ArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2012-05-09T03:03:33+02:00 https://brainmodular.org/forums/app.php/feed/topic/3434 2012-05-09T03:03:33+02:00 2012-05-09T03:03:33+02:00 https://brainmodular.org/forums/viewtopic.php?t=3434&p=23223#p23223 <![CDATA[Video pb]]>
Statistics: Posted by Clearscreen — 09 May 2012, 03:03
2012-05-08T23:41:03+02:00 2012-05-08T23:41:03+02:00 https://brainmodular.org/forums/viewtopic.php?t=3434&p=23221#p23221 <![CDATA[Video pb]]>
Kenan
Statistics: Posted by Ken29 — 08 May 2012, 23:41
2012-05-07T04:35:03+02:00 2012-05-07T04:35:03+02:00 https://brainmodular.org/forums/viewtopic.php?t=3434&p=23204#p23204 <![CDATA[Video pb]]> VVVV instead and control vvvv using OSC from Usine? vvvv's a lot more flexible in terms of what video it can play and how you can stream it.
Statistics: Posted by Clearscreen — 07 May 2012, 04:35
2012-05-04T18:54:13+02:00 2012-05-04T18:54:13+02:00 https://brainmodular.org/forums/viewtopic.php?t=3434&p=23194#p23194 <![CDATA[Video pb]]>
Kenan
Statistics: Posted by Ken29 — 04 May 2012, 18:54
2012-05-04T18:47:52+02:00 2012-05-04T18:47:52+02:00 https://brainmodular.org/forums/viewtopic.php?t=3434&p=23193#p23193 <![CDATA[Video pb]]> Statistics: Posted by nay-seven — 04 May 2012, 18:47
2012-05-04T17:32:53+02:00 2012-05-04T17:32:53+02:00 https://brainmodular.org/forums/viewtopic.php?t=3434&p=23191#p23191 <![CDATA[Video pb]]>
I resampled my video to 1024 x 768 wich is the proj matrix, it really improved the quality.
I had another pb, apparently, Usine doesn't seem to like >1go video files, after 1go, Usine stop reading the file and the last part of the video is black. I had to reduce the quality of the video.
Now I have a bigger problem. I use the sampler during the video playback, even in full screen, I have a Usine notification for peak creating, is there's a way to make it not appeared ?
Statistics: Posted by Ken29 — 04 May 2012, 17:32
2012-05-03T10:43:46+02:00 2012-05-03T10:43:46+02:00 https://brainmodular.org/forums/viewtopic.php?t=3434&p=23175#p23175 <![CDATA[Video pb]]> 24fps is the default in Usine but can be changed in the setup/midi in
Statistics: Posted by senso — 03 May 2012, 10:43
2012-05-02T19:38:51+02:00 2012-05-02T19:38:51+02:00 https://brainmodular.org/forums/viewtopic.php?t=3434&p=23168#p23168 <![CDATA[Video pb]]> And maybe use the same ratio in the player and the projector ( for example 1/2 of the projector :512x384 )
Statistics: Posted by nay-seven — 02 May 2012, 19:38
2012-05-02T19:15:51+02:00 2012-05-02T19:15:51+02:00 https://brainmodular.org/forums/viewtopic.php?t=3434&p=23167#p23167 <![CDATA[Video pb]]>
I work at the moment on an installation with sound and video. My video file in an .avi H264 720x576 and I use a projector (1024x768) with a 4x3m image. If I play the video with the media player, it is very clean, if I play it with Usine, it is dirty and pixelized... Any idea ?
PS : I'm in a rush, the opening is on next Tuesday...
Kenan
Statistics: Posted by Ken29 — 02 May 2012, 19:15
Kenan
Kenan
Kenan
