]]>2007-04-25T07:38:52+01:002007-04-25T07:38:52+01:00https://brainmodular.org/forums/viewtopic.php?t=347&p=1768#p1768 If I knew this existed, I might have done the PunchInLoops thing differently, by checking this value instead of counting blocks. That would make varying tempi easy to implement; as it is now I haven't bothere. The count blocks method do have the benefit of being lighter on the CPU (I think), and in addition the check for whether a play trigger should be sent is easier since I don't have to take into account any roundings.
Any possibility to have that as an input as well? (I'm never satisified, it seems...)
]]>2007-04-25T07:24:46+01:002007-04-25T07:24:46+01:00https://brainmodular.org/forums/viewtopic.php?t=347&p=1766#p1766already accessible in the synchro module (outlet Position).
]]>2007-04-18T16:46:22+01:002007-04-18T16:46:22+01:00https://brainmodular.org/forums/viewtopic.php?t=347&p=1685#p1685I'm gonna compose a new piece called psychic and emotional larsen using IBVA step1. But it's still too expensive for me. IBVA have had a long and chaotic existence! Why don't they try to work more with musicians in the electro-experimental domain? I was thinking about JMJ because he likes huge crazy systems and makes poor music with them (but lot of money - I really must be aware of that point!). And what about that crazy midi "keyboard"? We should talk about that in the General Discussion forum! That's interesting I think.
about the Brain2MIDI Expansion Pack: I think I have less dexterity with my brain than with my hands (and feet) even with the "coherence detector". Does J.-M. Jarre use it? That could explain some stuffs in that we used to call his music... And I'm wondering... what can happen when you connect Brain2MIDI to a random sequenced remote Midi-out
well, why this make you think about J-M Jarre ?
and yes, the point isn't to replace a midi keyboard by you'r brain, but... what about if a midi control surface .....is just you brain ? it's just about inovatif potential... the music modify you'r brain (emotion, sensation), and you'r brain modify the music. could be an interesting infinit beedback (don't know if i'm clear here)
Statistics: Posted by martignasse — 18 Apr 2007, 08:54
]]>2007-04-17T01:17:22+01:002007-04-17T01:17:22+01:00https://brainmodular.org/forums/viewtopic.php?t=347&p=1676#p1676It's incredible: we can have all what we dream about!
Statistics: Posted by Guest — 17 Apr 2007, 02:17
]]>2007-04-16T22:44:17+01:002007-04-16T22:44:17+01:00https://brainmodular.org/forums/viewtopic.php?t=347&p=1673#p1673next version (I hope) Also, I will create buttons on the conductor lite to have a direct acces create a midi learn, a key learn to recall a line. For the sequencer marker, a litle more complex but still easy. I put it in my todo list.
And an option on the sequencer module to go to loop marker X...
Yes, very good idea! I was wondering about that too.
=>martignasse - about the Brain2MIDI Expansion Pack: I think I have less dexterity with my brain than with my hands (and feet) even with the "coherence detector". Does J.-M. Jarre use it? That could explain some stuffs in that we used to call his music... And I'm wondering... what can happen when you connect Brain2MIDI to a remote Midi-out?
=>martignasse - about the Brain2MIDI Expansion Pack: I think I have less dexterity with my brain than with my hands (and feet) even with the "coherence detector". Does J.-M. Jarre use it? That could explain some stuffs in that we used to call his music... And I'm wondering... what can happen when you connect Brain2MIDI to a random sequenced remote Midi-out?
Statistics: Posted by Guest — 16 Apr 2007, 23:30
]]>2007-04-16T08:06:40+01:002007-04-16T08:06:40+01:00https://brainmodular.org/forums/viewtopic.php?t=347&p=1668#p1668Statistics: Posted by bsork — 16 Apr 2007, 09:06
]]>2007-04-16T08:06:26+01:002007-04-16T08:06:26+01:00https://brainmodular.org/forums/viewtopic.php?t=347&p=1667#p1667 no probleme for you'r crazy idea : http://www.ibva.com/Step1/Step1.html#midi
IBVA System is here for you, it's not an implant, but should do the trick
Statistics: Posted by martignasse — 16 Apr 2007, 09:06
]]>2007-04-16T03:37:02+01:002007-04-16T03:37:02+01:00https://brainmodular.org/forums/viewtopic.php?t=347&p=1663#p1663 One more cranky idea... I am dreaming about an implant in my head to drive the Conductor (and part of my keyboard). Waiting for that, could it be possible to have just a simple module? I could add a crazy script to decide when to trigger next or previous (or random) scene according to what I play...
Statistics: Posted by Guest — 16 Apr 2007, 04:37
]]>BrainModularBrainModular Users Forum2007-04-25T09:12:41+01:00https://brainmodular.org/forums/app.php/feed/topic/3472007-04-25T09:12:41+01:002007-04-25T09:12:41+01:00https://brainmodular.org/forums/viewtopic.php?t=347&p=1770#p1770Sorry, I'm confused. The manual is updated now.
the problem for me is the relation between ppqPos and SMPTEpos. Not so clear in my mind...
A direct access to ppQpos (Read & Write) in a script should be easy to implement.
