ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2015-05-15T11:16:54+01:00 https://brainmodular.org/forums/app.php/feed/topic/3457 2015-05-15T11:16:54+01:00 2015-05-15T11:16:54+01:00 https://brainmodular.org/forums/viewtopic.php?t=3457&p=32802#p32802 <![CDATA[No edit access to Wiki]]> Statistics: Posted by jongilhooly — 15 May 2015, 12:16
2013-05-13T21:18:40+01:00 2013-05-13T21:18:40+01:00 https://brainmodular.org/forums/viewtopic.php?t=3457&p=26077#p26077 <![CDATA[No edit access to Wiki]]> Statistics: Posted by bsork — 13 May 2013, 22:18
2012-05-23T07:32:12+01:00 2012-05-23T07:32:12+01:00 https://brainmodular.org/forums/viewtopic.php?t=3457&p=23441#p23441 <![CDATA[No edit access to Wiki]]> Statistics: Posted by bsork — 23 May 2012, 08:32
2012-05-22T22:58:26+01:00 2012-05-22T22:58:26+01:00 https://brainmodular.org/forums/viewtopic.php?t=3457&p=23430#p23430 <![CDATA[No edit access to Wiki]]> Statistics: Posted by senso — 22 May 2012, 23:58
2012-05-22T20:50:41+01:00 2012-05-22T20:50:41+01:00 https://brainmodular.org/forums/viewtopic.php?t=3457&p=23423#p23423 <![CDATA[No edit access to Wiki]]> Bsork, is there written "Logged as Bsork" at the bottom of the page, even if you seem to be unlogged ?
I'll try to go deeper tomorrow.
Statistics: Posted by LevraiBernardo — 22 May 2012, 21:50
2012-05-21T13:36:18+01:00 2012-05-21T13:36:18+01:00 https://brainmodular.org/forums/viewtopic.php?t=3457&p=23400#p23400 <![CDATA[No edit access to Wiki]]>
Statistics: Posted by nay-seven — 21 May 2012, 14:36
2012-05-21T11:31:55+01:00 2012-05-21T11:31:55+01:00 https://brainmodular.org/forums/viewtopic.php?t=3457&p=23399#p23399 <![CDATA[No edit access to Wiki]]>
As I've said, I've tested as bsork with both IE and Opera on my work machine (Win7/32 bit) and my private music machine (Win7/64 bit), as well as IE on a couple of other machines my family uses (XP and Vista).
As long as I can used bsork2 for Wiki editing, it doesn't really matter for me, but the problem may be something to have in mind next time something is being done on with access rights and so forth..?
Statistics: Posted by bsork — 21 May 2012, 12:31
2012-05-21T08:26:31+01:00 2012-05-21T08:26:31+01:00 https://brainmodular.org/forums/viewtopic.php?t=3457&p=23396#p23396 <![CDATA[No edit access to Wiki]]> Image
btw, have you tried with an other browser..?
Statistics: Posted by nay-seven — 21 May 2012, 09:26
2012-05-21T08:02:33+01:00 2012-05-21T08:02:33+01:00 https://brainmodular.org/forums/viewtopic.php?t=3457&p=23395#p23395 <![CDATA[No edit access to Wiki]]> Statistics: Posted by bsork2 — 21 May 2012, 09:02
2012-05-19T12:34:39+01:00 2012-05-19T12:34:39+01:00 https://brainmodular.org/forums/viewtopic.php?t=3457&p=23385#p23385 <![CDATA[No edit access to Wiki]]> very strange because the wiki access mode has not changed for a long time.
Did you enabled all the cookies on IE?
I suspect a security restriction from IE.
Personally I had to disable all the IE protection to access to the wiki correctly but it wasn't a login trouble.
Statistics: Posted by senso — 19 May 2012, 13:34
2012-05-19T07:08:07+01:00 2012-05-19T07:08:07+01:00 https://brainmodular.org/forums/viewtopic.php?t=3457&p=23383#p23383 <![CDATA[No edit access to Wiki]]>
Statistics: Posted by nay-seven — 19 May 2012, 08:08
2012-05-18T22:20:18+01:00 2012-05-18T22:20:18+01:00 https://brainmodular.org/forums/viewtopic.php?t=3457&p=23380#p23380 <![CDATA[No edit access to Wiki]]> Statistics: Posted by bsork — 18 May 2012, 23:20
2012-05-16T11:51:22+01:00 2012-05-16T11:51:22+01:00 https://brainmodular.org/forums/viewtopic.php?t=3457&p=23334#p23334 <![CDATA[No edit access to Wiki]]>
Statistics: Posted by bsork — 16 May 2012, 12:51
2012-05-16T11:49:16+01:00 2012-05-16T11:49:16+01:00 https://brainmodular.org/forums/viewtopic.php?t=3457&p=23333#p23333 <![CDATA[No edit access to Wiki]]> Statistics: Posted by nay-seven — 16 May 2012, 12:49
2012-05-16T11:43:40+01:00 2012-05-16T11:43:40+01:00 https://brainmodular.org/forums/viewtopic.php?t=3457&p=23332#p23332 <![CDATA[No edit access to Wiki]]>
IIRC, there was something similar wrong with logins some time ago - during last year, I suppose.
Statistics: Posted by bsork — 16 May 2012, 12:43
2012-05-16T11:32:06+01:00 2012-05-16T11:32:06+01:00 https://brainmodular.org/forums/viewtopic.php?t=3457&p=23330#p23330 <![CDATA[No edit access to Wiki]]> I've create a fake user (only gold member) and i can access to the edit page..
can someone confirm..?
Statistics: Posted by nay-seven — 16 May 2012, 12:32
2012-05-16T11:15:20+01:00 2012-05-16T11:15:20+01:00 https://brainmodular.org/forums/viewtopic.php?t=3457&p=23329#p23329 <![CDATA[No edit access to Wiki]]> Statistics: Posted by bsork — 16 May 2012, 12:15
