ArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2007-04-26T17:24:16+01:00https://brainmodular.org/forums/app.php/feed/topic/3452007-04-26T17:24:16+01:002007-04-26T17:24:16+01:00https://brainmodular.org/forums/viewtopic.php?t=345&p=1799#p1799The unpack option can produce a kind of very short arpeggio effect, if you play a big chord.
]]>2007-04-26T14:27:26+01:002007-04-26T14:27:26+01:00https://brainmodular.org/forums/viewtopic.php?t=345&p=1796#p1796 Will it be possible to delete all my "looping scripts" when using the unpack feature of the MIDI In?
Hem... well... In fact, I don't. Does it mean that when switching unpack on, we don't have midi arrays anymore (except for note# and note velocity)? No need to make loops in scripts? should I rewrite them to increase there speed?
Statistics: Posted by Guest — 23 Apr 2007, 00:31
]]>2007-04-21T21:55:54+01:002007-04-21T21:55:54+01:00https://brainmodular.org/forums/viewtopic.php?t=345&p=1723#p1723Statistics: Posted by bsork — 21 Apr 2007, 22:55
2007-04-21T17:41:28+01:002007-04-21T17:41:28+01:00https://brainmodular.org/forums/viewtopic.php?t=345&p=1712#p1712I'll try to make good use of that.
Thanks.
Statistics: Posted by Guest — 21 Apr 2007, 18:41
]]>2007-04-21T13:27:43+01:002007-04-21T13:27:43+01:00https://brainmodular.org/forums/viewtopic.php?t=345&p=1704#p1704The Unpack option transforms a polyphonic signal to a monophonic one. For example, if two midi note arrive at the same time, Usine delays the second note a little to always create monophonic signal. With this new midi flow, you can apply any math transformations you want because it's almost like a normal data flow.
]]>2007-04-16T00:06:42+01:002007-04-16T00:06:42+01:00https://brainmodular.org/forums/viewtopic.php?t=345&p=1661#p1661 I was used to see that Sysex connector on "Midi In" modules and not understanding the use of it. But it does not exists anymore and now I can see there an "Unpack" switch! I did not find any explanation about it in the doc... I'm sure it's very useful, I would like to understand! I've tried ON and OFF, without noticing an explicit difference... Can someone explain it to me?
Thanks!
Statistics: Posted by Guest — 16 Apr 2007, 01:06
]]>BrainModularBrainModular Users Forum2007-04-26T17:24:16+01:00https://brainmodular.org/forums/app.php/feed/topic/3452007-04-26T17:24:16+01:002007-04-26T17:24:16+01:00https://brainmodular.org/forums/viewtopic.php?t=345&p=1799#p1799The unpack option can produce a kind of very short arpeggio effect, if you play a big chord.
]]>2007-04-21T17:41:28+01:002007-04-21T17:41:28+01:00https://brainmodular.org/forums/viewtopic.php?t=345&p=1712#p1712I'll try to make good use of that.
Thanks.
