My rotator should feed the note scaler. It only works if the notescaler is in the main patch. When i place the scaler in the tab 2 it doesnt get the midi properly. Does turning on the different tabs activate that portion of the patch? I would want the tabs just to be visual access but the mid should flow normally thoughout the patch and subpatches. i will also upload a screenshot.
]]>BrainModularBrainModular Users Forum2012-05-25T19:00:05+02:00https://brainmodular.org/forums/app.php/feed/topic/34702012-05-25T19:00:05+02:002012-05-25T19:00:05+02:00https://brainmodular.org/forums/viewtopic.php?t=3470&p=23489#p23489Statistics: Posted by seamus — 25 May 2012, 19:00
]]>2012-05-25T08:27:44+02:002012-05-25T08:27:44+02:00https://brainmodular.org/forums/viewtopic.php?t=3470&p=23486#p23486You can use small presets for each tab and the conductor to store all ?. better is to try for a period
